Removing Upper ball joint
Discussion in '1st Gen. Tacomas (1995-2004)' started by SacYota, Nov 2, 2013.
  1. Nov 2, 2013 at 2:41 PM
    SacYota
    SacYota [OP] Member
    Sacramento,CA
    97 Tacoma
    Sup guys,
    I'm new here and was looking for other ideas of removing the upper ball joint from the UCA. I've tried the "fork" to split it out, but no luck. I've tried heating around the ringof the UCA and again no luck of taking it out. DW-40 and PB blaster to soak but still didn't work after hitting n tapping it with the sledge and mallet. Any ideas?
  2. Nov 2, 2013 at 2:51 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Get a pitman arm puller: I used it when replacing my UCAs. Didn't feel like smashing suspension parts with a hammer.
    Use it like this (steering stabilizer shown, but works the same way on your UCA):
  3. Nov 3, 2013 at 8:10 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Different size pickle fork? sometimes you have to jack up the LCA to make the UCA flatter and really bash the fork to get separation..
  4. Nov 3, 2013 at 8:21 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Take loosen castle nut and hit the spindle with hammer it will pop right out. using the fork can eat up the ball joint.
  5. Nov 3, 2013 at 8:40 AM
    runyun
    runyun Well-Known Member
    Irving/N. Grand Prairie
    02 Silver TRD DC
    I would also flip the castle nut..
    which reminds me, which would you guys recommend when doing upper bj's:
    OEM or Moog
    Same price (roughly) but I've noticed Moogs are built a lil more heavy duty.
    (sorry to threadjack)
  6. Nov 3, 2013 at 9:15 AM
    KenLyns
    Belly of the Beast
    The ball joint boot is already destroyed (or maybe that's why the OP wanted to change it in the first place).
    The rule of thumb is to hit what the tapered stud goes through, which on 2nd gens means hammering the spindle. On 1st gens you'd have to hammer the UCA, which can damage the UCA.
  7. Nov 3, 2013 at 9:15 AM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I've found that hitting it with heat, then cooling it rapidly with penetrating oil, and maybe a light tap with a pickle fork, and the front shocks will do all the work.
  8. Nov 3, 2013 at 9:25 AM
    BCephus
    BCephus Alright then
    Slingblade
    Virginia
    08 DCabSB 6 speed OME'd
    OME 886/dakar heavy, ARB bumper, 9.5XP warn, PDM tranquil kit, custom bullet hole tailgate anti theft kit, Camburg ball joint UCAs, Centerforce II clutch, FJ cruiser TRD wheels (black) with 285/75/16 Ds (white letters out, (Duh))
    Raybestos professional, which is the same as top tier NAPA stuff. They even use the same "sales" video. I would also put the castle nut back on to catch everything when it does come loose. Also, make sure there is some force in addition to gravity (pry bar, pitman arm puller etc) pushing the control arm and spindle apart while you are hitting it. Looks like you made some additional tire clearance also. Good luck bro.
  9. Nov 5, 2013 at 9:00 PM
    JLee
    Jerry
    Benicia, CA
    You can just hit the spindle on the 1st gens as well. Ive lifted about 20 and it works every time.
  10. Nov 6, 2013 at 7:01 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    lucky for me I was replacing both the UCA and Ball Joint so I just hammered and ground away to get it out. Although my ball joint separated real easy from the UCA. But the week leading up to the job I was soaking with PB Blaster everyday.
