removing splined coupler from transfer case?
Discussion in '1st Gen. Tacomas (1995-2004)' started by eimkeith, Oct 1, 2020.
  1. Oct 1, 2020 at 1:54 PM
    eimkeith
    eimkeith [OP] Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    Does anyone have a clever technique/method for removing the splined coupler from the transfer case without damaging it?
  2. Oct 1, 2020 at 1:57 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Are you talking about the input shaft? Driveshaft yolk?
  3. Oct 1, 2020 at 1:58 PM
    eimkeith
    J Keith
    at the input shaft, yes - between transmission and Tcase. Normally stays with the case when it is removed from the transmission. I want a good method for pulling it off of the case without damaging it so I can design a spacer to go behind it.
  4. Oct 1, 2020 at 2:00 PM
    Wulf
    rock raisin
    What are you trying to do, swap it for one with a different spline count?
    The input shaft is part one of the internal gears so you have to disassemble the entire thing to change it out.
  5. Oct 1, 2020 at 2:04 PM
    Bigal90
    Bigal90 Well-Known Member
    Houston, Texas
    98 XCab 3.4 Manual 4x4 SR5
    I've put vise grips around the coupler then used a puller with the jaws reacting off of the vise grips, if that makes sense. Of course you can still do damage with the vise grips so you do have to be careful.
    eimkeith[OP] likes this.
  6. Oct 1, 2020 at 2:05 PM
    eimkeith
    J Keith
    No, I just need to pull the coupler off to make a spacer to go behind it. I'm recentering it for my transfer case clocking ring, and need a good procedure for removing the coupler without damage (so no welding, etc. that folks do to pull it and discard it when going dual cases...)
  7. Oct 1, 2020 at 2:06 PM
    eimkeith
    J Keith
    has that worked for you? It seems like a press fit on that side...
  8. Oct 1, 2020 at 2:26 PM
    Bigal90
    Houston, Texas
    Yeah, it's definitely on there and required the puller. Seems like people have had varying degrees of success with this method though. If you haven't already checked it out, there are some discussions about removing it in this thread https://www.tacomaworld.com/threads/official-crawlbox-bs-thread.422186/
    eimkeith[QUOTED][OP] likes this.
  9. Oct 1, 2020 at 2:27 PM
    Wulf
    rock raisin
    My bad, I misunderstood
  10. Oct 1, 2020 at 2:28 PM
    eimkeith
    J Keith
    eh, my post was confusingly worded. all good.
  11. Oct 1, 2020 at 2:33 PM
    Bigal90
    Houston, Texas
    You could possibly install a collar like below to get a bit more clamping force on the coupler and prevent marring then use it to react off of with a puller.
    nagorb likes this.
  12. Oct 1, 2020 at 4:22 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    This style puller using two opposing of the four ujoint cap threaded holes on the flange. Get some long sockethead bolts and various washers, use something to protect shaft, like a small nut, warm it up. Replace seal while its out724DC38F-E4E6-47DA-8EB5-BF1BDADC4448.jpg
  13. Oct 1, 2020 at 5:14 PM
    eimkeith
    J Keith
    uh - no flange.
  14. Oct 1, 2020 at 5:25 PM
    Rachelsdaddy
    Southern NH
    Does it look like this? A three jaw puller will not grab it?
  15. Oct 1, 2020 at 5:26 PM
    eimkeith
    J Keith
    that's the front output flange; I need to separate the coupler that joins the transmission to the transfer case.
    Rachelsdaddy[QUOTED] likes this.
  16. Oct 1, 2020 at 5:27 PM
    Rachelsdaddy
    Southern NH
    Never mind, I misunderstood, I thought we were talking output shaft. Damn Bynadryl....
  17. Oct 1, 2020 at 7:23 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    This and a 3 jaw puller
  18. Oct 1, 2020 at 8:07 PM
    gearcruncher
    Canadain bumper technician
    What are you worried about .
    The outside of the coupler is not used for anything . All you have to worry about is damaging the splines .
    You can get a little agressive with the coupler
    Got a reverse hammer on a clamshell puller ? Thats what I use to use
    https://www.amazon.com/s?k=clamshel...=clamshell+puller,aps,181&ref=nb_sb_ss_i_2_16
    There should be some info lower in this thread .
    https://www.tacomaworld.com/threads/transfer-case-transfer-cases-in-first-and-2nd-gen-trucks.345652/
    Maybe some info here as well .
    https://www.tacomaworld.com/threads/transmission-swap-write-up-s.384303/
  19. Oct 1, 2020 at 10:45 PM
    eimkeith
    J Keith
    ah, so you use a bearing splitter with your puller? [EDIT] nevermind, I just looked up clamshell puller. nice but uber-expensive!
