Recommendation on new Headlight bulbs 2013
Discussion in 'Lighting' started by Dango13t, Mar 1, 2019.
  1. Mar 1, 2019 at 7:19 AM
    Dango13t
    Dango13t [OP] Member
    Dane
    North DFW, TX
    2022 Army Green 4Runner TRD Off-Road P
    looking for recommendation on new headlight bulbs for 2013 taco. looking to keep same halogen style lights but just a little stronger light output than OEM. if there are good LED lights that would look the same too and not blind on coming cars i would consider too. if you can link any good headlight bulbs that you guys have tried.
    thanks,
  2. Mar 1, 2019 at 7:22 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    crashnburn80 likes this.
  3. Mar 1, 2019 at 7:22 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Beat me to it Rick!
    crashnburn80 and Unchained 5150 like this.
  4. Mar 1, 2019 at 7:24 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I learned from the 2 best, you and @crashnburn80
  5. Mar 1, 2019 at 7:42 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    LEDs definitely do not work in halogen assemblies.
    If looking for a plug and play stock wattage bulb without going high power with a harness, GE seems to make the best performing ones, though bulb life will be shorter. In the H11, the GE +130 outperforms an H9 that is 60% brighter. The 2nd Gen takes H4s, the +130s are available in an H4, but GE just released a new +150 that looks to be even higher performing. I’ve ordered them and they should arrive any day now. Their test will be shared in the thread @Unchained 5150 linked above. That thread is everything H4 halogen headlights from high power with relayed harness to best stock wattage plug and play.
  6. Mar 1, 2019 at 8:01 AM
    Dango13t
    Dane
    North DFW, TX
    i will read over this link. thanks guys.
  7. Mar 1, 2019 at 8:18 AM
    Dango13t
    Dane
    North DFW, TX
    so below bulb would not require any new harness wiring correct for 2013 sport headlight? would like the pull and plug new bulbs in. crashnburn80
    Philips Xtreme +130
    thanks,
  8. Mar 1, 2019 at 8:19 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Nope I just ran those with zero issue
  9. Mar 1, 2019 at 8:21 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
  10. Mar 1, 2019 at 8:22 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I have the new Nightbreaker +150's and love them
  11. Mar 1, 2019 at 6:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    As others mentioned that is correct, plug and play. The GE +130 version should be much higher performing than those, but also much shorter life than the Philips +130s.
