Reattached A/C knob not changing temp
Discussion in '1st Gen. Tacomas (1995-2004)' started by 00PreRunner, Aug 2, 2018.
  1. Aug 2, 2018 at 7:34 AM
    00PreRunner
    00PreRunner [OP] Well-Known Member
    Jackson, MS
    '05 DCSB 4x4
    2005 DCSB, 4x4, Auto. more to come...
    Ok, so the other day, the temp control knob fell off my dash. When I tried to put it on, it felt loose and did not want to stay. I tried to glue it back, which worked, but the knob would not change the temp of the A/C. I eventually pulled the servo out, and looked at it. It will not hold a position unless I keep pressure. I'll post a video to help explain. My question is this:Could the servo itself be bad, or is the knob messing this up? Thanks!.
  2. Aug 2, 2018 at 7:37 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Try this first.
    https://www.tacomaworld.com/threads...ssible-aftermarket-part.500522/#post-16582776
    Not sure if it will help you. It sounds to me like it worked before you messed with the knob. Now that it's permanently affixed, who knows it the part that turns to control your AC is broken or what. You should feel a slight amount of resistance and some bumps as you're turning the knob. If it feels loose then I would assume something is wrong with the HVAC control unit or the way in which you ghetto-fixed your knob.
  3. Aug 2, 2018 at 7:45 AM
    00PreRunner
    Jackson, MS
    '05 DCSB 4x4
    Thanks. And I agree, the knob seems to be when this started. But the knob is back off the temp control. I can still turn the part the knob attached to, and it has that "bumpy" feeling. But the servo arm will not move until I turn the temp control counter-clockwise all the way, and hold pressure on it.
  4. Aug 2, 2018 at 7:48 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    Would you kindly remove the all-caps "Please Help!!!" from your title? Those words are reserved for people who are in actual need of emergency help, like stranded in a remote location or like what happened just a few days when a person went missing. Thanks.
  5. Aug 2, 2018 at 7:49 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Sorry, not helpful. Or maybe it is.
    wilcam47 and Dalandser like this.
  6. Aug 2, 2018 at 8:01 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    That...is...funny.
    Living in Dallas, I sometimes wish I had that setup...:rofl:
  7. Aug 2, 2018 at 8:02 AM
    tony2018
    tony2018 Well-Known Member
    Yeah its messed up.
  8. Aug 2, 2018 at 8:04 AM
    00PreRunner
    Jackson, MS
    '05 DCSB 4x4
    Well, if I wasn't about to sell the truck, this could be a solid route to take ha.
  9. Aug 2, 2018 at 8:59 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Looks to me like its in the a/c controller. Could just be a broken solder joint. You can carefully disassemble it and check the pins of the rheostat for broken solder joints.
    License2Ill and ThunderOne like this.
  10. Aug 2, 2018 at 10:34 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    And if you don't want to do that, you should be able to get a used HVAC control unit on eBay.
    00PreRunner[OP] likes this.
  11. Aug 3, 2018 at 7:22 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    seems odd, yes. does the knob have the metal shim inside still? this is what holds it on the stem and allows it to turn.
    can you turn the stem itself and get results (sans knob)?
  12. Aug 3, 2018 at 7:44 AM
    00PreRunner
    Jackson, MS
    '05 DCSB 4x4
    Yes I can turn the stem with no knob The servo won't adjust until I turn the stem all the way and hold pressure on it
  13. Aug 3, 2018 at 10:01 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    ok, just wanted to make sure and cover all bases.
    might be easier to just get a used unit :(
  14. Aug 3, 2018 at 8:04 PM
    Richard face
    Richard face Active Member
    Charlie
    Manteca, California
    This happened to me and I changed out the heater control cluster and everything is good now
