Removing the Radio Surround Plastic
Discussion in '3rd Gen. Tacomas (2016-2023)' started by themadman90, Mar 3, 2016.
  1. Mar 3, 2016 at 5:58 PM
    themadman90
    themadman90 [OP] Well-Known Member
    Adam
    South Carolina
    '16 TRD Off Road 4x4
    How do you remove the plastic paneling around the radio and air vents?
  2. Mar 3, 2016 at 8:19 PM
    poorboy16
    poorboy16 New Member
    jason
    just pull on the right side and it will come out.
  3. Mar 3, 2016 at 8:20 PM
    poorboy16
    jason
  4. Mar 3, 2016 at 8:28 PM
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Mine did not pop off all at once as shown in the video. I worked from the passenger side over to the drivers side. If you end up doing that, keep in mind that the tabs are designed to pull straight out, so if you get too much of an angle on the piece, I suppose there is a possibility you could bust off a tab.
    It took a notable amount of force to get that first edge off. That said, I just pried it up with my fingers, I didn't yank on it with my whole body or anything.
