Remove steering lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HNGNON, Apr 29, 2010.
  1. Apr 29, 2010 at 1:16 PM
    HNGNON
    HNGNON [OP] New Member
    New Orleans
    10 Sport
    How do you disable or remove pin from steering lock. I want to tow a 2010 Tacoma (with driveshaft disconnect), but can't lock doors or remove key from ignition. Thanks for your help.
  2. Apr 29, 2010 at 3:17 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Maybe the manual says something about towing...?
  3. Apr 29, 2010 at 3:29 PM
    ASE_MasterTech
    ASE_MasterTech Well-Known Member
    Monmouth County, NJ
    2010 TRD Sport DBL\Cab
    Wet Okole seat covers, Westin Platinum Oval tube steps, Rear spring TSB plus Super Springs, D-Rings in all bed bolts, Tailgate reinforcement mod (for loading Harley)
    I wouldn't 'flat tow' a Tacoma..
    At the very least, I would get a dolly for the front wheels..
    This Vehicle is not recommended for 'Flat' or 'Dingy' towing methods..
  4. Apr 30, 2010 at 5:45 AM
    HNGNON
    New Orleans
    10 Sport
    Thanks, but I towed my previous Tacoma with no problems. I install a drive shaft disconnect which lets the truck free-wheel without turning the transmission. If I were to dolly-tow the truck I would put the rear wheels on the trailer, again so the transmission doesn't turn.
    The way the Tacoma is wired you cannot turn off the key without locking the steering wheel and the doors won't lock with the key in the ignition. So you go down the road with the key in the Acc position (to free the front wheels to turn) and the doors unlocked.
  5. Jan 13, 2018 at 6:59 PM
    KixRock
    KixRock Member
    Kix
    2009 Tacoma Double cab V6
    I too am rigging my Tacoma for flat towing and would also appreciate an answer the HNGNON's steering wheel lock question.
    Driveshaft disco being installed too. My Taco is '09 RWD, AT, Pre Runner, SR5 6 cyl..
