Remove oem Door edge guards
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dallasrey, Apr 19, 2022.
  1. Apr 19, 2022 at 8:11 AM
    dallasrey
    dallasrey [OP] Well-Known Member
    Dallas
    17 MGM TRD OR 6MT Waiting on 22 Lunar TRD OR 6MT
    Have a new truck coming in and sadly it has the port installed door edge guards. These are the clip on ones, not the clear tape. I want to remove these safely. Videos online show these gently tapped on with a mallet so they are friction fit, not adhesive. Has anyone removed these? How easy is it? Was there any chipping or marring of the paint? Appreciate any insight.
  2. Apr 19, 2022 at 8:41 AM
    Trail Limo
    Trail Limo Well-Known Member
    No personal experience with this type of guard, but as a general rule, if it's a friction fit that needed to be pounded on there is a high probability it damaged the paint underneath.
  3. Apr 19, 2022 at 8:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have a personal dislike for them as it implies that I might be a door dinger.
    The clip on type usually have a glue strip in the bottom of the U. On a warmer day, they should be soft enough to peel off if you start at the end.
    Even the best automotive adhesive (3M VHB) will peel off without damage. Some cleanup might be needed.
    dallasrey[QUOTED][OP] likes this.
  4. Apr 19, 2022 at 12:27 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I installed my oem edge guards and they really go on quite easily. The reason you use a mallet is if the sticky adhesive tape grabs the door before the edge is fully seated. The mallet makes sure its pushed all the way onto the edge. So its more the adhesive than the crimping holding it on. Id carefully use a heat gun and start removing from a rear door first. That way you can get a feel of how its going to come up. You shouldn’t have scratched paint although Im sure you may have leftover adhesive to remove after.
    Big tall dave likes this.
  5. Apr 19, 2022 at 12:31 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I always go with a hair dryer over a heat gun because I feel like there's more room for error with a hair dryer. I don't use heat guns very often though.
  6. Apr 28, 2022 at 12:50 PM
    mykrowyre
    mykrowyre Well-Known Member
    Tom
    I did find an actual Toyota video on youtube showing how the techs are supposed to remove them.
    I'll probably remove mine too. Too me they look kinda like suspenders with shorts.
  7. Apr 28, 2022 at 12:54 PM
    dallasrey
    Dallas
    Oh really? Could you please post the link? I’ve seen a few people say they just pop off but I’m terrified of chipping the paint while doing this. Was thinking of maybe soaking the area in cash wash soap to help lube the area.
  8. Apr 28, 2022 at 1:12 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    I removed mine without chipping the paint.
    Not much to it just pull.
  9. Apr 28, 2022 at 1:31 PM
    dallasrey
    Dallas
    Awesome good to know thank you
    Siblue[QUOTED] likes this.
  10. Apr 28, 2022 at 1:38 PM
    mykrowyre
    Tom
    Actually after watching the video I'm not even going to link it. They are pounding it off with a plastic scraper and a mallet!
    Warming it up (even in the hot sun) and peeling it off is better.
  11. Apr 28, 2022 at 2:07 PM
    Siblue
    So Cal
    25 Tundra TRD pro
    I wouldn’t use any tools
