Removing Badges
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rklimetz, Feb 5, 2020.
  1. Feb 5, 2020 at 3:59 PM
    rklimetz
    rklimetz [OP] Member
    Rachel
    2020 White Tacoma SR5
    Hello! Just upgraded from an '09 SC to a '20 DCLB. Trying to ease myself into some mods and just wanted to see if anyone has some helpful tips for removing the outside badges/emblems on your own? Thanks in advance!
  2. Feb 5, 2020 at 4:04 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Easiest way is fishing line or in a pinch dental floss. Then remove the residual adhesive with bug and tar remover. Don’t use any harsh chemicals.
    StayinStock and gator2764 like this.
  3. Feb 5, 2020 at 4:08 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
  4. Feb 5, 2020 at 4:13 PM
    Tacospike
    Two Trucks
    I pulled mine off with my hands and just washed off the residue... not the easiest way but worked for me
  5. Feb 5, 2020 at 4:21 PM
    AstoriaTRD
    AstoriaTRD Well-Known Member
    I used plastic razor blades and WD40 for my stickers. I've heard those "pin stripe" eraser wheels work well but I haven't used one.
  6. Feb 5, 2020 at 4:34 PM
    HeritageTRD
    HeritageTRD Well-Known Member
    Washington
    98 4runner 3.4 V6 5spd MT Anthracite Metallic
    265/75/R16 BFG KO2's on Akuza 359 wheels - Sport Hood Conversion - Trail Gear 60" Rock Sliders - Rola Roof Rack - Custom Front Recovery Points - Hella 500 fogs - Flowmaster 50 series - Smoked Tails - Clear Corner & Turn Lenses - 5% Tint - GT Exact Seat Covers - Kenwood DVD & Alpine Speakers.
    Just to clarify on above tricks and tips...
    Floss/fishing line: used to saw back and forth behind badges that are double sided stickied on such as the "Tacoma" on the door and tailgate badging. Take care when prying pulling badges that you aren't digging the corner of the badge into your paint. After the badge is off you will be left with foam stuck to the paint. I was able to use a hair dryer to warm it up and used my thumb/fingers to rub it off. After the foam is rubbed off you can use as noted above(I used wd-40) to remove the residue. Then clean off the wd-40 with some alcohol. Finish with a wax of your liking.
    For Stickers: with a new vehicle you can probably just pick up an edge with your finger nail but may need a plastic razor blade (NOT metal!!!) to get it started and it helps if its warm (hairdryer again) then just peel it off. Use method stated above for removing sticker residue and your de-baged/de-stickered :thumbsup:
    rklimetz[OP] and Kevin8se7en like this.
  7. Feb 5, 2020 at 4:38 PM
    SuperTacoma
    SuperTacoma Well-Known Member
    Clint
    Georgia
    2019 Double Cab SR5 4x4 Silver
    I used a heat gun (can use a hairdryer) to heat it up, not too much. Then use dental floss or a slow gentle pull once you get it started. Used this technique several times.
    Tacompa likes this.
  8. Feb 5, 2020 at 4:50 PM
    gator2764
    gator2764 Well-Known Member
    Mid Ga
    2016 TRD DCLB 4X
    This!
  9. Feb 5, 2020 at 4:52 PM
    BFFR
    BFFR Well-Known Member
    Brandon
    2019 TRD Offroad
    I'll jump in on the fishing line suggestion. You can use a hair dryer to soften it up before hand if you need to. I don't necessarily remove the emblems but the dealer sticker is always the first thing to go for me. No free advertising lol
    VUIguy likes this.
  10. Feb 5, 2020 at 5:05 PM
    Jlp468
    Jlp468 Well-Known Member
    I did this but opposite. Used fishing line to peel off, then used heat gun to get residue off.
    SuperTacoma[QUOTED] likes this.
  11. Feb 5, 2020 at 5:27 PM
    rklimetz
    Rachel
    Awesome, thanks so much for the tips!
  12. Feb 5, 2020 at 5:50 PM
    HeritageTRD
    Washington
    Should also mention....where are pics of this new truck!!! :D
  13. Feb 5, 2020 at 5:54 PM
    Tacompa
    Tacompa Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    I used the hair dryer to warm up the badges and then Glide dental floss (its like teflon tape) in a sawing motion to remove them. I dabbed some goo gone on the residue and let it soak while I remove the next badge. The sawing motion may take some time because the floss will likely break a few times. Then I just rubbed the residue with my fingers and it came off. It's a lot easier when the truck is new. For the stickers, I used my finger nail to peel up a corner and then the hair dryer to warm up the adhesive as I slowly peeled it off.
    It is actually really easy, just take your time.
  14. Feb 5, 2020 at 6:00 PM
    StayinStock
    StayinStock The Artist Formerly Known As Stock
    Bob
    Missouri
    Yes I do
    Some
    Welcome to TW!
  15. Feb 5, 2020 at 6:18 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    All of my emblems are aftermarket. For the larger emblems, I would recommend heating the surface and using fishing line to separate the emblem from the paint. After that, try to peel as much of the adhesive off with your fingers while keeping the surface hot and wet. Then degrease and or googone it then get a rag and work all the residue off. After that’s done, clean the area so there is no noticeable changes in the paint because dust tends to bring out the old shape of the emblem lol.
    My aftermarket door emblem is the TRD pro style emblem except it says TRD Sport.
  16. Feb 6, 2020 at 10:41 AM
    SuperTacoma
    Clint
    Georgia
    One other note, the newer the vehicle the easier it is to remove the badges.
    VUIguy likes this.
  17. Feb 6, 2020 at 11:44 AM
    VUIguy
    VUIguy Well-Known Member
    2019 TRD Off-Road 4x4
    Took the dealer stickers off the first day with GooGone. Patience Grasshopper.
    If you are a rebel gasoline will do the trick just be sure to have a soapy rag nearby to clean it off ASAP. Also removes tint film.
  18. Feb 6, 2020 at 11:45 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    rubber wheel
  19. Feb 6, 2020 at 11:51 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    I used a hair dryer and dental floss. There was a little double sided tape left behind, I just rolled it off using my thumb. Then I used goo-gone to remove the glue residue. Wiped and washed it. After it dried, I applied a coat of wax.
  20. Mar 3, 2020 at 10:36 AM
    Stxxx
    Stxxx Well-Known Member
    2009 Tacoma TRD
    Fishing line and goo gone worked for me too, thanks TW! Been lurking for a while but just registered to say Ive got a chrome V6 and SR5 badge for free to whoever actually wants 'em.
