Removing the "secondary filter" aka charcoal filter from the airbox.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MaGuyver, Dec 2, 2020.
  1. Dec 2, 2020 at 3:49 PM
    MaGuyver
    MaGuyver [OP] Well-Known Member
    Savannah, Ga.
    2020 Tacoma Sport, Cement
    Tinted glass, Bed mat, Rigid light bar, Bakflip FiberMax tonneau, Bull bar, LED cabin lights, Bed lights.
    Are many of you removing the secondary filter? I did this on my 2007 Tacoma, but not sure about doing it in the new one.
    What are the Pors and Cons of it?
  2. Dec 2, 2020 at 3:51 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
  3. Dec 2, 2020 at 3:51 PM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    When I upgraded to a TRD CAI (cold air intake), I tried removing the charcoal filter from the OEM box. Didn't feel or notice a difference with it on or off so just left it on the TRD version.
  4. Dec 2, 2020 at 3:57 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    ...just ask yourself is a miniscule gain in less-restricted airflow which the ECU still calculates air:fuel ratios while not reducing as much air particulates from entering your engine something you truly prefer? Cleaner vs. (Placebo effect) "Gains"...
  5. Dec 2, 2020 at 4:04 PM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I'm all for getting rid of unnecessary elements that affect performance, but personally, I think that filter does more good than harm.
    Seventh and poopshute like this.
  6. Dec 2, 2020 at 4:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you change your air filter regularly there really won’t be any cons.
    If you never change your air filter, or use crappy filters, there might be a “small” possibility that many many years down the road it can restrict air flow.
    I vote leave it in there. It’s really not hurting anything.
    Taco_mike73 likes this.
  7. Dec 2, 2020 at 4:31 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Removed mine with hopes that it was faulty or clogged and might possibly improve my fuel mileage......it didn’t change a thing....
    TnShooter likes this.
  8. Dec 2, 2020 at 4:33 PM
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    I got rid of mine when I installed my supercharger. Not for more airflow, but because it’s one less barrier for the sound of the supercharger to get muffled by.
    You will get a non-noticeable amount more airflow by removing it. There is zero harm to removing it other than possible smells.
    The purpose of that filter is to block crankcase fumes (from the passenger valve cover vent) and other hydrocarbon smells from exiting the intake when the car is off. So it’s a filter for air leaving the intake. Your primary filter does actual filtering.
    I have noticed no increase in smell, but if you start to smell a hint of oil or fuel in the garage after you remove it that is why.
    BLKRCAT and VB25 like this.
  9. Dec 2, 2020 at 4:41 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Lexus V8 F cars (IS F, RC F, ETC) have an air box with a vertical filter. The upper half lacks the charcoal filter, likely for noise, but could play into resonance, throttle response, or flow.
    uurx likes this.
  10. Dec 2, 2020 at 4:42 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    it's a very non-restrictive filter strictly for emissions purposes. I wouldn't bother removing it. Noone has ever mentioned any change in performance after removal. I do wonder how long it's actually effective for, as even the best charcoal filters are usually only effective for a year or two tops...
  11. Dec 3, 2020 at 5:37 AM
    MaGuyver
    Savannah, Ga.
    Thanks guys. Guess i will leave it alone.
  12. Dec 3, 2020 at 7:49 AM
    griffee
    griffee Well-Known Member
    My '06 4Runner with the 4.7 (285k on the clock) threw a code for months (can't remember the codes, but basically it was running too rich). Tried everything...new air filter, new MAF sensor, new spark plugs, new gas cap. It just got worse and worse, to the point where it ran like crap sometimes and I didn't want to drive it. Took the charcoal filter out and it was like a new vehicle. Ran better than I can ever remember and I believe the mileage even went up a bit. I would have never believed it could be the issue if I hadn't lived it.
    TMAN30 likes this.
  13. Dec 3, 2020 at 7:54 AM
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    If you look up the difference in flow between a dirty air filter and a clean air filter it’s such a small difference that removing this is pointless and is not going to do anything. If the trd intake barely does anything at all removing this won’t help.
  14. Dec 3, 2020 at 7:58 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Wait, so you removed something and then years later, now ask if there are pros and cons? Why did you do it to begin with then?
  15. Dec 3, 2020 at 7:59 AM
    griffee
    I'm pretty sure that this thing doesn't filter particulates. It is for absorbing gas fumes that come back thru the intake when the engine is shut off. When it is running it doesn't do anything (other than restrict airflow in my case). Maybe mine, because of the high mileage, was more restrictive than when new or fairly new.
    scotkw likes this.
  16. Dec 3, 2020 at 8:01 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Surprised it didn't throw an air/maf code.
  17. Dec 3, 2020 at 8:05 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Not the answer I would expect from MaGuyver.
    Kinda disappointed if I'm honest.
  18. Dec 3, 2020 at 8:06 AM
    griffee
    I think the code was P0177, "system too rich" but it's been a while. It was both cats/banks too.
  19. Dec 3, 2020 at 8:07 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    don't bother, it doesn't do anything worth the effort of removing it that I'm aware of
  20. Dec 3, 2020 at 8:21 AM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    This is correct. It absorbs fumes. Doesn't stop dirt. The next time the truck is started, it pulls the fumes out of the charcoal, "refreshing" the media and "saving" the environment. The charcoal canister on the gas tank does the same thing but on bigger scale. Both useless.
    griffee[QUOTED] likes this.
