Removing Frame Rivets
Discussion in 'Suspension' started by erok81, May 4, 2017.
  1. May 4, 2017 at 11:40 PM
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    Hopefully this is the best section for this. :)
    The rear spring hangers and bump stops are held on with rivets. When I did my hydraulic bumpstops I had to remove the factory bracket. I followed Icon's (I think) instructions of cutting an x in the head popping off the four pieces and then hammering out the remaining rivet.
    That didn't go as easily as sounded. Many minutes of hammering I ended up just cutting off the rivet heads and another hour of hammering got out the remaining rivets. I never managed to remove the lower ones and just used them as locating dowels and welded the bracket to the frame. Hey...at least it won't get stolen. o_O
    In a week I'll need to remove the factory hangers. I think there's close to 15 of these stupid things to remove. I'm debating on buying a small compressor and air chisel to help get them off.
    For those that have had to remove those. What did you do?
  2. May 4, 2017 at 11:54 PM
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
  3. May 5, 2017 at 12:06 AM
    erok81
    Imposter
    Haha. Yeah exactly. I'm half tempted to take it to a shop and pay them to replace the rivets with bolts. :rofl:
  4. May 5, 2017 at 12:08 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Plasma.
  5. May 5, 2017 at 12:13 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    cut the head off, grind it flush, smak the hangar with a hammer, if you see a clean round line in your grinded flush zone ur good, do that to all the rivets then hammer the bracket off. grind the stubs down flush. your probably going to plate over em anyway if your putting new hangars in. they wont "fall out". if you want em gone and have a hole in your frame "unnecessary" in most cases just use a plasma cutter
    Shmellmopwho likes this.
  6. May 5, 2017 at 12:24 AM
    erok81
    Imposter
    I'm replacing the hangers with something else. So I need the factory holes. I just wanted a better way to do it. From my last experience I foresee a couple days just to hammer those things out.
    Maybe I'll check with some shops. I think 500-600 bucks to replace the rivets with bolts would be worth it. Then I can just bolt on my new stuff.
  7. May 5, 2017 at 1:06 AM
    bullaculla
    Da big big island!
    Grinding off the head works, but sometimes the rivet body is so tight in the hole, it separates the frame layers when you pound them out and then you have to clamp them back together again.
  8. May 5, 2017 at 7:40 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    cutting the head with a angle grinder and pounding it out applies to some of the frame rivets, if you do that shackle flip you will run into rivets that have a double grooved through washers that are tacked on. simply pounding them out with a press/punch is a stroke of luck if the welds on the washers hold and you dont have to cut them out in awkward spaces.
    rivets in the rear bump stops is more straight forward but the rear shackle mounts hold in the crossmember for the tire carrier as well
  9. May 5, 2017 at 8:00 AM
    Basikbiker
    Trav
    First off what exactly are you trying to do and replace? Shackle flips on the 2nd gen tacos are absolutely pointless, there's no benifit, ok you get some more lift, but if you wheel your truck it will ruin your leaf springs, inverted shackle setups are better, they maintain a better spring rate curve.
    And if you want to keep the stock crossmember then yes removing the rivets is a pain in the butt. If you can drill em out that works pretty well too.
  10. May 5, 2017 at 8:28 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    What worked for me is cutting the rivet head off with an angle grinder, then used a flap wheel to flatten out everything. Next I used a punch to mark the center of the river. To complete the job, I drilled out the remainder of the river with a 1/2" bit. Once I got through maybe a 1/16" of material, the rest of the river popped out with no effort. This took maybe five minutes per rivet, where as the air hammer had a much more difficult time punching them out. I tried a few methods to see which one would work best, and I think that drilling them was the quickest and easiest. I didn't have a torch at my disposal, so I didn't try that method.
    Truckntran and Basikbiker like this.
  11. May 5, 2017 at 8:36 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Also, it's much easier to get at those rivets with the bed off of the truck. Really isn't much work to do it either.
  12. May 5, 2017 at 10:38 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I ground them flat, then drilled them. Think it was 4 per hanger. Lots of fun.
  13. May 5, 2017 at 5:02 PM
    erok81
    Imposter
    Thanks for the replies! I'll try the drilling method. I know the hammering method alone isn't remotely quick. :rofl:
    I didn't even think about the tire carrier there.
    I'm removing the hangers entirely and replacing them for a long travel kit. No shackle flip.
  14. Jan 5, 2018 at 11:40 PM
    artesho
    artesho Well-Known Member
    Randy
    Any updates to this? How’d t go?
    erok81[QUOTED][OP] likes this.
  15. Jan 6, 2018 at 12:26 AM
    erok81
    Imposter
    Got them all done. It sucked. Majorly.
    Most I had to grind flat and the drill multiple holes to get up to 3/8. Then a lot of hammering. The tire carrier ones are also welded so you have to grind those off too.
    By far the worst automotive project I’ve ever done. :)
  16. Jan 6, 2018 at 1:42 AM
    artesho
    Randy
    yayyyy sounds like fun! haha wish me luck. taking on this project tomorrow to install new shackle hangers
  17. Jan 6, 2018 at 2:29 AM
    erok81
    Imposter
    Good news. Those are the easiest ones!
    Just remember. There are two, I think the rear most ones but not 100%, that are welded on the top side. I hammered forever until I realized they were welded on the top. If you climb underneath it’s obvious which ones are.
    Some I ground flat some I didn’t. I think in the end it was easier to just drill them all in stages. Three bits up to 3/8 then the rivets just hammer out really easy.
    Unless you have an air chisel or torch. Then it’s different. I did mine cave man style with a drill and hammer.
    Good luck.:D
    artesho[QUOTED] likes this.
  18. Jan 6, 2018 at 4:45 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I saw someone used a ball joint press with a modified tip to push the rivets out after they were ground flat. They said it worked well for the crossmember ones.
    artesho likes this.
  19. Jan 6, 2018 at 9:59 PM
    artesho
    Randy
    Didn’t even get to cutting the stock hangers. Ran into an issue with my lower shock bolt being bent and the threads being all galled. Took a while to find and replace that as well as the lower shock bushing sleeve which was all mashed for some reason. Anyway, gonna reattempt tomorrow with lessons learned. I bought an air chisel/hammer to see if it’ll help.
  20. Dec 26, 2018 at 11:42 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Gonna tackle the bump stop rivets this afternoon. What do y'all think of center punching the middle of the head and drilling it out with a 1/2 bit and then punch off/out what's left of th rivets?
