Removing Crankshaft position sensor 2012 2.7
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spencey, Sep 8, 2021.
  1. Sep 8, 2021 at 6:03 PM
    Spencey
    Spencey [OP] Member
    Hello, I have been having a problem with fuel economy, acceleration, and now I have a bad sound between 1 and 2 rpm. I ran it through a shop’s scanner, and the only code was for the crankshaft position sensor ( which would make sense.) I saw one other thread talk about this, and the conclusion was the ac compressor needed to be removed. Is that true? Or is there and easier way to replace it?
    Toyota Tacoma 2.7
  2. Sep 8, 2021 at 6:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Jimmyh likes this.
  3. Sep 8, 2021 at 7:33 PM
    Spencey
    Spencey [OP] Member
    Okay, that is what I didn't want to hear. So you just have to shift it a bit? you dont have to fully disconnect it and replace the refrigerant correct?
  4. Sep 8, 2021 at 9:01 PM
    TnShooter
    Deogee
    STOCK
    That I don’t know, but that is what I’d try first.
    If I were to bet, I’d bet just unbolting it’s and moving it would do the trick.
    I have a 4.0 engine, I can’t really tell you 100% for sure.
  5. Sep 8, 2021 at 11:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What the manual says:
    CRANKSHAFT POSITION SENSORREMOVAL
    1.DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
    2.REMOVE ENGINE UNDER COVER SUB-ASSEMBLY NO.1 (for 4WD and Pre-Runner)
    3.REMOVE FAN AND GENERATOR V BELT (W/ AIR CONDITIONING)
    4.SEPARATE COMPRESSOR AND MAGNETIC CLUTCH (W/ AIR CONDITIONING)
    5.REMOVE IDLE PULLEY ASSEMBLY WITH BRACKET (W/ AIR CONDITIONING)
    (a) Remove the 5 bolts, then remove the idle pulley with bracket.
    Steps 4 and 5 are the pain in the @ss ones.
    Step 4 says to unbolt the compressor assembly and you can probably tie it back out of the way enough ( maybe ). Edit: I was looking at the compressor removal instructions and the suction hose has a long hard pipe and a bracket that may be troublesome to moving the compressor enough to get at the idler and bracket.
    Step 5 says to remove the idler pulley assembly and bracket held on by 5 bolts.
  6. Sep 8, 2021 at 11:15 PM
    Spencey
    Spencey [OP] Member
    Wow, you are a gem. Thank you! I get the sensor tomorrow, so I will let you know how it goes ( and if the issues are fixed.) This is really helpful.
  7. Sep 8, 2021 at 11:46 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
    All the luck! Let us know how this comes out.
  8. Sep 8, 2021 at 11:49 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Be gentle when pulling the sensor from the engine it is plastic and it will break if stressed too hard.
    Use a twisting back and forwards motion while pulling it out. You need to twist it to get the o-ring to unseal from the hole. Remember slow and steady wins the race.
    Do not put a side load on it as it will break off in the hole.
    TnShooter likes this.
  9. Sep 9, 2021 at 2:15 PM
    Spencey
    Spencey [OP] Member
    Update: Parts store ordered a cam sensor not a crankshaft drive sensor. Should get the correct part on Monday.
  10. Sep 9, 2021 at 2:28 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well damn. looking forward to your success.
  11. Sep 9, 2021 at 2:34 PM
    Spencey
    Spencey [OP] Member
    Thanks for your help! And me too. I have been having serious issues with power and acceleration. 21 second 0-60. Going from a v8 tundra and trying to drive this one is a struggle. Hopefully this will alleviate the problem!
  12. Sep 9, 2021 at 7:58 PM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    did the shop tell you the code number?
    I know you said it was the Crank sensor, but I recently chased down some of my own codes and found it to be the Oil Control Valve ( one of the things to check from the FSM was crank sensor )
