Regular or 10 ply?
Discussion in 'Wheels & Tires' started by Titus139, Aug 18, 2021.
  1. Aug 18, 2021 at 4:13 PM
    Titus139
    Titus139 [OP] Well-Known Member
    Tim
    NorCal
    2011 Tacoma DCLB
    About to pull the trigger on a set of General Grabber ATX…talked with a guy at Discount tire and he recommended going Regular ply because the 10 ply in that tire has difficulty balancing on the lighter trucks.
    I have 10 ply (E rated) Hancooks right now and like them they’ve treated me well but super noisy as they wear out. But looking for real world experience or further recommendations.
  2. Aug 18, 2021 at 4:17 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    If you're debating between the two, you probably don't need E load.
    :cookiemonster:
  3. Aug 18, 2021 at 10:38 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I had e load and C load in the KO2 and to be honest...I don't notice any real difference.
    Mark77 likes this.
  4. Aug 18, 2021 at 10:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you don’t need 10 ply, I wouldn’t get them.
    The extra weight and ride is enough for me to not want them.
    If I needed them, maybe.
    But I don’t typically drive under those circumstances which might need 10 ply.
    Hairy Taco likes this.
  5. Aug 18, 2021 at 10:55 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    E
    second set, stiff, balance fine, wear pretty good… run ‘em a little squishy (30psi)
    tacotoe likes this.
  6. Aug 18, 2021 at 11:05 PM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    MOAR pics please! This is the setup I want to run, only matte black and RWL out. Ordered my DakarZeros in April...delivery has now been pushed to October.:bored: What size and what load do you have while in DD status?
  7. Aug 18, 2021 at 11:52 PM
    MNMLST
    Earth
    235/80/17
  8. Aug 19, 2021 at 6:45 AM
    Titus139
    Tim
    NorCal
    2011 Tacoma DCLB
    Sweet setup! Thanks for the info.
    MNMLST[QUOTED] likes this.
  9. Aug 19, 2021 at 6:45 AM
    Titus139
    Tim
    NorCal
    2011 Tacoma DCLB
    I’m also wondering if it’s worth the extra $250 difference from regular to E rated? Another thing to take into account.
  10. Aug 19, 2021 at 6:46 AM
    Titus139
    Tim
    NorCal
    2011 Tacoma DCLB
    So would you go with E rated or C again?
  11. Aug 19, 2021 at 6:48 AM
    MNMLST
    Earth
    No…
    until you drive in a rock quarry or run over a used muffler doing 85.
    JustJon, tsb, tacotoe and 1 other person like this.
  12. Aug 19, 2021 at 7:19 AM
    Titus139
    Tim
    NorCal
    2011 Tacoma DCLB
    Hahahaha ok thanks! What made you go with the E rated over the Regular?
  13. Aug 19, 2021 at 7:33 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Depends on hat you're doing with your truck and to your truck.
    If you plan on offroading rough and rocky trails frequently and or are loading the truck all the way down with armour and gear then get then it may be worth getting the 10ply E's.
    If you plan on offroading AND loading the truck down DEFINITELY get the 10 plys E's.
    If you just want to lift your truck a tad and go camping down some fire roads once in a while then nah stick with the C loads.
    But be honest with yourself or be willing to eat the MPG.
    texas angler likes this.
  14. Aug 19, 2021 at 7:44 AM
    Titus139
    Tim
    NorCal
    2011 Tacoma DCLB
    Thanks for the info. Not really going to load it down crazy heavy. I have E rated on now. Can for sure tell the difference with MPG. I like the ride when I’m off road and the extra protection. It’s saved me on a few time when I’ve had nails in them and not gotten a flat. But I won’t be doing severe off roading or rock crawling. Mainly off-roading for hunting and camping.
    Key-Rei[QUOTED] likes this.
  15. Aug 19, 2021 at 7:58 AM
    MNMLST
    Earth
    I’m a massive baller with cheddar to burn….
    tsb and tcjacado like this.
  16. Aug 19, 2021 at 9:26 AM
    Nessal
    Texas/Bay Area
    I would go with C just because it was 5lbs lighter per tire.
  17. Aug 19, 2021 at 9:30 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I won't buy E rated tires again..
  18. Aug 19, 2021 at 10:49 AM
    79CHKCHK
    SoCal no mo
    OP, if you want Grabber ATx tires the only C Load Rated tire General offers for 16" or 17" wheel size is the LT265/70r17 (31.6" x 10.7" @ 44.9#) with BSW. Otherwise it's E Load Rated or SL.
  19. Aug 19, 2021 at 11:19 AM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    C rated is preferable but there aren’t too many options. I just ordered some E rated toyo AT IIIs. I like E rated for hauling firewood, more aggressive tread pattern and tread depth vs SL tires, and not blowing out a side wall.
    tsb likes this.
  20. Aug 19, 2021 at 11:24 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Exactly. We have quite a few "princesses and the pea" on thia forum when it comes to tires. I got E rated KO2s a couple months ago and the ONLY thing i noticed, was slightly less mpg from a larger tire. Thats it.
    rosswood, tsb, 79CHKCHK and 1 other person like this.
