Release bearing/throwout bearing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjgandarillas, Jun 14, 2018.
  1. Jun 14, 2018 at 3:55 AM
    jjgandarillas
    jjgandarillas [OP] Well-Known Member
    joseph
    Anc, AK
    SPORT DCSB MT
    ICON 2.5 VSRR, icon 2.0 ext travel, UCA’s, Ray 10 17x8.5 -12, 285/70r17 BFG Ko2
    Hello!
    I searched the forums and couldn't find anything on dropping the transmission in a 2ng gen 4.0L 4X4 6 speed in order to get to the release bearing. Can anyone point me in the right direction or give me a link! thanks in advance!
    If I cant find any sources of help I'm just gonna send it myself and document it as I go! :) Ill post pictures of how it went!
  2. Jun 14, 2018 at 1:14 PM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Key-Rei and jjgandarillas[OP] like this.
  3. Jun 15, 2018 at 3:28 AM
    jjgandarillas
    joseph
    Anc, AK
    SPORT DCSB MT
    You’re the man!
  4. Jun 15, 2018 at 4:23 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I probably have the same Harbor Freight transmission jack (the cheapest scissors jack one). It does the job but just barely.
  5. Jun 15, 2018 at 4:36 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    All that I have is the harbor frght tranny adapter for a floor Jack think it was 35 dallors. But works great. And welcome to tw.
  6. Jun 15, 2018 at 7:27 AM
    Aerose91
    Aerose91 Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    God I'd love to do this, mine squeaks like that's its job
  7. Jun 17, 2018 at 10:46 PM
    jjgandarillas
    joseph
    Anc, AK
    SPORT DCSB MT
    I’m not going to lie this was a huge pain in the butt, I’ve never dropped a transmission in a 4x4 before and it’s super difficult. I’m on day three now, but keep in mind I am renting out a lift and can only work so long everyday.
  8. Jun 18, 2018 at 4:43 AM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Just keep at it. I thought the taco Mt was the easiest tranny tcase combo I have dropped. But than again I own my own lift n tranny jacks.
  9. Jun 18, 2018 at 10:19 AM
    huck123
    huck123 Well-Known Member
    Hunter
    Butte, MT
    2005 TRD OR Access Cab
    3" 33s, UCAs, Hurst Short Throw, JL 12 500 Watts
    Ok me and my dad did this in about 1 day, but keep in mind its not the throwout going bad its the quill, if its making the chirp then you either need the repair sleeve from URD or the hydro kit, i went with the repair sleeve and did my clutch all at the same time its lasted the 2k miles ive put on it so far i don't drive a lot.
  10. Jun 19, 2018 at 3:13 AM
    jjgandarillas
    joseph
    Anc, AK
    SPORT DCSB MT
    So Its all said and done, I did the sleeve kit, and it was good for about .5 miles, then my luck I feel a pulsing/vibration in the floor board and transmission when its in gear. I have the worst luck. I torqued everything down to spec. I don't know what can be wrong. I greased the sleeve and bearing. I am so mad at my transmission.
  11. Jun 19, 2018 at 9:43 AM
    huck123
    Hunter
    Butte, MT
    Does the clutch engage properly? Is there any grinding when switching gears?
  12. Jun 19, 2018 at 8:49 PM
    22argh
    22argh Well-Known Member
    did you have the flywheel machined?
  13. Jun 20, 2018 at 6:10 AM
    jjgandarillas
    joseph
    Anc, AK
    SPORT DCSB MT
    The clutch and flywheel were machined and changed by the pervious owner but he didn't knows about the bad quill. The only thing I changed was the release bearing :(
  14. Jun 20, 2018 at 6:10 AM
    jjgandarillas
    joseph
    Anc, AK
    SPORT DCSB MT
    The clutch engages very smooth, shifting gears is smooth but when its in gear it feels as though the transmission is grinding.
  15. Jun 20, 2018 at 10:45 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I dropped mine off this morning to have a new clutch and rear seal put in it. I'm curious what your issue is since I've got the URD parts going in as well. Hopefully it all goes well.
  16. Jun 20, 2018 at 3:23 PM
    huck123
    Hunter
    Butte, MT
    Trying to think what the issue is ive been loving the repair sleeve for the fact it stopped my chirping noise my truck was only at 135,000 when it went out too im now at 137,000 i actually bought it with the chirp thinking that it was just dry but after all the reading i found out.
  17. Jun 20, 2018 at 4:01 PM
    Taco'09
    Taco'09 Well-Known Member
    Be careful about that quill kit. Mine came with very pointy anchor screws that looked like they could damage and possibly crack the quill if tightened too much. The quill (snout) is very thin aluminum and there are a couple of pics floating around of the quill breaking off that had the quill kit IIRC. Not sure though that over-tightening the screws actually caused the breaks but something did, its just something to be aware of. The bad news is the quill is not a separate part of the transmission like on the 5-speed but cast into the front and the whole transmission has to be disassembled. Way to go Toyota. Not.
    garciav and jjgandarillas[OP] like this.
  18. Jun 20, 2018 at 4:15 PM
    Taco'09
    OP, since none of us are there its kind of hard to do an inspection and narrow this down. It could be a number of things from misalignment of the case-to-engine or even inside the transmission. I have read of a few install nightmares where it gets hung up and the weight of the transmission bends the input shaft, and that could cause something like this.
    However, if this were mine, the least expensive and easiest next look would be to drain the gear oil into a clean basin and see what comes out. Make sure to have a magnet handy.
  19. Jun 21, 2018 at 3:20 AM
    jjgandarillas
    joseph
    Anc, AK
    SPORT DCSB MT
    I bought mine thinking the same thing. :( This truck has been a huge nightmare
  20. Jun 21, 2018 at 3:25 AM
    jjgandarillas
    joseph
    Anc, AK
    SPORT DCSB MT
    I heard that the quills are very strong and don't usually bed but they shatter. I think it was aligned pretty well, but Ill just go ahead and drain a little gear oil out and see what it looks like. The dealership in Germany said they wouldn't touch because I put the sleeve kit in it. I'm about to see if there is a T56 magnum swap on this truck. (joking)
    So after driving it a few miles I honestly think that the sleeve might not have been tight enough and is possible loose on the quill. I am dreading dropping the transmission again.
