Remote air chuck for ARB dual compressor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bonuscup, Aug 4, 2023.
  1. Aug 4, 2023 at 7:38 AM
    bonuscup
    bonuscup [OP] Well-Known Member
    Southern California
    2021 TRD OR DC LB XYZ
    I’ve done a bit of digging but haven’t seen any definitive examples, can someone who set up a remote air chuck in the front of the truck share how they did it?
    I have an ARB dual compressor that I’m planning to mount in on the passenger side under the hood and want to be lazy and not have to open the hood to air up tires. The switch will be in the cab.
    Looking around the front of the truck I don’t see a clear spot that I can mount a chuck to be able to attach a hose. I have a stock front bumper.
  2. Aug 4, 2023 at 6:50 PM
    JustaguySR5
    JustaguySR5 Active Member
    2021 SR5
    RCI rock sliders engine/trans/transfer case, differential and A-arm skids. ARB twin-compressor, rear air locker. Bilstein 6112/5160 with Icon RXT Leaf Packs. UpTop Overland Bedrack.
    Get some hose, fittings, nylon tape and possibly some pipe dope and route that bad boy to where you want it. It’s easy, just make sure all your connections are tight. I ended up needed to re-torque the hose clamp at my 90 degree fitting off the compressor after running the engine for awhile.
    bonuscup[OP] and Bishop84 like this.
  3. Aug 4, 2023 at 6:56 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    dude. thats sexxy
    JustaguySR5[QUOTED] likes this.
  4. Aug 4, 2023 at 10:33 PM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
  5. Aug 5, 2023 at 3:52 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Mine are not in the front, but this it might give you some ideas. With the remote chuck and tubing you really could put it anywhere. My thoughts on the location were that I wanted a chuck on each side, as centered on the truck as possible.
    I buy almost all my ARB parts and pieces from Nothridget4x4 great selection.
    https://youtu.be/dB0muc0XWX8
    Kefka, drizzoh and JustaguySR5 like this.
  6. Aug 5, 2023 at 9:47 PM
    bonuscup
    Southern California
    This just so good. Thanks for sharing.
    ClassyTacos[QUOTED] likes this.
  7. Aug 5, 2023 at 9:49 PM
    bonuscup
    Southern California
    This is awesome. How did you end up mounting the chuck to the front end?
  8. Aug 5, 2023 at 9:53 PM
    MGMDesertTaco
    Y'all are too fancy. Mines on a desertdoesit mount under the passenger seat. :notsure:
    ClassyTacos likes this.
  9. Aug 6, 2023 at 2:19 AM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    This is my solution
  10. Aug 6, 2023 at 7:57 AM
    JustaguySR5
    2021 SR5
    I had bought a compressor mount from R4T to place it behind the grill but found out I was missing some parts during the install. Long story short, instead of returning it, I left it in place and mounted the chuck to it. I just zip tied the hose to the mount as close to the chuck as possible to make it sturdy.
  11. Aug 6, 2023 at 9:11 AM
    overlimit
    overlimit Well-Known Member
    BC C, Eh! N, Eh! D, Eh!
    '21 DCSB TRD OR Premium.
    Here’s what I did with mine. I didn’t want to have to open the hood each time I needed air so I ran a chuck to both the front and rear of the truck. My choice of location might not work for those that like to bury their truck in the mud but they’re somewhat protected from splashes and spray. Two years later they’re still working great.
    The brackets I made were pretty simple, using just a drill, a grinder and some files this is what I came up with.
    Two suggestions from me… first one is to use DOT approved airbrake tubing. It has better kink, heat and abrasion resistance over the cheap stuff. The upgrade cost is only a few extra cents per foot. The fittings are your choice, just make sure they work with your airline.
    The second one I have is to use a braided stainless steel lead hose. This is because compressing air makes it hot and it can burst the plastic airline (more likely if you use the cheap stuff). I think the one I got is a Viair brand with a check valve in it, purchased from Amazon.
    Silverlogic and JustaguySR5 like this.
  12. Aug 6, 2023 at 6:38 PM
    Silverlogic
    Tyler
    Looks like the front would be difficult to access, how does it work out in reality?
  13. Aug 6, 2023 at 7:05 PM
    overlimit
    It’s easy enough that I’m able do it with one hand, but there’s not a lot of room to work with. I could’ve cut the plastic to make more room but I didn’t want to cut or drill into my truck.
  14. Aug 7, 2023 at 8:39 AM
    BlarBlarjosh
    BlarBlarjosh Well-Known Member
    Josh
    Southern California
    The engine bay air isn't too warm for the compressor without opening the hood?
  15. Aug 9, 2023 at 6:56 AM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Put mine in the plastic in case I didn’t like it. It hasn’t moved since, been 2 years?
  16. Aug 9, 2023 at 6:59 AM
    alwaysHI
    2017 MGM DCSB
    Nah.
    It’s not like I run tools for mine, but by the time I’m done airing up my 35s, I’m ready for the road, and that means airflow.
    Been about 2 years since my install and no complaints or issues here.
    Mine is installed by the power steering reservoir tho, not blocking the radiator like some other mounts. I also run a single
