recommend lock for the hitch ball and tir?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aboyz, Dec 15, 2020.
  1. Dec 15, 2020 at 9:13 AM
    aboyz
    aboyz [OP] Well-Known Member
    can someone recommend some lock for a trailer lock for the tire and also lock for the hitch ball? I wanted to see what people the most popular.
  2. Dec 15, 2020 at 9:16 AM
    Juice Weasel
    Juice Weasel Well-Known Member
    3rd Gen Tacoma SR5
    zip ties
    Skydvrr likes this.
  3. Dec 15, 2020 at 9:20 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    For the hitch ball - pull the pin, remove the ball mount & ball, store in the cab. You could always try a locking pin, but given the exposure to the elements you'd probably never be able to remove it unless you did so regularly.
    Not sure what you mean by "lock for a trailer lock for the tire"
    Tullie D and Skydvrr like this.
  4. Dec 15, 2020 at 9:23 AM
    aboyz
    do you have a brand or a link where i can purchase onf of those lockiing pin? locking tire? i mean a device to lock the tire so someone cannot tow away my trailer.
  5. Dec 15, 2020 at 9:25 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    :crapstorm::crapstorm::crapstorm:
    In before the incoming shitstorm about how easily defeated a combination lock is. It does a fantastic job of guarding my $20 UHaul brand stinger.
    TomTwo likes this.
  6. Dec 15, 2020 at 9:27 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've used fulton trailer hitch locks and truck receiver pin locks on my boat and sled trailers for years. I've always kept my spare trailer tire in the trucks bed when in use.
  7. Dec 15, 2020 at 9:32 AM
    CT Yankee
    CT
    Wulf likes this.
  8. Dec 15, 2020 at 9:39 AM
    R4D4G4ST
    R4D4G4ST Well-Known Member
    21 LR TRD PRO MT
    Maxxis Militia
    If you leave your hitch on for long enough, it'll rust into place and not even the force of God will be able to remove it.
  9. Dec 15, 2020 at 9:40 AM
    aboyz
  10. Dec 15, 2020 at 10:06 AM
    aboyz
    do you know the brand you use for both?
  11. Dec 15, 2020 at 10:15 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Are you looking for a lock to secure the hitch to the receiver on the truck?
    And a wheel lock for the trailer? Or a lock for the spare tire on the truck? Or a lock for the spare tire on the trailer?
    You can find this type of stuff on RV websites. Many choices.
    In my experience, the best method is simple. Remove the hitch when not in use, locking pin when in use. Ball lock on the trailer when not in use, remove the chains and tires. When trailer is in use, a lock on the ball lever.
    Rock Lobster likes this.
  12. Dec 15, 2020 at 12:22 PM
    zoo truck
    None
    Their all fulton's, the trucks receiver's 5/8'' pin looks like a rod going offset into a cigarette lighter...the coupler on the trailer is one of those gorilla trailer coupler locks, same for the couplers latch lock which appears made from brass. Their all over 20 years old...been with me on long sled trips and in ocean water. They still work perfect. If your asking me the model numbers...been too long to remember.
  13. Dec 15, 2020 at 12:27 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    zoo truck likes this.
  14. Dec 16, 2020 at 6:48 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    I just use a long lock on my trailer so it can't be stolen. I then use the same lock to lock it on the hitch.
    hfjeff likes this.
  15. Dec 16, 2020 at 7:13 AM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    - Purchased used vehicle that receiver had never been removed from hitch
    - Could not get receiver out so soaked with PB Blaster every day for a week
    - Could not remove receiver by pounding with sledge hammer on back of receiver
    - Wrapped chain around tree and hitch ball
    - Receiver would not budge so removed entire hitch from vehicle
    - Put hitch in 60 ton press to press out receiver
    - Bent square cross-member that connects side frame mounts
    - Bent it back
    - Cut open square tube in hitch where receiver fits and pried apart
    - Removed receiver
    - Welded tube back together and found receiver would no longer fit in hitch
    - Took entire hitch to scrap yard and got $1.xx
    Yes the pin was removed the entire time. :rofl:
    hiPSI, Wulf, R4D4G4ST[QUOTED] and 2 others like this.
  16. Dec 16, 2020 at 8:01 AM
    Knute
    There is the detail to support the reason to remove the hitch from the receiver.
  17. Dec 16, 2020 at 8:04 AM
    zoo truck
    None
  18. Dec 16, 2020 at 8:10 AM
    zoo truck
    None
    Its why i use a stainless steel receiver plug, and keep the male section and ball stored in the trucks cab. Been there, had it happen with my boats from loading, and unloading in saltwater.
  19. Dec 16, 2020 at 9:57 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I take the hitch out of the receiver. Takes two seconds.
    For the lock, I cut the shank off an old ball, put it in the tongue of the trailer and then locked it with a padlock.
    Sure, If the want to steal it they can, but it's going to take some effort.
    Lt. Dangle and hfjeff like this.
  20. Dec 16, 2020 at 9:59 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol fire wrench was needed.
