Regular or digital torque wrench suggestions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Sep 9, 2018.
  1. Sep 10, 2018 at 1:11 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    CRAFTSMAN old fashioned beam style best bang for the buck
  2. Sep 10, 2018 at 1:15 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Loosen the cap. That helps a lot.
  3. Sep 10, 2018 at 1:20 PM
    SpeedyJ
    SpeedyJ Active Member
    Jeff
    Calgary, AB
    2007 Tacoma Double Cab TRD Sport
    Bilstein 5100's, DuraTracs
    Loosen the cap so that it's not touching the battery? Or is there something else at play here? I've actually taken to removing the batteries completely in between uses.
  4. Sep 10, 2018 at 1:26 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    My HF 3/8 torque wrench has been fantastic. Used if from 5ftlbs to 75ish, and is within 5% based on some testing a friend and I did.
  5. Sep 10, 2018 at 1:31 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Yes. I leave mine in the case like that. Taking the batteries out is just as good.
    SpeedyJ[QUOTED] likes this.
  6. Sep 10, 2018 at 2:00 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Anybody who tells you that they've "got a great torque wrench" or "never had any problems with brand x" is not providing any useful information unless they've had it calibrated regularly. Sure, they may indicate that you've reached a given torque value, but how close to the desired value are they? Remember, a torque wrench is used where exacting / consistent levels of torque are required. For that type of application, I don't like to scrimp. I have Snap-On and Proto torque wrenches that all get calibrated regularly. Oh, and make sure you back the torque setting back to zero after using any "click stop" type torque wrench.
    As for click stop vs. digital readout, I've never had the batteries go dead in my click stop wrenches because they don't have any. I'm a big fan of simple here.
    ian408 likes this.
  7. Sep 10, 2018 at 4:15 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    In the past couple of years I acquired two Precision Instruments Split Beam Torque wrenches. They are the exact same wrenches sold by Snap On, without the ridiculous price tags. And yes, I’ve QC tested them for Accuracy and Precision.
    Precision Instruments PREC3FR250F Silver 1/2" Drive Split Beam Torque Wrench with Flex Head https://www.amazon.com/dp/B002XMSFIM/ref=cm_sw_r_cp_api_4yVLBbTCSGQDE
    Precision Instruments PREC2FR100F Wrench (3/8" Dr. "Split Beam" Torque w/Flex head (20-100 Ft./Lbs)) https://www.amazon.com/dp/B000YOX568/ref=cm_sw_r_cp_api_yFVLBbBMHAG73
    Prior to these two, I used 1/2” and 3/8 HF Torque wrenches. The 1/2” was horrible for accuracy (well above 13% of target value.) The 3/8” was decent on accuracy, but precision was out of wack.
    Both HF torque wrenches are now relegated to long handled ratchet duty. Lol
    PzTank, Biscuits and (deleted member) like this.
  8. Sep 10, 2018 at 4:27 PM
    jeepsrwack
    jeepsrwack Well-Known Member
    2014 Tacoma trd sport
    I purchased a Kobalt 50/250 lbs recently and tested it with a digital. It’s pretty accurate, I’m happy with it
  9. Sep 10, 2018 at 6:12 PM
    Subway4X4
    Lloyd
    NY/NJ
    Yeah. There are times where I definitely wished I had a torque wrench in the lower inch-lb range. My 3/8” doesn’t go lower than 20 ft-lbs.
    There’s probably a good reason that P.I. doesn’t offer a split beam, flex head 1/4” torque wrench similar to my 3/8” and 1/2”
    I wish they did. I like having the flexhead. And not having to unwind the wrench to zero for storage.
    DoorDing likes this.
  10. Sep 10, 2018 at 7:30 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    There are very few bolts that would require 1/4". 3/8" will work...
  11. Sep 10, 2018 at 7:41 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    I have a Craftsman digital 1/2" and 3 /8" torque wrenches that work well for me. I bought a nice 1 /4" regular torque wrench off Ebay.
    the Craftsman list on their website most of the time for $ 119 but put them on sale for $59. Just have to keep watching
  12. Sep 10, 2018 at 7:48 PM
    dawgn86
    2013 Toyota Tacoma
  13. Sep 10, 2018 at 7:53 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    @coreseller 's post right after yours is correct regarding Craftsman. I bought the $80 Craftsman and it broke in less than a year. Been using a Pittsburgh Harbor Freight one ever since and it works great.
  14. Sep 10, 2018 at 8:03 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    Calibration is key.
    I would consider Husky, Kobalt and Craftsman a good middle of the road tq wrench.
    I’ve had a Husky 1/4” ratchet for almost 20 years and It has never broke! I’ve put it through some serious stress too. Broken plenty of Craftsman and other brands.
  15. Sep 10, 2018 at 9:51 PM
    #35
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    at least.
    Link from Amazon? 50 one?
  16. Sep 12, 2018 at 5:41 PM
    #36
    dawgn86
    2013 Toyota Tacoma
    Search Tekton TRQ 21101
  17. Sep 12, 2018 at 7:40 PM
    #37
    EHam
    EHam Well-Known Member
    Eric
    Charlotte, NC
    2011 DCSB TRD Off-road
    Due to industry standards, most* click wrenches are calibrated at +/- 4%(cw) of the max torque rating on the wrench. Digitals are anywhere from 4% to 1% so if you're looking for the most accurate then go digital...but honestly you need to ask yourself what are you going to be using it for? Tightening lug nuts, rebuilding an engine, etc. More than likely a click/mechanical/beam style torque wrench will be fine. Most of the fasteners you'll be tightening are engineered to have an acceptable tolerance higher than your torque wrench.
  18. Sep 13, 2018 at 7:15 AM
    #38
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I saw a deal on a Craftsman click type torque wrench which was $79 for $39. Thought it was a good deal, so I bought it. Horrible mistake. I first put it to 25lbs just to feel what the click is like on my truck that's already at spec. Nothing. It just kept spinning the lug. I'm sure something is wrong with it. Going to take it back.
  19. Sep 13, 2018 at 4:08 PM
    #39
    lickem66
    lickem66 Well-Known Member
    Portland, OR
    12 V6 DCSB 4x4 Sport 6MT
    Ride-Rites, OE tubes, Tri-Fold tonneau, extra bed D-rings, OE bedmat, center console organizer, rearview mirror bracket re-locate.
  20. Sep 13, 2018 at 8:18 PM
    #40
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    Just for general knowledge, I am a professional aviation mechanic, I own numerous Snap-on wrenches and they are calibrated regularly. They are worth the money for a heavy user.
    The beam type are great for torques that are required to be held to stretch the bolt. But generally for such as that I use a dial indicator type. Click wrenches are perfectly adequate for 95% of torques.
    Even with a good torque wrench, of a type suitable for the task, there is some technique involved in getting consistent results.
    PzTank, Rufus, Biscuits and 3 others like this.
