Remco problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pinker, Jan 8, 2019.
  1. Jan 8, 2019 at 11:59 AM
    Pinker
    Pinker [OP] Member
    04 tacoma
    Can someone please tell me what this is? I have an 04 Tacoma double cab. I’ve had it 11 years and it’s been amazing. I purchased it with some mods but I haven’t the slightest idea what this is! Please help and thanks!
  2. Jan 8, 2019 at 12:02 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    what..the..hell...is...that thing, lol
    @BartMaster1234 @Speedytech7 @Empty_Lord
    BartMaster1234 and wilcam47 like this.
  3. Jan 8, 2019 at 12:03 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Oh shit! I finally know something for once.
    At least I think I do. Looks like a driveline disconnect for flat towing behind an RV.
    My stupid unnecessary knowledge for flat towing finally came in handy.
  4. Jan 8, 2019 at 12:03 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
  5. Jan 8, 2019 at 12:04 PM
    eon_blue
    Azusa, CA
    Ah, that makes sense...hadn't seen anything like that before.
    wilcam47 likes this.
  6. Jan 8, 2019 at 12:05 PM
    Pinker
    Pinker [OP] Member
    04 tacoma
    Holy cow that makes perfect sense! It does have that!
  7. Jan 8, 2019 at 12:05 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Makes it easier for flat towing so you don't have to unbolt the driveline. There should be a lever to engage it somewhere in the cab, theoretically.
  8. Jan 8, 2019 at 12:06 PM
    Speedytech7
    Also makes it way weaker, not that it really matters if it is just a daily driver
  9. Jan 8, 2019 at 12:06 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    It's a good idea to reserve words like "Help" in a thread title for folks that are broke down or stranded on the side of the road.
  10. Jan 8, 2019 at 12:06 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Do you have the flat tow mounting brackets on the front of the truck?
    That's an expensive setup. I looked at getting one for my 5-Lug, but it went upwards of $1,000.
  11. Jan 8, 2019 at 12:06 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Huh...that's pretty interesting.
    To add to the driveline disconnect does it go to a lever or something?
    Also, when people use the work "help" in a thread title it means they need help right away or urgently because harm by come to them if they don't get help immediately.
    Try using a different title that describes what you need assistance with.
  12. Jan 8, 2019 at 12:07 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    :bowdown: Whoa I’ve never seen anything like that!
  13. Jan 8, 2019 at 12:07 PM
    eon_blue
    Azusa, CA
    Pretty crazy looking contraption...I wonder how does it just disconnect the driveshaft with the pull of a lever, don't bolts need to be removed for that to happen? Or do they just stay removed and this device keeps it in place until the lever is pulled?
  14. Jan 8, 2019 at 12:08 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It's like a mechanical coupler IIRC. You move the lever, and it disengages the splined section of the driveshaft from the differential.
    You can tell the driveshaft has been shortened by a shop because of the aftermarket D/S weights on it. My shortened driveshaft has the same tubing and weights.
    eon_blue[QUOTED] likes this.
  15. Jan 8, 2019 at 12:09 PM
    Speedytech7
    It's almost exactly like the syncro in your tcase that actuate 4WD
  16. Jan 8, 2019 at 12:09 PM
    eon_blue
    Azusa, CA
    Gotcha. Pretty neat, looks like a liability on the trail though
  17. Jan 8, 2019 at 12:11 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Unbolting the driveshaft is 100x cheaper, and more reliable. This is merely for convenience for people who flat tow their vehicles a lot.
    wilcam47 and eon_blue[QUOTED] like this.
  18. Jan 8, 2019 at 12:11 PM
    Speedytech7
    Yeah on a driveshaft where the only bracing of the design is some stamped sheet metal and rivets it is a weak design that I wouldn't trust for a second. I'd be scared to leave a stop hard. The reason you can trust it in a transmission or transfer case is because it is braced by rigid cast pieces to keep everything from deflecting.
  19. Jan 8, 2019 at 12:30 PM
    Pinker
    Pinker [OP] Member
    04 tacoma
    Thank you everyone for your help and my apologies for the inappropriate thread title but I was so stuck! The truck does have a disconnect mount inside of the cab I’ll add a picture of that. It’s making an awful noise. does anyone see anything wrong with removing it and the cable? 7B9D1B9C-A6C2-41DD-9DAC-E6AAC9541A58.jpgAD31D2BA-5577-4C5F-B268-684DD55A3433.jpg 180C049F-4A8F-47B2-8B1C-87D1647B6E2B.jpg
  20. Jan 8, 2019 at 12:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I would remove it if you’re not using it, however it appears your driveshaft has been shortened to allow for the mechanism. Can you take more pictures of the driveshaft?
