Removing chrome plating from emblems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jbrnigan, Sep 28, 2015.
  1. Sep 28, 2015 at 9:59 AM
    jbrnigan
    jbrnigan [OP] Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    After dealing with peeling plasiti-dip on emblems, I decided to just paint them. I had issues with adhesion (400 grit, plastic primer and Krylon fusion) so I just removed the chrome plating on the emblems. I am now going to paint them - color match. The process is time consuming, but, results in a "virgin" plastic surface to work with and prep for paint. Immerse the emblems in household bleach (use a plastic container), change the bleach twice a day. Process takes about a week on emblems the size pictured. All the chrome plating is removed without affecting the plastic lettering. Should work on any vacuum metalized auto part.
  2. Sep 28, 2015 at 10:04 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Interesting. I just might try this on other emblems.
  3. Sep 28, 2015 at 10:10 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    If you soak chrome plated plastics in acetone, it will do the same thing much quicker (hours, not days). You just have to be sure the base plastic doesn't melt from the acetone.
    EDIT: DON'T USE ACETONE! It will start to melt the plastic once the chrome is gone. I was wrong.
  4. Sep 28, 2015 at 10:51 AM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    I like this but am curious...do you just use some 3M double sided tape to re-apply the badges/emblems?
    Also kinda surprised that plasti-dip peeled. I had it on all my chrome badging of last vehicle for 3-4yrs w/o issue.
  5. Sep 28, 2015 at 11:08 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Looks good and its the right way to do it. Paint simply will not work long term over chrome. There are also DIY methods that use oven cleaner or brake fluid.
  6. Sep 28, 2015 at 12:44 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    That's tricky. I'm not sure what type of plastics emblems are made of but guessing emblems are most likely ABS (acrylonitrile butadiene styrene) which I don't believe will hold up. Only plastics that can safely contain acetone are PP=polypropylene and PPCO=polypropylene copolymer.
  7. Sep 28, 2015 at 1:01 PM
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Your right, I was able to take chrome off of R/C truck parts, but I just tried on a old car emblem, and it took the chrome off, but after the chrome was gone, it was starting to melt the plastic. Thanks for the info.
  8. Sep 28, 2015 at 3:26 PM
    jbrnigan
    Midwest
    I tested oven cleaner (EZ OFF) acetone and dot 3 brake fluid. EZ Off had no effect. (EZ Off will remove the chrome from poly styrene, like model car parts) Acetone and brake fluid both went after the chrome and the plastic! Chlorine bleach takes longer but has NO effect on the plastic. A reapplication of 3M double sided trim tape to reattach. Plasti-dip peeled off on the sharp corners of the lettering and needed to be touched up, was a PITA.
    steelhd and DriverSound like this.
  9. Sep 28, 2015 at 4:01 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Thanks.
  10. Oct 6, 2015 at 5:14 PM
    YotaComa22
    YotaComa22 Well-Known Member
    Ben
    Auburn, PA
    2016 TRD SPORT
    3" ToyTec Lift kit with ultra Goliath wheels and general grabber tires for now.
    What's the best way to re apply the emblem? 3M tape?
  11. Oct 6, 2015 at 6:31 PM
    jbrnigan
    Midwest
    Yep - 3M double sided tape. I have also used trim adhesive, but, the tape is quicker.
  12. Oct 11, 2015 at 4:15 PM
    YotaComa22
    Ben
    Auburn, PA
    2016 TRD SPORT
    The tape used from factory is a grey color. Very strong. How do you only put tape on letters so you don't see tape in between letters.
  13. Oct 11, 2015 at 4:53 PM
    jbrnigan
    Midwest
    I trim the tape before installing it on the back side of the emblem, and, you don't need to cover the entire back side - for example:
    TACOMA - the horizontal and vertical sides of the "T" - the vertical sides of the "A's", not the cross piece, the horizontal sides of the "C" etc. They won't fall off and you won't see tape in the letter spaces. The 3M tape I used is 1mm thick and 10 mm width.
  14. Oct 11, 2015 at 5:14 PM
    YotaComa22
    Ben
    Auburn, PA
    2016 TRD SPORT
    Thanks. Where ya get the good 3M tape at?
  15. Oct 11, 2015 at 6:15 PM
    jbrnigan
    Midwest
    E-bay
  16. Nov 8, 2015 at 11:25 AM
    YotaComa22
    Ben
    Auburn, PA
    2016 TRD SPORT
    Think this process will work on chrome plastic center caps for my ultra wheels?
