Recommendations for an off-road build on a budget
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ReeceRiley, Nov 30, 2019.
  1. Nov 30, 2019 at 9:27 AM
    ReeceRiley
    ReeceRiley [OP] Well-Known Member
    Reece
    Des Moines iowa
    Tacoma in-line 4, 2 door, 5 speed
    I’m thinking about modding my 2008 5 speed regular cab 2.7 L Tacoma.
    I’m looking at suspension, engine, wheels, and tires. My goal is to have a cost efficient and off-road capable build. Currently stock, has a topper, and is a daily driver. I understand that there is person preference, I am looking for your recommendations, I am on a budget.
  2. Nov 30, 2019 at 9:32 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum!
    Is your truck 4x4? If so, you already have a cost efficient and off-road capable vehicle.
  3. Nov 30, 2019 at 9:32 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Cost effective and off-road capable?
    OME and good tires.
    Kolter45 and boston23 like this.
  4. Nov 30, 2019 at 9:51 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yeah is it a 4x4 6 lug or a lil 2wd 5 lugger?
  5. Nov 30, 2019 at 9:51 AM
    ReeceRiley
    Reece
    Des Moines iowa
    Do I need to do upper control arms with the OME
  6. Nov 30, 2019 at 9:51 AM
    ReeceRiley
    Reece
    Des Moines iowa
    It’s 4x4
    Hobbs likes this.
  7. Nov 30, 2019 at 9:54 AM
    nd4spdbh
    SoCal
    pss a lil awesome 4x4 regular cab 6 lugger stock will have better off road manners than any longer lifted truck.
    That stated, first and best thing for offroadability, tires. Bump to a 265/75R16 in what ever tire you feel best for your needs. No cutting or trimming needed.
    If you really want to do a lift 5100's up front and maybe an AAL out back for 1-2in of lift all around.
  8. Nov 30, 2019 at 10:00 AM
    T4RFTMFW
    UCAs are only required by lift size.
    Whole lot of info in suspension forum. Start reading!
    whatstcp likes this.
  9. Nov 30, 2019 at 10:17 AM
    ReeceRiley
    Reece
    Des Moines iowa
    Thanks for the recommendation, should I recovery points? If so where?
  10. Nov 30, 2019 at 10:38 AM
    ReeceRiley
    Reece
    Des Moines iowa
    This is exactly what I was looking to hear thanks so much for your thoughtful response, this really helped me out.
    MattCowsmasher likes this.
  11. Nov 30, 2019 at 10:58 AM
    ReeceRiley
    Reece
    Des Moines iowa
    I think I will start on learning how to maintain all of the fluids and then I’ll move on to tires
    Is there a good resource for learning how to do maintenance?
  12. Nov 30, 2019 at 11:09 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I think before anyone here can make any recommendations, we need to know what you mean by “off-road capable”. Are you wanting to rock bash hard trails or cruise dirt/gravel roads?
  13. Nov 30, 2019 at 12:14 PM
    ReeceRiley
    Reece
    Des Moines iowa
    Thanks!
  14. Nov 30, 2019 at 12:16 PM
    ReeceRiley
    Reece
    Des Moines iowa
    I live in iowa so it wouldn’t be that intense but I would like to be able to over come most of the obstacles in my state
  15. Nov 30, 2019 at 2:29 PM
    3Dog
    3Dog good boy
    Rocky Mountain high...
    2015 Tacoma 4x4 auto TRD Sport DCSB
    ^^ This. Since you are in Iowa, I wouldn't lift it at all, until you have a fair amount of time off-roading it in stock form to find what, if any, limitations you have. I doubt you will find any.
    Invest instead in some good P-rated all terrains (as @whatstcp recommended above) and focus on maintenance for now.
    If you are simply wanting to lift it for looks, then that is another story.
  16. Nov 30, 2019 at 8:16 PM
    crx7
    crx7 1997 FZJ80 Triple Locked
    Grand Junction Colorado
    Bilstein 5100s preferably used
    OME 884 preferably used and mounted on 5100s
    AAL
    Tires only when yours wear out: you’d be amazed what airing down will do.
    Do not go out and buy a packaged lift kit. Piecing it together on cheap used deals works best.
    You do not need after market UCAs with a mild lift. Only get them if you find they can’t align it with your lift which would need to be 3+ inches
  17. Nov 30, 2019 at 8:24 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Since you've got a 4 cyl, you might look at something like a 235/85/16 tire. Wider isn't always better.
    What kind of offroading are you looking to do?
  18. Dec 1, 2019 at 12:32 PM
    ReeceRiley
    Reece
    Des Moines iowa
    Alright, I’m not exactly sure what I want to do yet.
  19. Dec 1, 2019 at 1:05 PM
    0xDEADBEEF
    So, I think you should just get some decent tires, some good recovery gear, read up on how to use them, and go have fun. It doesn't take much to have fun, just look how the old Camel Trophy trucks were equipped.
  20. Dec 1, 2019 at 2:29 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Decent tires no bigger than 265/75/16. Use the rest of your budget for gas.
