rebuild kits 5vze and a340 transmission
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kirbdog, Oct 27, 2022.
  1. Oct 27, 2022 at 10:47 AM
    Kirbdog
    Kirbdog [OP] New Member
    Florida
    2001 tacoma 5vze 4x4 286,000 and counting
    cold air intake, leveling kit, hy Flo-cat back exhaust.
    Hello all,
    My 5vz has 285k miles and compression is reading around 100 for half the cylinders. she still runs and I still drive her all over the country, she really is a good truck. with that said I think its time for a rework of the engine and tranny.
    Ive thought about getting a JDM engine and swapping it, but they seem to be harder to find and in reading there is not much confidence that JDM engines are as "new" as they claim.
    with that said. I am looking for suggestions on good quality rebuild kits for the engine and transmission. OR a quality supplier of JDM engines that I can have confidence in.
    I plan on keeping this truck for a long time so I'm not trying to do it on the cheap.
    I know there's prob another thread with this so point me that way if you will, OR ill take the suggestions.
    Cheers,
  2. Oct 27, 2022 at 10:59 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Welcome to TacomaWorld... Curious as to why you feel the transmission needs to be rebuilt/refreshed. AT or MT? Any issues from your transfer case?
  3. Oct 27, 2022 at 11:02 AM
    Kirbdog
    Florida
    auto trans: a340f. Really the tranny doesn't have any major issues still shifts smooth enough and I drive it everywhere. it has a small leak from the transfer case. I figured if I was doing a power overhaul and the trans was out, it would be the time to overhaul it.
    Area51Runner likes this.
  4. Oct 27, 2022 at 11:10 AM
    Area51Runner
    If it's not giving you any issues, I'd say leave it alone aside from a drain/fill. @gearcruncher might be able to suggest anything he would do if it were out.
    As for the transfer case, leaking is definitely something I would address. I'd pull it and replace the seals for sure.
    Cheers to an 01 with 285k and still going strong.
    :cheers:
    MalinoisDad likes this.
  5. Oct 29, 2022 at 10:54 AM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    If you have low compression start thinking about head gasket and valve job, or refurb heads. Also check your valve clearances if you never have they are probably out on the exhaust valves. if rest of engine is good I’d probably leave it be
    Black DOG Lila likes this.
  6. Oct 29, 2022 at 1:56 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You really have no idea just what your going to need till the engine is out and inspected,
    You could just decide to bore the block as much as possible and cut the crank without inspecting spending more money then needed.
