Rebuild Throttle Body?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gpack, Dec 29, 2016.
  1. Dec 29, 2016 at 5:03 PM
    gpack
    gpack [OP] Tacoma Owner
    Hello all,
    I am currently experiencing the throttle body issue on my '04 Tacoma 3.4L.
    My situation:
    Cruising speed; lift foot slightly, but not completely off accelerator, and RPM's fluctuate going in more the downward direction than increasing and truck starts to dive slightly as if braking; no stalling or intense jerking going on. Upon pressing accelerator during the power fluctuation, no acceleration or transmission shift response. Pump a couple of times and it finally straightens up. I have noticed if I attempt to go to the floor, I am unable and met with resistance in the pedal only allowing me to go halfway down until it feels like a tennis ball is under the pedal and I am trying to compress it. I do not continue pressing as I am unsure what would be damaged.
    I have read much about the TPS and throttle body replacements due to this. As well, I have read about the 100+ pedal pump remedy. I will try the pump to see what happens. Otherwise, has anyone had experience or know if this semi-electronic throttle body on the '03-'04 Tacoma's can be rebuilt? What might be required to tackle the rebuild instead of purchasing a new TB to the tune of $900+ (best new I could find - not too thrilled about another used ($300+) and it possibly failing.)?
    Thoughts or other realistic remedies?
  2. Mar 9, 2019 at 5:42 PM
    gpack
    In the event anyone runs across this thread with the same issue...it was the throttle sensor mounted on the back of the throttle body. I followed a thread I found somewhere about removing that sensor, cleaning it up, tapping it gently, then replacing with loc-tite applied to new allen head bolts for easy removal in the future. The small phil heads can strip easy and cause a major problem with the TB housing and so on. I had a hickup a couple of times, but this throttle issue has not happened in quite a while. I even found an Asian supplier online that has these throttle sensors available, but seems to require a bulk order. Either way, it never resorted to that for me.
    otis24 and TacosConQueso like this.
  3. Mar 9, 2019 at 5:52 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Someone can chime in, In my research to fix my high idle, I saw that someone on this forum rebuilds them in Florida I think.
  4. Mar 9, 2019 at 8:27 PM
    1997tacomav6
    Denver
    Look to see if there is a gap between the the butterfly and the throttle body wall.
    If there is it needs to be fixed.
    http://www.maxbore.com/
    Can rebuild the throttle body by cleaning the whole unit in an ultrasound cleaner and installing a new
    Butterfly after the throttle body is bored out just a bit for 125.00
    But be warned he’s very busy and can take two - three weeks to do it.
    He took a month for mine to be fixed, luckily for me the one he rebuilt is a spare
    So I didn’t have any down time
    Sebz13 likes this.
