Relocate OEM Camera
Discussion in 'Audio & Video' started by Unchained 5150, Nov 7, 2016.
  1. Nov 7, 2016 at 10:04 AM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Added a Hitchgate Solo to my truck as I am a Tester for Wilco OffRoad. Now the OEM Camera is blocked. I want to relocate it so I still have the camera abilities, so I know I have to take the Tailgate Skin off and pop it out of it's holder. But do they make an extension wire so I can make it longer and rewire it? Or I have a new Kenwood Head Unit and would just adding a new Kenwood Camera to the head Unit be a better idea? Thanks for any help you can offer.
    ChadsPride likes this.
  2. Nov 7, 2016 at 10:07 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Just here for the sphincters....
    Unchained 5150[OP] likes this.
  3. Nov 7, 2016 at 10:15 AM
    TacoPretzel89
    TacoPretzel89 Well-Known Member
    '07 Tacoma
  4. Nov 7, 2016 at 10:17 AM
    Unchained 5150
    Rick
    Auburn Ma
  5. Nov 7, 2016 at 10:33 AM
    TacoPretzel89
    '07 Tacoma
    I believe so? Just a longer wire that you can hook your camera to? Isn't that what you wanted? They make way cheaper cameras on Amazon for like 15$ that come with 14ft wires
  6. Nov 7, 2016 at 10:45 AM
    Unchained 5150
    Rick
    Auburn Ma
    Yeah I want to keep the OEM but just extend that might work thanks
  7. Nov 7, 2016 at 5:01 PM
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    The oem harness is fairly long. About 4 feet from the connector underneath to the camera in the handle.
    So depending on the location you want to move it, it may reach.
    Now the question is how will it be mounted? Maybe on another modified handle?
    If you still need to extend it, you can cut it and add waterproof connectors in the piece out wire.
  8. Nov 7, 2016 at 5:05 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  9. Nov 7, 2016 at 5:23 PM
    Unchained 5150
    Rick
    Auburn Ma
  10. Nov 7, 2016 at 5:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you sure? Maybe you could email them and they'd let you.
  11. Nov 7, 2016 at 5:26 PM
    Unchained 5150
    Rick
    Auburn Ma
    Sounds like a plan thanks again
  12. Nov 8, 2016 at 5:06 AM
    truckstuff
    truckstuff Active Member
    Bennett
    NE Tennessee
    2015 DCSB
    3" lift 33" Toyo RTs
    about to have the same issue...
  13. Nov 12, 2016 at 11:14 AM
    Captain Taco
    Captain Taco RipCity
    Rob
    Portland
    2013 Black Tacoma Sport
    3" Lift, Krank Fuel Wheels, TRD Pro Grill, Curved Roof LED Light Bar
    Did you end up buying the harness from Amazon? or are you going a different route? any idea where you are going to mount it too next?
    also! what are you going to do with the section where the camera used to be? to fill in the hole...
  14. Nov 12, 2016 at 2:31 PM
    Unchained 5150
    Rick
    Auburn Ma
    Might just leave that one in the OEM spot. And buy a different one to run to the Head Unit.
  15. Nov 12, 2016 at 3:32 PM
    Captain Taco
    Rob
    Portland
    Roger that! Not a bad idea.
    Is yours currently wired to the rearview mirror?
  16. Nov 12, 2016 at 3:38 PM
    Captain Taco
    Rob
    Portland
    Is there any place to connect it to on the actual hitchgate solo? Or would it get in the way when opening up the hitch gate?
  17. Nov 12, 2016 at 5:24 PM
    Unchained 5150
    Rick
    Auburn Ma
    Mine is in the Head Unit, and it will attach to the License Plate bracket
    Captain Taco likes this.
