removing catalytic converter
Discussion in '1st Gen. Tacomas (1995-2004)' started by patrick2wdtacoma, Dec 4, 2018.
  1. Dec 4, 2018 at 6:46 AM
    patrick2wdtacoma
    patrick2wdtacoma [OP] Member
    patrick
    1999 toyota tacoma extended cab 2wd
    i have a 96 tacoma 2.4l engine. i want to remove the catalytic converter and replace it with just a straight pipe directly into the muffler. ive done this once before with a hardbody nissan. can it be done with a first gen tacoma?
  2. Dec 4, 2018 at 6:48 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Not a good idea. The truck won't ever run right.
    Replace the cat with quality aftermarket unit for best results.
  3. Dec 4, 2018 at 7:24 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Just curious, why it will not run? To my understanding first O2 sensor (before cat) is used to tune up the fuel/air mixture, the second O2 sensor (behind cat) is used for emission check only. Replacing cat with pipe will screw up emission check and will throw the engine check light (and will not pass emission obviously) but should not affect driving. I have not done it yet, but I read that there is some RC filter O2 sensor mod that would fool the ECM to not throw engine check light.
  4. Dec 4, 2018 at 7:42 AM
    yotatoy02
    yotatoy02 Well-Known Member
    Will
    1999 Gold Tacoma v6 4wd
    OME 3" Suspension lift, tailgate removal, 2016 wheels
    My brother tundra has no cat and it does not run right at idle due to it. Unless you re program the computer it’s always gonna throw a bad fuel to air
  5. Dec 4, 2018 at 7:43 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Luv my yota likes this.
  6. Dec 4, 2018 at 7:49 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    It will run but throw a CEL light. If you live in a place where they have testing (Which you must not have) it will be fine. You can also buy an 02 sensor elbow to trick it into thinking there is gas pressure in there and it will not affect the 02 sensor. It will stink, it will be loud. Do what you want. It's bad for the environment but hell - so are people in general. lol
    there is that rear 02 simulator mod that is quite inexpensive as well. Lots of people on here do it. Ever priced an OEM cat? Holy ---- You can also get an aftermarket cat. Your engine will be happier with the cat - however since they are designed for the back-pressure.
    RysiuM likes this.
  7. Dec 4, 2018 at 7:56 AM
    wheeliest
    Json
    TMPE AZ
    Please explain..
    Why would his engine be "Happier" that a restriction is there?
  8. Dec 4, 2018 at 8:03 AM
    Xbeaus
    Beau
    Because they engineered the engine with the back-pressure from the Catalytic converter in there. I am just assuming that the ECM,Fuel to air ratio, MAF sensor all play a part in that. Beside pollution control it's beneficial in my opinion.
    Someone would have to do a dyno test on the 4 banger or 6 to show any real data on that though. Maybe on a big V8 or something that displaces more would more exhaust flow benefit anything. I think most people do it because the cat is clogged and getting rid of it for a straight pipe is a cheap alternative.
  9. Dec 4, 2018 at 9:21 AM
    taco57
    taco57 Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    I have this on mine. Put straight pipe in after my converter was stolen. Works great to eliminate the check engine light and I have no drive-ability issues. If I were in need of replacing the entire exhaust I would probably start with a new converter just because of the environmental thing.
  10. Dec 4, 2018 at 10:11 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Don’t do that.
    Cut it off after the cat, or replace the cat with a more free-flowing one.
  11. Dec 4, 2018 at 12:13 PM
    patrick2wdtacoma
    patrick
    Bartmaster1234 do you have a particular reason as to why i shouldnt cut the cat off?
  12. Dec 4, 2018 at 12:15 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Like said above, The engine isn’t designed to deal with that lack of back pressure from the cat. You can run an O2 simulator if you want to rid the CEL.
    I read a post on this forum of someone who cut it off at the headers. He said his truck sounded like an “angry bumblebee”.
    Why do you want to straightpipe it, the sound?
    Xbeaus likes this.
  13. Dec 4, 2018 at 12:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    From my experience, sawzalls are quick and easy, take cats out in a jiffy
    E30325 likes this.
  14. Dec 4, 2018 at 12:20 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I’m calling PETA
  15. Dec 4, 2018 at 12:24 PM
    JKO1998
    Utah
    I’m just saying, thousands of cats have been cut out with a sawzall
  16. Dec 4, 2018 at 12:25 PM
    Clearwater Bill
    Billy
    Largo Florida
    1) All the cool kids are freaked over climate change. Whether you buy that or not, there is nothing redeeming in ICE emissions (of all kinds of things). Don't be part of the problem.
    2) it's actually Federally illegal, even in non emissions states. And a random roadside inspection can cause you grief.
    3) if you are off-road only (as in tow it or live on your own land and never leave), as in not plated, registered etc., you might be 'legal'. Doesn't mean that polluting is good.
    4) there is nothing to gain from cat removal other than noise making. If you think the OE cat is restrictive, install a performance one. Don't believe me, prove it out on a dyno. Not a butt meter, a real one.
    Xbeaus and BartMaster1234 like this.
  17. Dec 4, 2018 at 12:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Agreed. If you’re seeking sound, the exhaust without a cat won’t sound very good. A proper less restrictive car and even a better muffler would be much better.
  18. Dec 4, 2018 at 12:48 PM
    Xbeaus
    Beau
    Just go electric. Save the planet mofo! One Taco owner at a time ;)
    If I was you - to avoid too much grief and also remember you will smell like your exhaust. Everywhere you go. Your clothes - everything in there will smell like it. If - it's far enough away you won't but in traffic you are gonna stink. My local exhaust pros shop does a real kick ass deal on aftermarket catalytic converters. Quoted me about $145 to replace mine (total). That's a pretty sweet deal when compared to OEM stuff.
  19. Dec 4, 2018 at 12:49 PM
    RysiuM
    Rysiu
    If you are seeking sound why not buy a good stereo and blast those decibels inside the cabin only. Why everybody else has to suffer from the noise form your truck?
    If you want to get rid of the cat because you are afraid it will be stolen (or was stolen already), you can do what I did, when my OEM cat was stolen: put a new cat and some kind of theft protection. I went for "cat skid plate" solution. it is thick still plate bolted to the frame with secured bolts and blocking the cat from being cut or removed.
    The same kind of protection I did for my 2012 4Runner as soon as I got it home. 4Runner has 2 converters on both sides of transmission, so I adopted OR-FAB skid plate designed for 3-rd gen Tacoma.
    Simple solution - if you can't see it, you can't steal it.
    cruiserguy likes this.
  20. Dec 4, 2018 at 1:22 PM
    Xbeaus
    Beau
    Those are all good ideas. I've never heard of that being a problem where I live and I assume that those plates are not very cheap. My dog usually hears anybody remotely close to the house. They wouldn't stand a chance. lol
