Removed haze with PlastX. What to use to seal/UV protect?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dennisi01, Sep 15, 2019.
  1. Sep 15, 2019 at 5:40 PM
    Dennisi01
    Dennisi01 [OP] Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Hey all, just used Meguiars PlastX on my hazy headlights with great results for 10 minutes of work. My question is what is an inexpensive sealant/UV protective coating to use to stop them from immediately hazing up again?
    Black DOG Lila likes this.
  2. Sep 15, 2019 at 6:27 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Keep them waxed
    Or have a body shop clear coat them
  3. Sep 15, 2019 at 6:46 PM
    TacoTuesday1
    FL
    a small bottle of Plast-X came in my Meguiar's Heavy Duty headlight restoration kit, around $20 from Wal-Mart.
    As well as round sanding pads (1000 and 3000 grit I think) that it said to use wet, and then a final protectant coating. Which I guess you don't have.
    Good thing is the kid comes with that. Potentially bad thing is I don't know how good it is, and if it only lasts a year.
    I kept what's left over in the kit for future use on the tail lights, and for if I need more in the future.
    But I hear certain 3M polishes are better.
    As for other protectants on the market that can be sourced separately, I don't know what they are, their quality, or their cost. I'd research it.
    I have heard Opti-Lens is good but I never tried it, and it's expensive.
    What I found tricky with the protestant included in the Meguiar's kit is that it goes onto their foam applicator pad really thin/drippy, might dry it out, and is runny so it's a challenge to avoid getting it on paint surrounding the headlight.
    I don't know if something else like Opti-Lens might be easier to apply.
    Some people say wax them but I don't know if that protects against UV.
    I've even seen tail lights ceramic coated; I have no idea why a person would do that. Ceramic coatings are typically used to protect paint from things like door dings. But if someone smacks a plastic tail light instead of a metal door, it will just crack, maybe regardless of what it's coated with. Because the material itself underneath is just plastic.
  4. Sep 15, 2019 at 7:05 PM
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    I did a 3 step wet sand (1,000 / 2,500 / 4,000) using my hand drill and then finished my headlights with my Porter Cable using Meguiars M105 and M205.
    Once I finished sanding/buffing, I sealed them with 1:1 ratio mix of Mineral Spirits and Spar Urethane (rubbed on). It's been almost a year and a half and they still look like new. Many people have had a lot of success with this type of sealer.
    I plan on re-applying the clearcoat after winter just to freshen them up.
  5. Sep 16, 2019 at 2:01 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Meguiars Headlight Coating sold separately at some auto stores or Walmart in 4 oz spray bottle and says good for 1 year. Two coats required on 1st use.
    R0dzilla75 likes this.
  6. Sep 16, 2019 at 4:07 AM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    303 Aerospace
  7. Sep 16, 2019 at 4:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    McKee 37 Headlight Protectant
  8. Sep 16, 2019 at 9:05 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Guys thank you for all of your responses! A lot of different opinions on this one, lol!
  9. Sep 16, 2019 at 9:13 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Was looking at this. Have you used it with long term success? No adverse reactions etc.?
  10. Sep 16, 2019 at 9:20 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    That's really interesting - haven't heard of that technique. What did you use to apply it? Did it dry smooth?
  11. Sep 16, 2019 at 9:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    My '13 looks fresh and has never been garaged in it's 7 years of life.
    I will say I'm preserving the original, not resealing a sanded off unit.
  12. Sep 16, 2019 at 10:02 AM
    Rujack
    Perfect. My lights are still in good original condition. Thanks.
  13. Sep 16, 2019 at 10:13 AM
    Rujack
    @Clearwater Bill
    Is this the product you use:
    McKee's 37 MK37-130 Headlight Protectant Spray 8 Fluid_Ounces https://www.amazon.com/dp/B01IB15TZ0/ref=cm_sw_r_cp_api_i_5i8FDbVC1EQE3
    or is it this one:
    McKee's 37 MK37-121 All In One Headlight Restoring Polish 8 Fluid_Ounces https://www.amazon.com/dp/B01LXZVSY9/ref=cm_sw_r_cp_api_i_Gj8FDbSDR2829
    or this one:
    McKee's 37 MK37-270 Headlight Coating, 4 fl. oz https://www.amazon.com/dp/B07BZV29DM/ref=cm_sw_r_cp_api_i_4j8FDbJFJKD7Y
    I do realize that the first one specifically says “protectant”, just want to be certain...
  14. Sep 16, 2019 at 11:00 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    This may have some pointers for you.
    -J
  15. Sep 16, 2019 at 11:21 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    When I restored the headlights on my '96 Thunderbird, I clearcoated them with a UV-blocking paint made for the sign making industry. It was from a company called Sign Painters' 1-shot. They looked crystal clear for five years, and then I got rid of the car.
    Remember that most of the yellowing and hazing is caused by exposure to UV light from the sun, so you need something that will block it.
  16. Sep 16, 2019 at 2:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Rujack[QUOTED] likes this.
  17. Sep 16, 2019 at 3:02 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Coppertone ultra UV, Dont laugh it works. I put Coppertone original on my boats vinyl seat cushions after noticing a shiny clean butt print a year after I sat my Coppertone coated butt there. I started putting it on the white rubber fenders too and they stay looking new.
  18. Sep 16, 2019 at 3:36 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    The Spar stuff failed miserably for me. I can't imagine a worse product. Not sure if the sun was just too crazy out here in CA or what but it quickly turned yellow and then began to crack and chip/peel off the lens.
    IMO the best solution for faded headlights is to sand them to remove any previous coating or imperfections, clear coat with a 2 part, automotive grade clear coat and then keep them waxed or treated with another UV type protectant.
  19. Sep 16, 2019 at 3:38 PM
    clenkeit
    Colin
    Lakewood, CA
    BTW, a great way to shoot clear coat, or other automotive paint, on your own in small batches for stuff like this is to use Preval system. https://preval.com/
    Basically bridges the gap between 2K rattle can and having to take the parts to a body shop.
  20. Sep 16, 2019 at 4:47 PM
    cookiedough
    cookiedough Well-Known Member
    Phx, Arizona
    02 DCSB OR, 19 DCSB OR
    '02 - No mods. '19 Blue Friday - GFC, RXT S1, Bilsteins
    TLDR; 2 sets headlights, good experience with Sylvania kit on both.
    I tried the Mother's kit on my daughter's Civic. Worked ok, 1 year later, they were hazed and yellowed again. I debated between Mother's and the Sylvania (didn't know about Mckee's). Picked up the Sylvania, has the sandpaper, has the sealant. Still good 2 years later. After the Civic experience (which was my test case for my '02 Tacoma) I used the Sylvania on it as well. Still clear, 1 year down the road on the Tacoma and 3 years on the Civic.
