Removing automatic transmission pan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fla_sun, Oct 25, 2015.
  1. Oct 25, 2015 at 4:30 PM
    fla_sun
    fla_sun [OP] Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Getting ready to remove the automatic transmission pan on my 2006 Tacoma 4X4. I understand this pan has RTV or some kind of sealant. Rubber mallet or scraper?
    Anyone have any tricks that would come in handy?
    Thanks...
  2. Oct 25, 2015 at 7:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do not pry hard on the edge of the pan. It could deform it enough to cause a leak. Toyota uses FIPG or Form In Place Gasket, black or orange depending on the application.
    I use a couple ( 2 or 3 ) plastic scrapers from the hardware store and insert them in diametrically opposing positions and wedge the pan loose slowly. The plastic will not scratch and is less likely to deform the pan edges.
    Clean the mating surfaces well and make sure they are free of oil and debris before you reapply the new FIPG and install the pan. Use a torque wrench to reinstall the bolts into the pan and tighten them down in a cross pattern in increments until you reach full torque. Then go around the pan ( not in a cross pattern ) and torque to the final value again. Remember aluminum is soft, do not over torque the bolts.
    The 65 inch pounds is for the A340E Transmission.
    The 750E transmission pan torque is 39 inch pounds.
    Sorry for the confusion.
  3. Oct 26, 2015 at 5:56 AM
    fla_sun
    Thanks for the great info Jimmyh.
    I planned to use a Fel-Pro gasket with RTV. Sounds like that would not be needed.
    I was wondering if a rubber mallet might be needed to break loose. Guess I'll figure it out.
    Where I'm staying I will have a 2 hour window to use a covered space and no backup vehicle to run to the parts store if I forget something. Got to get it right the first time.
  4. Oct 26, 2015 at 9:48 AM
    fla_sun
    I just checked and the tranny pan has a gasket and no visible sealant. Maybe worried about nothing. I'll have a couple plastic scrapers just in case. Thanks again!
  5. Oct 26, 2015 at 10:18 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    my 2013 is just a gasket
    fla_sun[OP] likes this.
  6. Oct 26, 2015 at 7:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I always use a sealer even with a gasket.
    I just ran through the FSM again and I misread the torque value it should be 39 inch pounds and NOT what I said above.
  7. Oct 26, 2015 at 8:47 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    I use a little sealant at the corners of the gasket to align the pan and gasket holes so I can start some screws without the gasket falling off and starting over.
  8. Oct 28, 2015 at 4:21 AM
    fla_sun
    From Fel Pro Q&A:
    "No RTV or any other sealers, ATF, or anything else should be applied to the (TOS 18736) gasket. Make sure the transmission and the pan are clean and dry. And yes, the bolt holes in the gasket are just slightly undersized, so the pan bolts will hold the gasket in place.
    We hope this helps!"
    I think I will try it this way.
    Update: Pan came off easy, cleaned the pan, magnets and filter. Pan went back on easy. Thanks all for the help with specs.
  9. Jan 19, 2016 at 8:23 AM
    ENGINE326
    ENGINE326 New Member
    Long Island, NY
    2012 DC LB Sport
    I'll be changing my transmission oil pan tomorrow. How was it taking off the 20 surrounding pan bolts?
    Also... I plan on swapping the magnets from the old pan to the new pan. how are the magnets seated in the old pan?
  10. Jan 19, 2016 at 3:42 PM
    fla_sun
    The bolts on mine came out very easily. The three magnets each have a spot on the pan. Just look at the old pan and place them in the same spot after cleaning.
    I did spray the bolts the day before with PB Blaster.
    Atlas86 likes this.
  11. Jan 20, 2016 at 1:10 PM
    ENGINE326
    Long Island, NY
    2012 DC LB Sport
    I didn't get to change my transmission oil pan today. I plan on getting to it tomorrow.
    I'm changing the pan due to the drain plug being cross threaded and stripped out by the previous owner attempting an oil change. I'm choosing to replace the whole pan and gasket with original Toyota parts as opposed to drilling the plug out and retapping.
    With the drain plug cross threaded I cannot drain the pan before I remove it, i believe the next logical step is to drain as much as I can through the check valve under "room temperature conditions."
  12. Jan 20, 2016 at 1:16 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yeah don't use sealant together with Fel Pro gaskets - it will just cause the gasket to get stuck on the transmission case, creating a mess the next time you remove the pan... if there is a next time.
  13. Jan 20, 2016 at 2:16 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Since you are replacing the pan, use an awl and a hammer near one of the corners to drain the fluid. Do make sure your new pan is correct before punching the hole, since it somewhat irreversible. ;)
    Jimmyh likes this.
  14. Jan 20, 2016 at 4:21 PM
    KenLyns
    Belly of the Beast
    ^JB Weld isn't THAT hard to use. :laugh:
  15. Jan 20, 2016 at 4:36 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    A MIG welder is easier. :welder:
  16. Sep 5, 2018 at 12:17 PM
    Newbie62
    Newbie62 Member
    Rusty
    1999 Toyota Tacoma Prerunner
    So is FPIG a gasket replacement or do you put it on both sides of the rubber gasket?
  17. Sep 5, 2018 at 12:46 PM
    fla_sun
    Do not use FIPG with a gasket. Use FIPG by itself.
    Just using the gasket alone for this application makes a good tight seal and takes much less time than FIPG.
    R0dzilla75 likes this.
  18. Sep 5, 2018 at 7:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    FIPG
    Form
    In
    Place
    Gasket
    It is used in the place of a pre-cut / formed gasket.
  19. Sep 5, 2018 at 8:34 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    When I purchased my new transmission filter it came with a new gasket for the pan. I Just used the gasket only. Had zero issues.
    Benny123 likes this.
  20. Feb 27, 2020 at 9:27 AM
    Srdjan_c
    Srdjan_c New Member
    Srdjan
    2016 Toyota Tacoma TRD sport
    the same thing happened with me with the drain plug being cross threaded. I was wondering if you remember how it went when you removed the pan? Did it all spill out? And how much ATF fluid did you have to put back in? And how did you verify the level? Sorry for all the questions, would really appreciate your input though!
