Removing Gauge Needles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Okkine 2.0, Sep 29, 2023.
  1. Sep 29, 2023 at 7:07 PM
    Okkine 2.0
    Okkine 2.0 [OP] Well-Known Member
    2022 TRD Sport, Lunar Rock
    I removed those annoying stickers on the sun visor.
    Has anyone removed the needles from the instrument cluster for a 3rd Gen? Do they just pull off? Or is there more to it than that? They seem to be on there pretty tight (which makes sense...).
  2. Sep 29, 2023 at 8:33 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I don’t know about the Tacoma, but I’ve read in the past, you can really screw up gauge cluster pretty easily, so be careful.
    Stevie17 likes this.
  3. Sep 29, 2023 at 9:40 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Whaaa??
    Plan to mod it by adding some sparkly paint??
    Or?
    Maybe leave those alone?
    Or go ahead - I'll stay tuned...
  4. Sep 29, 2023 at 10:12 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Just curious, why do you need to remove the needles?
  5. Sep 30, 2023 at 6:50 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    This might be interesting...
    :popcorn:
  6. Sep 30, 2023 at 7:57 AM
    Okkine 2.0
    Exactly what I'm trying to avoid! Threads for previous generations say they just pull off, but I haven't seen anything specific for the 3rd gens.
    I like to have the interior cabin very dark at night. The gauges in these 3rd gens are just way too bright for my preferences, even when fully dimmed (yes, I know about turning the ODO knob).
    I'd like to throw some of those LED dimming strips over the LEDs in the gauges, to turn it down a few more notches.
    monoman[QUOTED] likes this.
  7. Sep 30, 2023 at 10:01 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    You'll help alot of quiet people out that like to mods things by finding out but at a great risk to yourself... I would get a scrapyard cluster to try it on first just to see how removal works... may not be able to test it by plugging the scrapyard one in but atleast not breaking the needle is a good first step.
  8. Sep 30, 2023 at 10:04 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’ve done this on a newer Subaru cluster and used two spoons to evenly pry up on the needle at the base. Came right off.
    Okkine 2.0[OP] and musicisevil like this.
  9. Sep 30, 2023 at 6:44 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Or you can dim the cluster illumination by turning the odometer knob counter clockwise.. :anonymous:
  10. Sep 30, 2023 at 6:49 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
  11. Sep 30, 2023 at 6:57 PM
    Okkine 2.0
    Read the whole comment before replying... :anonymous:
    Phlogiston and crazysccrmd like this.
  12. Sep 30, 2023 at 7:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Did you try the spoon trick?
  13. Sep 30, 2023 at 7:10 PM
    Okkine 2.0
    I haven't yet. I just wanted to make sure they still just pull off before putting to much force on it.
  14. Sep 30, 2023 at 7:12 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    @Okkine 2.0 I am not sure about the Tacoma, but on older Toyotas, the needles would pop off with a little prying action. The problem was with putting them back on. When the speedometer needle was removed, it would lose it's spring tension, effectively dropping it below 0 mph. So you had to put it back on at speed. The way I always did it was have a friend act as a pace car, and when we hit 65, I'd stick it back on. Kind of a pain, but not terrible. You may also be able to add a resistor in line with the illumination wire going to the gauges? This is all pure speculation though as I have never done it on a Tacoma. But assuming the gauge illumination is like the switches and other buttons, it will have an illumination + and -. You can add a resistor to either of those as long as they are just illumination. I would do the ground side just to be sure as that is most likely only illumination since it uses PWM for dimming. And PWM won't be affected by a resistor in a negative way BTW. Just something to look into.
  15. Sep 30, 2023 at 7:13 PM
    Puppypunter
    Johnny
    2019 Black SR
    @caribe makaira do you happen to know (if anyone does, it would be you :)) if the gauge cluster has its own illumination wires feeding it?
    musicisevil likes this.
  16. Sep 30, 2023 at 7:21 PM
    caribe makaira
    Caribbean, Puerto Rico
    There are a few fuses to the Combo Meter, one that is constant fused:
    Meant to "save" any settings.
    then there is the METER fuse (IGN)
    But, I have no info on how the Combo Meter handles its own illumination. (CAN-BUS might be involved)
  17. Sep 30, 2023 at 8:06 PM
    Okkine 2.0
    I traced out the wire for the headlight signal to the gauges the other day, hoping to put a resistor in there. Disconnecting it disables the lighting for the climate control, steering wheel, door panel, and all the other buttons, however the gauges stay illuminated.
    Same results when pulling fuses.
    Someone in another thread was saying the gauge lighting is controlled through the network, independently from the other buttons, rather than through a dedicated wire.
    Thanks for the info on putting them back on. Sounds like it would be wise to take the advice up above, and find one in the scrapyard to practice on.
  18. Sep 30, 2023 at 8:12 PM
    caribe makaira
    The illumination wires (PANEL fuse) to the Combo Meter is for the steering wheel switches and the dimming feature.
  19. Sep 30, 2023 at 9:09 PM
    Trail_Limo
    Trail_Limo Well-Known Member
    G
    Land of fruits and nuts
    Turd Gen OR Limo
    might be easier to just wear sunglasses
    Chew likes this.
  20. Sep 30, 2023 at 9:14 PM
    apreston1
    apreston1 Well-Known Member
    Liberty Hill, Texas
    Or hang a towel over the gauge cluster?
