Removal of Tow Package Hitch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, Mar 21, 2017.
  1. Mar 21, 2017 at 1:50 PM
    Jibbs
    Jibbs [OP] "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Hey Guys
    Went wheeling this last weekend and broke off the corner of my rear bumper because reasons including but not limited to me being an idiot. Looking at aftermarket rear bumpers now (side note: any suggestions for nice 3g bumpers here would rule). Some of the ones I'm enjoying have the hidden receiver under the license plate, and those dont play nice with the factory receiver.
    I haven't actually crawled under the truck and looked, but is the Tow Package receiver assembly welded to the frame or is it bolt on? Knowing if I can remove it without having to cut metal will drive my purchasing decision.
    Side note, has anyone actually towed anything with the receiver built into things like the Pelfreybilt bumpers? They are all 'not rated for towing'. At most I'd probably end up using them for a small trailer with a motorcycle on it so I assume they'd be solid.
  2. Mar 21, 2017 at 1:52 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Bolt on
    Jibbs[OP] likes this.
  3. Mar 21, 2017 at 1:54 PM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Awesome thanks!
    dYL0n[QUOTED] likes this.
  4. Mar 21, 2017 at 1:58 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Just get you an SOS Concepts or Pelfry with the hidden hitch. Avoid the ones where you "add" the hitch, especially the ones that go under. You can haul just as much as the factory hitch, no problem. It's simple to switch everything over
  5. Mar 22, 2017 at 8:16 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    There's many rear plate bumpers that keep the hitch in the stock location. Why would you want to remove the hitch?? Just get a bumper you don't have to mess with the hitch.... wait till you take off the OEM bumper (lots o plastic). A new plate bumper is a no brainer.... seriously.
  6. Mar 22, 2017 at 8:21 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    I became intimately familiar with how much of that bumper is plastic. I was considering just taking off the hitch for clearance. It dragged ALOT wheeling last weekend I'm also considering relocating the spare tire to the rear
    https://goo.gl/photos/V1LeMELjgGUsoUnf8
    TacoRD16 likes this.
  7. Mar 22, 2017 at 8:27 AM
    erok81
    erok81 Well-Known Member
    Imposter
    I've thought of that too. But then I realized instead of scraping a solid piece of steel, I'd be scraping/slamming the plastic bumper instead. So mine is still on.
  8. Mar 22, 2017 at 8:33 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Sorry, to be clear, youre saying you thought about removing the hitch but didn't because then you thought you'd hit the bumper?
    If I remove my hitch at all, it will be in the same day that I install a new plate bumper, so I figure it should be fine.
  9. Mar 22, 2017 at 8:59 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Really? Why not go look. It's pretty easy.
    Hobbs likes this.
  10. Mar 22, 2017 at 9:30 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Clearance / departure angle for one.
    bobrown14[QUOTED] likes this.
  11. Mar 22, 2017 at 9:31 AM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Removing the OEM hitch nets you an easy two-three inches of extra clearance back there.
    Definitely getting rid of mine (in favour of integrated hitch) when I get a rear bumper this summer
  12. Mar 22, 2017 at 10:13 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Was at work. Do you have any information to contribute?
  13. Mar 22, 2017 at 10:18 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I just leave the ball bracket in when I head to the hunting ranch. I have a couple of creek crossing and just the ball nut and stud will scrape.
  14. Mar 22, 2017 at 10:20 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Simmer down.
    bobrown14 likes this.
  15. Mar 22, 2017 at 10:22 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Not simmered? There's other questions in this post and I would *love* to assume that guy didn't really just make an asinine comment for no reason
  16. Mar 22, 2017 at 10:37 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    so what caused the problem,, the hitch itself, or the receiver ? if it was the hitch, turn it upsidedown when off road..
  17. Mar 22, 2017 at 10:45 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    It wasn't really a 'problem' (read: I never got stuck because of the receiver), just that when I was hosing off the undercarriage of the truck I noticed that a crap ton of mud was caked all around the receiver and smashed up into the tow chain cutouts, etc. I also noticed it dragging on the ground in a few of the videos from behind me in spots where clearance came into question. Honestly, I'm fine with removing it, this question was more of a 'is it possible' thing, which I've now established it is. Planning on a streamlined rear plate bumper with the hidden receiver under the license plate for the extra clearance I'll probably never need.
  18. Mar 22, 2017 at 11:01 AM
    gottaToy
    JJ
    1985 Moped
    The factory hitch/bumper come off as one piece.
    A plate bumper will collect all kinds of crap, too.
    Getting a plate bumper that puts the hitch in factory location, kinda defeats the purposed of getting a plate bumper?
  19. Mar 22, 2017 at 11:05 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Right which is exactly why I was hopeful that my factory receiver wasn't somehow permanently affixed, because then I'd just have to replace a busted bumper without getting a cool new truck part
  20. Mar 22, 2017 at 11:58 AM
    Woodrow F Call
    Colorful Colorado
    The point was that is was an easy question to figure out for yourself as you obviously know where to look. Additionally, there are plenty of threads where people are installing their new bumpers. A thread maybe asking about potential upgraded bumpers might be a better topic..... then slip in your "How do I remove my receiver?" in there. I just thought the question was too easy to answer for yourself.... it came off as "I'm too lazy to figure this out on my own, so how do I x?"
    Sorry, I read the You probably don't know how to internet. Click here to level up! thread earlier and it rubbed off on me.
    bobrown14 and Exracer2 like this.
