Regular cab to extended cab conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pinoiako916, Oct 5, 2013.
  1. Oct 6, 2013 at 4:26 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Xtra Cab on a short wheelbase truck with a shortened bed was/is a popular conversion with older Toyotas used for rockcrawlers/extreme 4 wheeling. People need the short wheelbase, but want a little bit of room to sit in the thing comfortably too, the older trucks were very small inside.
    Can it be done on a 2nd gen? Sure it can. Can YOU do it? I dunno. It's probably beyond my skills, definitely beyond my attention span/patience. A pro body shop could do it if they were so inclined, but that would cost way too much to be worth it. I would love to see it done!
  2. Oct 6, 2013 at 4:27 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    4.7 indeed sema did it up nice blacked out interior also.
  3. Oct 6, 2013 at 5:34 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The cab has various weld seams at the roof and B-/C-pillars. Toyota even sells replacement cab pieces for collision repair (for example). So yea, with enough time and money it's quite possible to do properly, with all the seatbelt anchor points, side impact structure and rollover curtain airbags intact. It will be much more expensive than trading in for an Access Cab, as others have said.
  4. Oct 6, 2013 at 6:27 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Just because you can, does not mean that you should. :eek:
  5. Oct 6, 2013 at 6:37 PM
    KenLyns
    Belly of the Beast
    Of course, if I had enough money to commission Ferrari to build custom models for me, I would. :D
