Recalibrate odometer/speedo for larger tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oldschoolczar, Jul 6, 2017.
  1. Jul 6, 2017 at 3:32 PM
    oldschoolczar
    oldschoolczar [OP] Well-Known Member
    '16 DCSB TRD OR
    Can this be done? I'm upgrading from 265/70/16 to 265/75/16. It's only an inch greater diameter and speedo errors are almost negligible, but the odometer errors will bug me much more.
    Seems like you can update in the navigation system but it sounds like that does nothing for the odometer.
    Really wanted to stick with the 265/70s but just couldn't find a tire I wanted in that size. Feel like I'm opening a can of worms here.
  2. Jul 6, 2017 at 3:34 PM
    TheAngryGinger
    TheAngryGinger Go Big Red
    Nebraska
    '17 TRD Sport
    Stock
  3. Jul 6, 2017 at 3:37 PM
    Clearwater Bill
    Billy
    Largo Florida
  4. Jul 6, 2017 at 3:42 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    i'm running your set up. imo, it is not worth the price. if you were going 35+ then maybe. just my opinion man
  5. Jul 6, 2017 at 3:47 PM
    oldschoolczar
    '16 DCSB TRD OR
    Yeah was hoping the dealer or independent mechanic (preferably) can do this. I'll likely only need to do it once if there's no rubbing with these tires (fingers crossed).
  6. Jul 6, 2017 at 3:48 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It's not possible to reprogram it on the Tacoma, you would need to add a module to alter the signal going to the speedometer.
    EDIT: See my below post, the speed signal on the 2016+ is actually sent from the Skid Control ECU to the Speedometer via the CAN bus, as such it might be more difficult to alter the signal than it was on 2015 and older trucks.
    Jeff
  7. Jul 6, 2017 at 3:50 PM
    ahkouchi
    Andrew
    Big Island Hawaii
    you shouldn't have any rubbing. i know lots of people that went 265 and are fine.
  8. Jul 6, 2017 at 3:51 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    OVtuning said he can compensate for larger tires built right into his ECU tune.
  9. Jul 6, 2017 at 3:54 PM
    Jeff Lange
    Calgary, Canada
    Interesting. I mean I guess it's possible if the Skid Control ECU pulls that calibration data from the Engine ECU, however the Engine ECU is not what sends the speed signal to the gauge cluster, and as far as I know OVtuning isn't tuning the Skid Control ECU.
    (Note: The Skid Control ECU does pull some calibration information from the Engine ECU when performing a zero-point or other calibration, but I didn't think this was one of the parameters).
    Jeff
    MESO likes this.
  10. Jul 6, 2017 at 3:56 PM
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    I'm running 285/75/16 with a 3" lift. According to the flashing speed reminders they setup beside the roads, my speedometer is 2 mph off. I just ignore it. If a cop writes me up for speeding 2 mph then he or she is having a slow day or had a fight with the spouse or something.
  11. Jul 6, 2017 at 3:57 PM
    oldschoolczar
    '16 DCSB TRD OR
    Cool thanks for the assurance. The stock tires were shit! And I gained a half inch of clearance. Woohoo!
    I'm really just concerned about incorrect mileage for service intervals and following detailed directions (e.g drive 4.1 miles and turn left).
    I guess if I record my mileage at the tire change I can always calculate true odometer reading.
  12. Jul 6, 2017 at 3:59 PM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    I found with the stock tires the speedo was reading high and then when I went to 265/75-16 it was almost dead accurate. Once I went up to 255/85-16 it started to be off noticeably over 30-35 and obviously got progressively worse until it was off by over 4-5mph at 70mph. Just gauging this from driving past the speed indicator signs on the side of the road.
    Edit: I always forget to check if its a 2nd gen or 3rd gen thread :facepalm:. I have a 2nd gen.
  13. Jul 6, 2017 at 4:48 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    same same, but different, but still same. you're good :thumbsup:
  14. Jul 6, 2017 at 5:06 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    check speed with a gps app on your phone. not a map app, but just a standard gps app that gives you velocity, altitude, etc. there are ton's of these for free. I like to use them when I'm on amtrack and trying to see how fast we are going. FYI, I've clocked the regular amtrack at up to 118 mph on straights out of NY pulling into CT and RI which surprised me. Anyway, They tend to refresh faster and be more accurate for speed since they just triangulte a few variables rather than calculating a few variables AND try to graph where you are on a map which causes a bit of a delay if your phone is a little older (like my iphone 5).
    I feel like I remember when researching btwn 2nd gen, third gen, types of lift etc, that some 2nd gen guys wrote that speedo did not change on 33 when checking with an accurate gps. Something to the effect that they felt that the truck was designed to have a tolerance up to 33? or something about how maybe the truck was designed for 32/33's?
    It was around march of last year that I looked this up so I may be wrong. I'm getting older and my memory is not as accurate. Anyway, check it with a gps app while you are driving.
  15. Jul 6, 2017 at 5:29 PM
    oldschoolczar
    '16 DCSB TRD OR
    It's even more fun to use your GPS app on an airplane! Can't always get a signal but when in a window seat you sometimes can. I got a GPS watch. Put it in cycling mode and watch it rack up like 8 miles a minute. It's pretty cool. I always try to figure out where I am and once I'm on the ground - and the map loads - it's fun to see how close I was.
  16. Jul 6, 2017 at 5:38 PM
    Hiker46
    Hiker46 Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    Another thing you can try is to set both your trip odometer and a gps trip to 0 and then drive. I found that after 200 miles in CO and UT my truck was biased around 2% low. The gps indicated 200 miles while the truck's odometer was around 196 mi. It's good to have relatively straight roads or at least wide turns. Interstates highways are good for this test.
    Arrampico likes this.
  17. Jul 6, 2017 at 5:48 PM
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    OP, Hypertech works. Also, see the link below for a guide as to how much your speedo may be off. Honestly, I have found that mine is always a little fast and a size bigger generally makes it dead on or so negligible until it doesn't matter.
    https://www.tacomaworld.com/tirecalc
  18. May 12, 2018 at 8:54 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Dead reckoning is always an option. For odometer difference you could drive a controlled route with the current tires. Drive that same route with the new tires. Compare the difference and establish your control number. Lets say you drove 45 miles with the old tires and the distance was 40 miles with the new tires. 40/45= .888... So 40/.888= 45ish.....Magic!
  19. May 12, 2018 at 9:12 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Just in case anyone is wondering, the reason why Toyota does not let you easily recalibrate is it throws the Odometer off as well. If they let you recalibrate, you could just tell the vehicle it has 20” tires on it, while keeping stock tires, and when you sell your truck with 300k miles on it, the Odo would only read 200k miles etc. It is for legal reasons it’s locked out.
    If you upsize your tires, without recalibration, you are actually reducing the accrued km on the odo, so it is a marginal win for resale.
    CaptainBart45 likes this.
  20. Jan 4, 2019 at 6:10 PM
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    Is this going to be a reality? I know there are big plans.
