Recommendations for portable tire inflator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaboDawgs, Aug 18, 2020.
  1. Aug 18, 2020 at 11:19 AM
    CaboDawgs
    CaboDawgs [OP] Member
    Kim
    Next week we will be flying to Dallas to pick up our new TRD Pro so I’m shopping for all the accessories. Can anyone recommend a good portable tire inflator? We live in Cabo and will be driving on sand a lot so it should get a fair amount of use.
    Please let me know what other essentials we should consider. I need to shop while we’re in the US because the selection in Mexico isn’t great.
    ORtoCOTaco likes this.
  2. Aug 18, 2020 at 11:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you want fast and portable, then I have been impressed with my Viair. I bought a 300P and just converted it to automatic. Otherwise, I'd say go with the 400P Automatic.
    The ARB also has a lot of fans around here.
    44-16 Taco, Dryfly24, MJTH and 3 others like this.
  3. Aug 18, 2020 at 11:22 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    ARB Twin Air - you can mount it in several different locations. Pricey, but worth it IMO.
    Wulf likes this.
  4. Aug 18, 2020 at 11:27 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Viair 300P! Love mine.
    OmahTako, NWTacoTime and tonered like this.
  5. Aug 18, 2020 at 11:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Based on the fact you'll be doing it frequently, you'll want something with some ass behind it, otherwise you'll spend forever filling up. I've had a dual arb in the past and liked it.
    edit: It also depends on your tire size too.
    Shellshock likes this.
  6. Aug 18, 2020 at 11:32 AM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    I’ve used the dewalt 20v inflator and without any issues. 100 bucks as a bare tool. If you’re already invested in a cordless tool platform Milwaukee, makita, and ryobi (maybe others) also have cordless inflators. Runs on batteries or 12v power from cig lighter
    tarbal255, MannyS, tacoman45 and 2 others like this.
  7. Aug 18, 2020 at 11:33 AM
    iptman
    iptman Well-Known Member
    Northen VA
    2018 TRD Pro, 1997 Land Cruiser, 1977 Land Cruiser
  8. Aug 18, 2020 at 11:33 AM
    Technique
    Alex
    Utah
    My friend has the dewalt one. I did all of mine and two of his before that thing finished one of his tires. I have 33s and he has 265/70/17s.
    SnowroxKT and tonered like this.
  9. Aug 18, 2020 at 11:34 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    The Viair compressors are great. I personally use an 88p (see below) and it hasn't let me down yet. If it ever sh*ts the bed on me, I'll probably upgrade to one of the bigger ones. One of the nice things about the 88p is it will fit in the cubby behind your driver side back seat and won't blow your cig lighter fuse since it connects direct to battery.
    For those who are considering this inflator, it inflates each one of my 265 75 R16 tires from 16psi to 34 in about 1 minute. Add a minute between each tire for duty cycle cool down, you can be aired back up in about 10-15 mins. Works well
    https://www.amazon.com/Viair-00088-...dchild=1&qid=1597775598&sr=8-1&srs=2603227011
  10. Aug 18, 2020 at 11:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  11. Aug 18, 2020 at 11:38 AM
    rustyfromskowhegan
    2013 AC 4x4
    Definitely more nuts to the portable compressors. I think the dewalts etc are called “inflators” not quite to compressor status. Sounds like something like you’ve got would be better for OP if they’re airing down and up all the time
  12. Aug 18, 2020 at 11:41 AM
    Technique
    Alex
    Utah
    Exactly. Just topping off tires the dewalt is fine, but if somebody is looking to air up and down, a Viair or ARB is hands-down the way to go!
    tacoman45 and tonered like this.
  13. Aug 18, 2020 at 12:07 PM
    tacoman45
    Orygun
    OP - I will say, the 88p is probably the best $60 I’ve spent in a long time. Can’t go wrong with any of the suggestions here tho.
    I do a lot of surf perch fishing and as a result, I air down often to drive on the beach. I’ve used it probably 50 times so far without issue. Takes about 5 mins to air up all of my tires to 36 psi from 16 psi. I run 265 75 16 duratracs FWIW
    Jaredius, C41n, Peace1 and 2 others like this.
  14. Aug 18, 2020 at 12:08 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I personally think viair is the best bang for your buck. I feel like with arb your just paying for the name
    tacoman45 and GlitterGulch like this.
  15. Aug 18, 2020 at 12:17 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Taco16LB[QUOTED] likes this.
  16. Aug 18, 2020 at 1:12 PM
    db6598
    db6598 Well-Known Member
    NC
    I've been using the Viair 400P for the last 18 months. Gets used pretty regularly since we drive out on the beach frequently. No issues with it at all. I often notice I'm finished airing up before other people who had a head start with some other compressor. I've seen it range from $180-250 on Amazon.
    tonered likes this.
  17. Aug 18, 2020 at 1:18 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I got a smitty built one works great for 100 bucks.
    You SHOULD see what can be shipped to you while in Cabo just in case you need parts.
    My smitty is not mounted though. A guy on here did some really awesome stuff with his. He mounted his in the space between his cab and fender on a LB, and ran air hose to his bumper and had a permanent chuck to air up or down all 4 tires at once. Took him 5 minutes and never had to worry about it getting stolen because you can't see it.
    tonered likes this.
  18. Aug 18, 2020 at 1:25 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Another for Viair 300p. You are probably gonna want some deflators as well.
    tonered and Dirk Diggler like this.
  19. Aug 18, 2020 at 1:36 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  20. Aug 18, 2020 at 2:16 PM
    rtadams89
    rtadams89 Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    I used to have a compressor in my SUV (before the Tacoma) and then moved it to the Tacoma. I hardly ever used that thing, as I found that if my tire went flat, I was just putting on the spare and fixing/reinflating the tire when I got back home. With the Tacoma, I now air down my tires more frequently and started shopping for a better compressor. That let me to the CO2 tank options and that's what I went with. The CO2 bottle normally stays in my garage if I'm just driving around town and when I pack up the Tacoma for any sort of off road, I throw the tank in the back. WAY faster than even the best tankless compressors and lets me use a airgun to clean things off, pressurize a portable fuel tank to fuel up other vehicles, run a impact wrench, etc.
    MattCowsmasher and tonered like this.
