Recovery gear on a budget
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skynet Surfer, Sep 26, 2020.
  1. Sep 26, 2020 at 11:21 AM
    Skynet Surfer
    Skynet Surfer [OP] Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    So it's near my Birthday and my family got me about $100 for ebay gift certificate money. I'm looking at adding $40 and getting a Bubba rope. I was wondering what you guys think? I keep seeing people suggesting 20 or 30ft. Also what weight rating is good for a 2nd gen use?
    I looking at boards and other stuff later. What other stuff do you suggest?
    FattyKrack likes this.
  2. Sep 26, 2020 at 11:37 AM
    Bishop84
    Bishop84 Well-Known Member
    Hitch receiver shackle x1000
    Gunshot-6A and Skynet Surfer[OP] like this.
  3. Sep 26, 2020 at 11:42 AM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    Quality shackles and I would get a good kinetic rope.
    Skynet Surfer[OP] likes this.
  4. Sep 26, 2020 at 1:07 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    why not just get a recovery strap like $60 ish +- depending on the quality
  5. Sep 26, 2020 at 1:38 PM
    Skynet Surfer
    Dis
    15 DC v6 SR
    Yes I know but I watched a review on Matt's offroad recovery and they compared the 2. Arb needed to be replaced much sooner.
    mOjO_Taco and Taco_Josh like this.
  6. Sep 26, 2020 at 1:59 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Go old school.
    2000 lb tensile strength rope, 2 dual sheave block and tackle, 10,000 lb hooks (2).
    Tie off to the truck and deadman with the hooks, lace up the block and tackle with the rope. Pull on the loose end. You probably won't need a winch.
    Lace the rope correctly, you could get 5 parts of line pulling. You have potential pull strength of 10,000 lbs.
    deanosaurus likes this.
  7. Sep 26, 2020 at 2:24 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I find traction boards to be much more useful than a snatch strap, but that is because I often roll solo. I've run into people out in the middle of nowhere with their vehicle in a ditch and a snatch strap attached to their bumper, waiting for someone to come along for a tug.
    Speaking of come along, those are also very helpful in solo recovery when you can't afford or use a winch.
  8. Sep 26, 2020 at 2:52 PM
    Skynet Surfer
    Dis
    15 DC v6 SR
    Good points. I often roll solo or with my wife. As I don't know many offroad people. As much of my car stuff is all about the older wrx crowd. I do have a come along. but I have plans to get a bumpers and winch. but I need suspension first. Working on getting the rest of my skid plates soon.
    Gunshot-6A likes this.
  9. Sep 28, 2020 at 12:14 AM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    Get Sliders first!!!! buy an air compressor and air down before you get stuck, cheap shovel, traction boards (if solo), you also need to replace the transport Hook on the front if you don't have a bumper with pull points, and get the hitch D-ring for the back if you don't have aftermarket bumpers. Do hitch plug relocation if you haven't torn it off already. Depending on your load snatch strap are less $$ or kinetic rope of at least 7/8 and to get the most snap energy get a 30 footer. My fully outfitted rig is heavier than yours will be so you shouldn't have to go larger than 7/8 on the kinetic strap. couple of D-rings and/or soft shackles.
  10. Sep 28, 2020 at 1:20 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    How long is the Bubba rope you’re looking at?
  11. Sep 28, 2020 at 1:31 AM
    Texas T
    TX
    '14 T Force
    I have about 80’ of kinetic rescue rope that is rated at 1200lbs. Since it’s your birthday and your on a budget send me your address and I’ll send you half of it.
  12. Sep 28, 2020 at 1:51 AM
    Texas T
    TX
    '14 T Force
    I’ve been searching online to back my claim of 12k lbs but can’t find anything to prove it. I’ll just say that I would trust it to pull my truck out and it really is bad ass rope
  13. Sep 28, 2020 at 1:52 AM
    Texas T
    TX
    '14 T Force
  14. Sep 28, 2020 at 2:16 AM
    Texas T
    TX
    '14 T Force
    It’s nowhere near 7/8” It looks like 1/2”
    whatstcp likes this.
  15. Sep 28, 2020 at 2:24 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I'd get the highlift extreme jack, it comes with an extra piece for putting a shackle on each end, then grab some rope, you got yourself a budget winch, add some more rope and some sheaves and you got yourself an even better winch.
    A lot of times you can get yourself unstuck solo by just lifting the truck and stacking under the tires, done this many a time.
    $100 well spent.
    https://www.amazon.com/Hi-Lift-Jack...extreme+jack&qid=1601283580&sr=8-3&th=1&psc=1
    A $20 mini D handle shovel has also saved me a lot of headache.
    Ultimately the best and cheapest recovery related thing you can get is knowledge, watch a bunch of videos on youtube, know how and when to use your gear safely and learn through experience when you can.
    milescf likes this.
  16. Sep 28, 2020 at 2:27 AM
    Texas T
    TX
    '14 T Force
    I’ve never been stuck but I’ve got several people unstuck.
  17. Sep 28, 2020 at 2:28 AM
    Key-Rei
    Key
    Florida
    You're either lying or not having enough fun. :anonymous:
    usmc2msu likes this.
  18. Sep 28, 2020 at 2:34 AM
    Texas T
    TX
    '14 T Force
    I’ve tried. Thing is where I go on the beach I usually go alone so I try to be smart. But then I pass people that aren’t familiar with that beach and are stuck. There’s no cell phone signal or any connection otherwise so I feel obliged to help. My little truck made me so proud one day I pulled a four door Chevrolet diesel off it’s axles one day. I’ve been driving that beach since I was 14 I’m 41 now
    cytocycle likes this.
  19. Sep 28, 2020 at 2:41 AM
    Texas T
    TX
    '14 T Force
    4F1673F9-64CA-40B0-8DA3-13E29379A877.jpg Saw this there today. He went right when he should have went left
    FredRed315 and mOjO_Taco like this.
  20. Sep 28, 2020 at 2:45 AM
    Key-Rei
    Key
    Florida
    Ah beach driving yeah, so long as you air down and understand driving sand and can read the soggy line you good.
    I never pulled nothing off it's axles but I did yank an old Ford Excursion (Big long boi) out of a ditch with my '00 4Runner, had to throw everything at it, 4 Low and Locked but it is a heck of a warm proud feeling I get ya!
    You should try some trails some time get yourself good n stuck!
