Removing AC compressor on 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, May 7, 2021.
  1. May 7, 2021 at 4:47 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    To remove the AC compressor does the fan shroud and power steering both have to be removed?
  2. May 7, 2021 at 5:05 PM
    BallsyMcGee
    BallsyMcGee Plumber Extraordinaire
    Las Vegas
    1996 Tacoma SR5
    Its will to live just to spite father time himself
    turbodb and 1997tacomav6[OP] like this.
  3. May 7, 2021 at 5:11 PM
    1997tacomav6
    Denver
  4. May 7, 2021 at 5:18 PM
    BallsyMcGee
    Las Vegas
    1996 Tacoma SR5
    Good luck!
  5. May 7, 2021 at 5:18 PM
    1997tacomav6
    Denver
    I was going to replace the compressor and then have an AC guy charge it,
    The company that sold me the compressor said it shipped with 4 ounce of oil.
    I don’t know If I should add more or just install it and hopefully the AC guy knows what to do?.
  6. May 7, 2021 at 5:21 PM
    BallsyMcGee
    Las Vegas
    1996 Tacoma SR5
    I would add oil, but first dump out the stock oil as that guide says
    1997tacomav6[OP] likes this.
  7. May 7, 2021 at 5:27 PM
    1997tacomav6
    Denver
    Do you have to disconnect the power steering hoses?
    Can’t the just disconnect the whole power steering pump from the bracket and push it out of the way?
  8. May 7, 2021 at 5:50 PM
    BallsyMcGee
    Las Vegas
    1996 Tacoma SR5
    I took mine out because it got too cumbersome and crowded
  9. May 8, 2021 at 7:13 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I extract the compressor out the bottom, with a bit of towards the front action. Only the frame clamps for the PS lines need to come off so the lines can move out of the way. The PS pump is not touched or any lines opened.
  10. May 8, 2021 at 7:41 AM
    1997tacomav6
    Denver
    Really?
    That sounds a lot easier
  11. May 8, 2021 at 9:16 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yep, it's a juggling act for sure. Remember the compressor oil as you tilt, rotate and finagle the thing in and out to avoid embarrassment (spill). Getting the comp in place dry then adding the oil will keep it off your arms. Plugging the ports will also prevent spills but the chance of dislodging them would be high. Think about that as you go thru the removal process and make the call.
    If you want a challenge, the comp can go in/out without tilting enough to spill.
  12. Jun 12, 2021 at 5:35 PM
    crackedmirror
    crackedmirror Well-Known Member
    Is the oil in the compressor connected to the oil in the engine?
  13. Jun 12, 2021 at 6:58 PM
    1997tacomav6
    Denver
    Absolutely NOT,
    The AC compressor oil is mixed in with the Freon when charged.
    It’s a different amount for every car,
    Tacoma is around 7 ozs or something like that,
    Some new compressors come with oil some don’t.
  14. Jun 12, 2021 at 7:26 PM
    crackedmirror
    Just so I know NOT to do it, what's the way to evacuate the refrigerant using basic hand tools at home?
  15. Jun 12, 2021 at 7:27 PM
    1997tacomav6
    Denver
    Have a shop do it, most will do it for free because they recycle the old Freon
  16. Jun 12, 2021 at 11:03 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    As far as I know there is no way to evacuate/pull down an A/C system without an ac machine unless ya just don’t care about yourself or the environment. As 1997tacomav6 said have a shop do it.
    Back in the day, early 80s when I was learning the trade some of the techs would hang out in the back of the shop and drink beer before going home. Ya, it was a different world back then. Anyway there was one old guy that would tap a 12 oz can of R12 Freon and spray it on a 6 pack to cool it every evening. A 12 oz can was about 4 bucks then. Every day for the 5 or so years I knew him he would stand in a cloud of R12 every evening until one day he keeled over dead in his stall from a heart attack. That stuck with me, who knows if it was the r12 that did it but I’m sure it didn’t help.
