Reducing dust in the truck bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by colorado_blacked_out, Oct 1, 2023.
  1. Oct 1, 2023 at 1:32 AM
    colorado_blacked_out [OP] '22 DCSB TRD OR
    Hey guys, '22 TRD OR here.. I do a lot of overlanding and even with a well sealed tonneau cover, my taco always ends up with a lot of dust in my truck bed (and my camping supplies) even after just a few hours on a dry trail. Doing a quick check, I'm assuming almost all of it is coming in from around the tailgate, especially the gap between the bottom of the bed and the tailgate.
    Has anyone tried to seal their truck bed from dust? I'd imagine it would just take finding the right piece of rubber ribbon and some scissors and e-6000 to create a much better seal, but maybe someone can recommend a product or better solution before I DIY it?
    edit: Got some great advice on here for the full breakdown of how to do this:
  2. Oct 1, 2023 at 1:47 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Welcome.
    One solution of many just google it. Yep tailgate bottom and sides plus any cover gap with your tonneau. Suggest plastic storage boxes for clothes etc on those trips as always seems to get in!
    Note dust also comes up thru those little in bed storage boxes as they have drain holes also.
    greedy23 likes this.
  3. Oct 1, 2023 at 1:59 AM
  4. Oct 1, 2023 at 2:19 AM
    greedy23
    greedy23 Active Member
    California
    Thanks too! So thats why the inside always gets dirty even if I dont go off road! It just kinda builds up after long time so this should help..
  5. Oct 1, 2023 at 5:53 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Easy. Trade for an SUV. Beds are not air tight. You can't make a bed air tight, or even water tight. Beds are designed to haul shit in the open air, hence the whole no top thing. You need a Honda Pilot or something.
  6. Oct 1, 2023 at 6:43 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I just spent 5 days riding around Utah, it was as dry and dusty as I've seen it. Within the first mile of off roading the outside of the truck was covered in layers of fine silt.
    I knew it' would be bad this time of year so prior to leaving I sealed up all the holes in all the bed cubbys. I also got inside with the tonneau cover closed during the day and anywhere I saw light I sealed it with silicone. That was mostly in the front upper corners where the sides meet the front wall of the bed.
    During the 300mi of off road dust did get inside but it was concentrated mostly at the bottom of the tailgate as others have noted and it wasn't excessive. There was some dust on the items in the bed bed but it also wasn't excessive. I'm pretty sure w/o the other measures it would have been allot worse. I was also using storage boxes for most of the gear so it stayed off the important stuff. Next time I'll also carrying a dustpan brush, the small amount that did get in would be easily manageable with a brush. An air blower would be better but we can't have everything out there.
    Thanks for the tip Mud Dog! I'll be installing one of the lower seals you recommended, along with the other things I've done that should stop most of what got in.
    The truck is a shade darker w/o all the dust.
    j-utah and jackn7 like this.
  7. Oct 1, 2023 at 6:50 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Good luck I kind of think you will never keep it out. It is a low pressure area while driving.
    Stevie17, hiPSI and Tocamo like this.
  8. Oct 1, 2023 at 7:08 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Only real solution is a TRD SUV!
    Stevie17 likes this.
  9. Oct 1, 2023 at 7:12 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol people buying a truck and wanting to keep dirt out of bed. Crazy.
    Lone_Wolf77, Tocamo and Stevie17 like this.
  10. Oct 1, 2023 at 7:23 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Nothing crazy about trying to keep the dust out of the bed, Drive around off road out west with allot of stuff in the bed and I promise you you'll wish you had a way to keep it out or minimize it. I've lived on the east coast and know you don't see 1% of the dust and silt we see that's kicked up driving on the ancient lake beds that cover much of the west. Saying something is crazy because you don't understand it, haven't experienced it or don't know how to solve it is crazy.
  11. Oct 1, 2023 at 7:32 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I wonder if most of the dust is coming up through the drain openings at the end of the bed corners.
    Tocamo likes this.
  12. Oct 1, 2023 at 7:38 AM
    Lmao at the replies acting like it's some impossible feat to reduce dust back there
    BRFab, SunRunner and jackn7 like this.
  13. Oct 1, 2023 at 7:42 AM
    I'm also wondering if some of these people understand what tonneau covers even are haha
  14. Oct 1, 2023 at 8:13 AM
    Seeing as how my thread has already informed at least a couple of people about a solution to this issue with truxseal, I think I've been perfectly constructive.. Have you? But thank you for the very helpful input! Only rivaled by "Only real solution is a TRD SUV!" and "Lol people buying a truck and wanting to keep dirt out of bed. Crazy."
    Jofenech and Tocamo like this.
  15. Oct 1, 2023 at 8:17 AM
    It's almost like I said REDUCE dust.. And shocker... this is possible!
  16. Oct 1, 2023 at 8:19 AM
    scocar
    scocar hypotenoper
    I misquoted OP. You are right. My bad.
    Have you caulked the gaps at the top of the bedrails where they meet the front wall of the bed? Not as significant as the huge gaps around the tailgate as far as dust, but still a notorious gap for water leaks.
  17. Oct 1, 2023 at 8:30 AM
    My tonneau cover actually came with these little foam inserts for those spots that seem to work pretty well to seal it.
  18. Oct 1, 2023 at 8:30 AM
    scocar
    scocar hypotenoper
    Far worse is the million holes under the plastic bedrail caps
    Well placed thick foam seals can help there.
    McHale likes this.
  19. Oct 1, 2023 at 8:32 AM
    Now that is something I wasn't aware of, thanks
    scocar[QUOTED] likes this.
  20. Oct 1, 2023 at 8:33 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ever hear of the Golden Rd? It is just one of thousands of dirt roads in Maine it is right about a 100 miles long clear to Canada. I live on a dirt road, it's part of a 7,000 acre wild life management area. Yeah we got enough dust to cover several states.
    hiPSI likes this.
