Recommendations Fender Liner Sheet Material???
Discussion in 'Off-Roading & Trails' started by bren5279, Aug 14, 2017.
  1. Aug 14, 2017 at 12:28 PM
    bren5279
    bren5279 [OP] Well-Known Member
    Brendon
    new bern NC
    2012 Black Tacoma TRD Long Travel Supercharged
    TRD Supercharger Dirt King 14" Long Travel Kit Pro Comp 6" lift Fox dual rate 2.5" remote res front coil carriers Fox triple bypass 2.5" remote res front shocks Fox 12" 2.5" Remote Res. Shocks DSC adjusters (flutter shim stacks) ARB Lockers F+R 4.88 Regear F+R Shackle flip kit Bamf tall shock mount Demello Offroad Front Bumper Smittybilt Winchs F+R Method beadlock 17x9 Rims 37" Open country R/T tires Baja fiberglass Front Fenders Baja Fiberglass Rear Fenders Bulletproof Fab Front Grill Air Intake Reroute High Lift Jack Pro Comp Skid Plate KB Voodo Short Bed Rack CVT Cascadia Rooftop Tent
    Hey guys, does anyone have any recommendations on a good cheap material that could be used for lining fenders (like sheet rubber or something)?? My OEM ones are long gone, and I'm trying to find something I can line them with to keep the sand and mud out of the engine bay with.
    Currently I have some rubber sheets from a tool box I had, but need something bigger and a little cheaper than 60$ a mat.
    ... Was considering a good really thick vinyl tarp, or a huge sheet of gasket maker (but thatd probably be expensive)
    and please avoid the urge to say don't use them haha .... yeah I know that's an option
  2. Aug 14, 2017 at 7:00 PM
    bren5279
    Brendon
    new bern NC
    Anyone?
  3. Aug 14, 2017 at 10:13 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Maybe some rubber floor mats? Might be able to find some fancy plether (fake leter) material from a craft store.
    I'm probably going to be in the same boat, the ones in my 1st gen are pretty bad off.
  4. Aug 14, 2017 at 10:25 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
  5. Aug 14, 2017 at 10:25 PM
    Yo_Hec
    Yo_Hec Well-Known Member
    Hector
    Fort Myers
    17 TRDPRO , 05 Honda Element
    Peddle commander and various molle racks.
    goo gle rubber sheets. I'm sure you'll get some good hits
  6. Aug 14, 2017 at 10:26 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  7. Aug 14, 2017 at 10:32 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I looked through all the epm.... whatever types of rubber (uv,oil,and some other shit resistant). Ended up using tool box liner. I think it was 18"x72", 1/8" thick. $15 and it did both wells. It's held up 2 summers and one winter. (Canadian). I'll post some pics tomorrow for you.
  8. Aug 14, 2017 at 10:35 PM
    jbrandt
    Justin
    I love that place. Although a lot of those panels I saw in the link were only at most 12x24", which might be big enough if you're careful with your cuts. I'm sure theres others in there I missed.
    It's kind of the blessing and the curse of that place - so much stuff!
  9. Aug 14, 2017 at 10:37 PM
    bullaculla
    Da big big island!
    36" wide by however long you want. I'd go 3/32" pretty cheap too.
    mcharfauros likes this.
  10. Aug 14, 2017 at 10:39 PM
    jbrandt
    Justin
    Yeah, I'm dumb, I missed that.
  11. Aug 14, 2017 at 10:40 PM
    bullaculla
    Da big big island!
    Meh. Like you said, they have a lot of stuff. I've been researching it for my self too. Actual fender liners and the engine bay covers. One guy on here actually sells the engine bay covers tho.
  12. Aug 15, 2017 at 6:13 AM
    bren5279
    Brendon
    new bern NC
    Thanks for the tips guys! Yeah Mcmaster was in the back of my head, was hoping I could resort to something locally but thatll probably have to work. Looks like theres some fabric reinforced ones too. The toolbox liner sheet I have now is ripping at the ziptie mounts which is why I was looking into other options
  13. Aug 15, 2017 at 6:56 AM
    bren5279
    Brendon
    new bern NC
    WalkinTaco and bullaculla like this.
  14. Aug 15, 2017 at 10:17 AM
    bullaculla
    Da big big island!
  15. Aug 15, 2017 at 10:21 AM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    I went to a tire place and asked for an innertube. They had a few that didn't hold air and were $free.50. It was a little wrinkly and didn't lay flat but the price was right.
  16. Aug 15, 2017 at 10:44 AM
    bullaculla
    Da big big island!
    Nice! Doesn't ship to Hawaii tho :(
    I order stuff from McMaster monthly, so I'll add a sheet on my next shipment.
  17. Aug 15, 2017 at 10:58 AM
    cnote4l
    cnote4l Gear Tech Customs Vendor
    Cody
    Evergreen, CO
    2016 TRD OR
    You can find and buy precut slabs online all day only downside is the $/sq ft gets increased. 3x6ft slabs will come up short if your cutting 1 peice designs into the material or hoping it's cut right the 1st time. If you want to save yourself some time and money I've got precut sets that are put to the test everyday by TW members and proven to fit. Obv upgrade from factory especially for those that ride around with nothing there. Oh and I love shipping to my peoples in Hawaii!! @bullaculla already knows :fistbump:
    bullaculla likes this.
  18. Aug 15, 2017 at 1:13 PM
    bren5279
    Brendon
    new bern NC
    Thanks Cnote, definitely a good option for those of us looking for the OEM upgrade!
    Me however I need a full fender liner replacement. Going long travel and need something to line the entire fender well to protect the cabin intake and air intakes. Figured Id do the sides as well while I'm at it
    cnote4l likes this.
  19. Aug 15, 2017 at 1:23 PM
    bullaculla
    Da big big island!
    Yeah, I need to do the whole front and rear fender liner too as I gutted mine to fit 37s. Also I don't have the stock shock towers.
    cnote4l likes this.
  20. Aug 15, 2017 at 8:05 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    Of course and the air intake cavity is especially important to have coverage from dirt dust etc. I'm n the middle of the r&d design for a set of precut fender liners to be direct replacements for stock liners. I'm upgrading the protection, coverage and design to close up the gaps and give it a clean ass look
