Reinforced X-Crossmember
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VersaTrax, Jan 24, 2022.
  1. Jan 24, 2022 at 11:06 AM
    VersaTrax
    VersaTrax [OP] Well-Known Member Vendor
    Nicholas
    2019 Toyota Tacoma
    I am wanting to replace my rear crossmember that secures the spare tire with heavy duty tubing. I know welding on the tubing would be the go to answer but does anyone make a bolt on reinforced x-crossmember for the 2nd gen Tacoma?
    Pic as an example (not my truck)
  2. Jan 24, 2022 at 11:12 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    @ARCHIVE Archive Garage makes one that is straight across or a curved one for more ground clearance but it bolts up to the Archive Garage Hammer Hangers. This stiffens your entire rear end and beefs up your stock hangers. If this is a picture of yours, then it will not work due to the hangers in this picture being welded on and custom. If this is not your rig, just order the Hammer hangers, and crossbar and you are good to go.
    https://archivegarage.com/explore-archive/ols/products/tacoma-hammer-hangers
    Chris(NJ) likes this.
  3. Jan 24, 2022 at 11:14 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    The Tacoma X-Runner rear crossmember bolts in and is supposed to help out. It's not as beefy as what's posted above though.
    Island Cruiser and SR-71A like this.
  4. Jan 24, 2022 at 11:18 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    I guess I should have clarified that the photo was an example. I am more so looking to replace the stock x-crossmember in general. The archivegarage hammer hangers and crossbar is a great addition, though.
  5. Jan 24, 2022 at 11:30 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    What is your motivation for replacing the rear crossmember? People usually do that when going LT or links in the rear so they're already doing abunch of custom fab and burn in the crossmember while they're at it. This seems overkill for a more stock vehicle. The frame in your example pic is also fully boxed in.
    Also FYI the stock crossmember is riveted not bolted in.
  6. Jan 24, 2022 at 11:32 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    And those rivets do not come out easily
  7. Jan 24, 2022 at 11:35 AM
    plurpimpin
    PDX
    You can say that again hahaha
  8. Jan 24, 2022 at 12:01 PM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    I'm slowly building the truck to what I want it to be. And you are correct the bottom does have the rivets however, the top portion of the cross member is bolted in.
  9. Jan 24, 2022 at 12:13 PM
    crashngiggles
    Jared
    They do with the right tools and experience lol.
  10. Jan 24, 2022 at 12:16 PM
    plurpimpin
    PDX
    And that would be what? Hard for us to help you with no details.
  11. Jan 24, 2022 at 12:27 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    For the record you were invited to my rivet party :sawzall:
  12. Jan 24, 2022 at 12:34 PM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    I am just looking at options to prevent bed flex. I am not doing any hard offroading that probably requires it but I am no longer utilizing the spare tire mount the cross member so I was thinking about beefing it up back there by adding a square tubing x-cross member. Instead of welding it on I would like to have it bolted on if possible so I don't have to remove the bed to weld.
  13. Jan 24, 2022 at 12:36 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    It really seems like the easiest option are the Archive HH + crosstube or similar product from BAMF and others. Why are you resistant to this approach?
    VersaTrax[QUOTED][OP] likes this.
  14. Jan 24, 2022 at 12:37 PM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    I am not, just looking at different options.
    skeletron[QUOTED] likes this.
  15. Jan 24, 2022 at 12:45 PM
    plurpimpin
    PDX
    to answer your original question a bolt on product does not exist. Whatever you get will have to be custom fabricated.
  16. Jan 24, 2022 at 3:46 PM
    crashngiggles
    Jared
    I would have came but I was out of town that weekend. I most certainly would have been there though. We can always what until the next time either you or I add, take off, or cut something up on our trucks lol.
  17. Jan 24, 2022 at 3:48 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I got my frame plates from Big Country Customs and DOM from ruffstuff. However, I do not see the rear frame plate kit on BCC's website anymore.
    I know DMZ Fab has a frame plate kit.
  18. Jan 24, 2022 at 4:42 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    I moved to SC a couple months ago :anonymous:
  19. Jan 24, 2022 at 5:09 PM
    crashngiggles
    Jared
    Oh crap.....that is a change. Well....most certainly "good luck" down there sir. Hopefully we will see each other again.
