Removing power steering reservoir?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Jan 28, 2015.
  1. Jan 28, 2015 at 6:35 AM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I have a 3.4L and was wondering how you remove the PS reservoir to clean the screen. I was doing the turkey baster method but stupidly put in on the pavement and it picked up small rocks when I put it back into the reservoir.
    Apparently there are three bolts to remove it but I'm not sure how to do this without removing the pulley, belt etc. I don't know how to move the pulley manually to see if there are bolts behind it. Are there two on the front side and one on the back?
  2. Jan 28, 2015 at 6:55 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Playing around with tablet, not sure the diagram will come out.
  3. Jan 28, 2015 at 6:58 AM
    koditten
    Kirk
    Central Michigan
    Here is an exploded view of the pump.
  4. Jan 28, 2015 at 7:32 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Thanks. I ended up cranking the starter for a split second to move the pulley so I could access that front bolt.
  5. Jan 28, 2015 at 8:56 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You could've also just loosened the belt, to turn the pulley :D
  6. Jan 28, 2015 at 11:33 AM
    little bear
    little bear Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    been trying to accomplish this also.... did you get it done?
  7. Jan 28, 2015 at 2:40 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Nah, too lazy :p
  8. Jan 28, 2015 at 4:54 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    It's pretty easy, took about 30 minutes. Just need a 3/8" driver and 12mm socket and a 12mm wrench. Then undo the two bolts on the rear with the driver/wrench and the front bolt with the driver. If the pulley access hole isn't oriented to get to the front bolt, just crank the starter for a split second or loosen the belt and turn the pulley. I used the lazy method of cranking the starter. Undo the return hose and pull off the resi. I pushed the return hose off by putting the open end of the 12mm wrench on the end of the hose and pushing down on the wrench using a flathead to get the hose off. The resi comes off at an angle, the tube on the bottom is shown in the vid and will help you figure out what direction to pull it off. Basically just pull it up and towards the pass side to get it off. Wiggle it a little so you're not putting stress on that o-ring.
    I used about a half a can of brake cleaner in each side of the holes and just shook it out. Sort of followed the procedure in this video (though removal of the whole PS pump is not necessary).
    https://www.youtube.com/watch?v=GZwYbvwIQ4Y
  9. Jan 28, 2015 at 5:41 PM
    tan4x4
    Rick
    Folsom, CA
    Don't forget about that little o-ring. Verify that it is still good before re-installing, or you'll have a leak.
  10. Jan 28, 2015 at 6:49 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I did. :) I even pulled it out again just to make sure it didn't slide out of the channel it was in and put a dab of ATF on there to help it slide in. All's good.
  11. Jan 28, 2015 at 8:15 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    there is a hole in the pulley so rotate the pulley until the hole lines up to remove that bolt. you most likely will be able to line things up by pulling on the belt one way or the other after its close unless you get unlucky
  12. Jan 29, 2015 at 8:31 AM
    little bear
    Barry Hobson
    Canadian, Texas
    thanks for the details..... how easy was putting the return hose back on the reservoir?
  13. Jan 29, 2015 at 10:46 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Just had to wipe the ATF off the outside of the hose with a towel, other than that you can slide it on by hand. :)
    I would suggest covering the lowest belt with a rag or plastic bag, you will spill some Atf when you pull the resi.
  14. Jan 30, 2015 at 4:44 PM
    little bear
    Barry Hobson
    Canadian, Texas
    Got it done today.... Could just be me but sounds quieter and turns easier ;)
  15. Jan 30, 2015 at 6:39 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Glad you got it taken care of! How dirty was your screen? Mine wasn't too bad but I wanted to spray any of the rocks out I might have picked up when I set the turkey baster on the pavement -_-
  16. Feb 2, 2015 at 9:43 AM
    little bear
    Barry Hobson
    Canadian, Texas
    Wasn't horrible but definitely some material on the screen
  17. Apr 20, 2022 at 1:06 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Sooo, I am in the process of doing this, but when I line up the hole on the pulley I still can't get that front bolt off, the wrench won't fit. Is there a trick to doing it? I'd strongly prefer to not have to take off the pulley.
  18. Apr 20, 2022 at 1:15 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    You should be able to line up the hole in the pulley with the front bolt and get a socket on there. Check out Timmy's video on that job, start at 21:30 or so:
    https://youtu.be/5k61KXRK8bM?t=1287
    drewskie[QUOTED] likes this.
  19. Apr 20, 2022 at 2:54 PM
    drewskie
    Drew
    Burbank, CA.
    My engine is the 2.7, so I guess it's a bit different unfortunately. I thought that it was the same reservoir. That video is perfect though, thanks.I can get super close to getting the socket on the bolt but the pulley is still in the way, someone suggested taking off the belt so I'm going to try that
