Remove Smell of Smoke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SubFrozen, May 9, 2011.
  1. May 9, 2011 at 2:06 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    Hey guys--
    I went through a 6-month period where I was smoking Cloves and friends were smoking Cigs. After ending up in the E.R. and almost losing my job due to medical issues, I quit. Now, I'm suffering the reminder each time I step into my Tacoma.
    I have your typical Taco interior. What's the easiest way to clean it? Should I rip it out and have leather installed? Can I buy pre-cut replacement material for the entire vehicle? Thoughts, ideas?
    Also, how can I clean out all of my vents?
    Thanks
    -Will
  2. May 9, 2011 at 2:11 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    From what I know is I would wash ALL the carpets and maybe change the cabin air filter. Also good choice :thumbsup: quitting
  3. May 9, 2011 at 2:15 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Clean everything first obviously, then get an Ozone treatment.
    Find a detail shop that does them. It should run you about $50-100 depending on where you go.
  4. May 9, 2011 at 2:15 PM
    toojayz
    toojayz Well-Known Member
    Jim
    Northern NJ
    2011 TRD Sport 4x4 DC MGM SB
    I used to detail cars years ago and one of the tricks we used was white vinegar. We had it in a spray bottle and sprayed the rugs seats and let the car air itself out and really helped to dissipate the smell of cigarette/cigar smoke. White vinegar (DO NOT USE ANYTHING BUT WHITE AS IT WILL STAIN) won't harm anything. Good luck
  5. May 9, 2011 at 2:16 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Take the seats out and steam clean them, steam clean the carpet still in the truck.
    Also, leave all your windows down for an extended peroid, say 6 hours or so. After a bit of time the smell will fade. I used to smoke a pack a day and most of my friends are smokers, can't tell my trucks ever been smoked in.
  6. May 9, 2011 at 2:18 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    I'll grab some white vin. and go to town. Un-bolt everything, pull it out, and maybe do a few DIY items while I'm at it such as a USB port in the middle console and lights under the dash.
    Is there a quick way to clean out all of the vent tubes?
    I was at a pack a day of cloves, 2 packs a day of american spirits. I feel better already.
  7. May 9, 2011 at 2:23 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    does homertaco still have his seat cloth? might be an option if so....
  8. May 9, 2011 at 3:58 PM
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    I will second that White Vinegar suggestion. I used to detail cars as well, but did not learn of this trick until I bought my Tacoma. The car lot did a good job of disguising the smell, but it came back...bad. Then I did the White vinegar wipe down of everything ESPECIALLY the plastic and leather, and it has smelled great ever since. Granted, it smelled like a pickle for the first couple of days, but that quickly went away.
    White Vinegar....the answer for sure.
  9. May 9, 2011 at 4:05 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Definitely shampoo everything.
    I have an Auto Air Ionizer in my vehicles, it plugs into the cig lighter or whatever. It actually works and even though I am a smoker, my vehicles don't smell like it. You can find several different styles on Amazon, etc.
  10. May 9, 2011 at 4:07 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I doubt that any smoke smell is coming from your vents.I wouldn't worry too much about that.
  11. May 9, 2011 at 4:09 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Smoke ash gets in everywhere... you will find it coated to everything under the dash and everywhere. you have to clean everything extensively to get rid of smoke smell. Its very difficult to do.
  12. May 9, 2011 at 4:14 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    Biggest deal I've ever done is get a vent cleaner spray from an autoparts store and spray it in the return air and let it run for awhile and your car will smell way better other then that just a lot of scrubing!
  13. May 9, 2011 at 4:21 PM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    Hey bud, I helped my buddy clear out his cig smells and I basically got all of the smell out in one clean.
    Here is what you need to do
    1) Shampoo/Clean all the floor carpet
    2) Replace your cabin air filter
    3) If possible, park your car in a garage for a night or two with all windows open
    4) Vacuum out every square inch of your rig, seats, compartments, floor, etc.
    5) Find some carpet or fiber spray and wipe cleaner for your seats- this really helps!
    Let me know how it goes?!
  14. May 9, 2011 at 5:15 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    A great mod for any truck that gets real dirty inside is to remove all the carpet and bedliner the inner floor. If you had the seats steam cleaned, and did this mod (install a drain plug as well..you never know!) you'd be set I think.
  15. May 9, 2011 at 6:25 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    RZ Rob
  16. May 9, 2011 at 7:05 PM
    joes06tacoma
    Joe
    Central Coast, CA
    What worked for me on several company trucks as well as the Tacoma I have now was "Ozium" spray from the auto parts store. Spray every time you leave the truck with the windows up. Takes care of the smell in a couple weeks.
    Also seemed to speed things up on the Taco when I changed the cabin filter. The interior had been steam cleaned right when I got it, but the smell was still there. The Ozium did the trick. My company trucks were never even wiped down, just the Ozium.
  17. May 9, 2011 at 7:24 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Along with the long list above,I would recommend using TSP and cleaning inside the vent ducting the best you can. TSP is good for removing nicotine residue off. I use to work section 8 housing in Utah and the guy I worked for had bought one of the old Motels up their that had block walls painted white. We would have people move out after 10 yrs or so who smoked and we would go in and coat the walls with TSP and all the yellow nicotine would come off. It worth a try. Good luck! TSP can be found at Lowe's or Home Depot in the paint section.
    Quote:
    Mormon Girl: I just don't understand how sperm knows to make it across the sheets, or where to go from there! :laughing:.....yea,you are living in UT.
  18. May 10, 2011 at 1:33 AM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    My buddy bought a used 06 Taco from a dealership. Original owner was a smoker and the dealership tried their best to clean the interior and spray crap to hide the smell. The only thing that has worked for him was to swap out the cabin filter and run my commercial ozonator (http://shop.toolsforhealing.com/KleenAir_2500_Commercial_p/aso-2500.htm) in the truck with the windows up and the air circulating and then with the A/C on. He ran his truck in his driveway (idle) for about a hour while we were out drinking some beers. He did this a couple of times and now there is no smoke smell.
  19. May 10, 2011 at 6:22 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Don't forget to clean the headliner. It absorbs a bunch of smoke.
    Benny123 likes this.
  20. May 10, 2011 at 6:26 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    White vinegar does work. Use febreeze as well in large quantities, over a period of time (like spray the crap out of the interior every time you leave the truck).
    I smoke in my truck on a daily basis and it doesn't smell like smoke, because of the febreeze. (I know I can't smell but my friends who don't smoke can't smell it at all).
