Removing tail lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rich8419, May 17, 2008.
  1. May 17, 2008 at 5:21 PM
    Rich8419
    Rich8419 [OP] Well-Known Member
    Louisiana
    2009 Dbl Cab Short Bed Offroad Pkg
    weathertech floor liners, scan guage, gatekeeper
    is there some sort of trick to removing the rear tail lights? I'm afraid of breaking it.
  2. May 17, 2008 at 5:28 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    should just be the 2 screws inside where the tailgate is....and then pull them out. should be it
  3. May 17, 2008 at 5:30 PM
    Rich8419
    Louisiana
    I have those two screws removed. It doesn't want to come out easily. I'm weary of just applying more force.
  4. May 17, 2008 at 6:46 PM
    hondabuster
    hondabuster Active Member
    MN
    08 reg cab 4x2
    Tinted window,vent shades
    I just removed mine last week and had the same concerns, There are two posts and grommets, and it can take a bit of force to remove them. Just pull straight back(no side to side motion), and they should pop out.
  5. May 17, 2008 at 8:25 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i had the same problem when i was putting some guards over my taillights. like hondabuster said, just take the screwes out and pull straight back with some force. when you feel/hear the popping sound, they'll slide out easily. at that point, just make sure to completely remove them slowly so you don't snag and pull any wires.
