Rear Traction Bars?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UluaHuntah34, Jun 7, 2020.
  1. Jun 7, 2020 at 12:06 PM
    UluaHuntah34
    UluaHuntah34 [OP] Well-Known Member
    2008 Tacoma 6inch Lift, 2 inch body lift, on 37s
    Anyone got some recommendations for a good rear traction bar?
  2. Jun 7, 2020 at 3:12 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    If you're handy, you can create your own. Fully adjustable, no ground clearance issues.
  3. Jun 7, 2020 at 3:38 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If you saw how much the axle wrapped down under engine braking / braking in general, you would NOT run those.
  4. Jun 7, 2020 at 3:43 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Avoid the ones that attach to the diff carrier bolts. They can tweak the flange and cause leaks.
  5. Jun 7, 2020 at 4:08 PM
    jbrnigan
    Midwest
    Unfortunately, this site won't let me post the video I made of the traction bar under acceleration and braking, so , just let me say - I HAVE seen how much the axle wraps under both acceleration and braking! I do understand what you are referring to, but in this case, you just have an opinion not based on any personal observation of this particular installation.
  6. Jun 7, 2020 at 6:37 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Cal tracs
    hresendiz25 likes this.
  7. Jun 8, 2020 at 9:41 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    I have seen quote a few post for bud built traction bars. I know nothing about them, but seem to be good words when I've seen them talked about.
  8. Jun 8, 2020 at 9:49 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    What problem are you trying to solve?
  9. Jun 8, 2020 at 9:56 AM
    su.b.rat
    su.b.rat broken truck
    truth.
    see above, regarding the weld on version. and then this:
    https://www.tacomaworld.com/threads/crazy-leak-from-the-rear-end-overnight.548948/
    it's a good bar for certain. but it needs skilled fab work to properly mount or it's a full on liability.
  10. Jun 8, 2020 at 9:56 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    calvert racing, highly recommended in the diesel scene, though I'm not sure if they make them for Tacomas.
    BassAckwards likes this.
  11. Jun 8, 2020 at 10:01 AM
    BassAckwards
    They do, they call them cal-tracs. Have been considering a set for my taco
    coopcooper[QUOTED] likes this.
  12. Jun 8, 2020 at 10:03 AM
    nd4spdbh
    SoCal
    Had one on my truck (weld on) it was hardly close to a solution and hardly close to an easy bolt on solution at the cross member.
    Poly joints at the rear still flexed way too much, and the cross member that the shackle bolted to is the flimsiness thing ever, not to mention the shackle bracket needed LOTS of massaging to actually work on the crossmember as well as the traction bar itself had to be clocked out of the way to clear the stock exhaust.
    10/10 would not recommend, just build you own at that point.
    su.b.rat likes this.
  13. Jun 8, 2020 at 12:25 PM
    su.b.rat
    my experience with the driving was not as poor as yours, it did quite a bit to plant the rear, and i toss my truck hard. but that's the thing. it lasted less than a week. lol. so you are 100% right.
  14. Jun 9, 2020 at 10:09 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Cal-tracs is what most everyone that drag races in vintage performance cars has been using for many years. They're vastly superior to the generic "slapper" bar design from 1970. I had no idea people would want to put them on a Tacoma, but whatever.
  15. Jun 9, 2020 at 10:25 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Damn. Axel Wrap is one of the biggest complaints I have. Even with Deavers it’s super annoying.
    I already have the RuffStuff DIY kit to put one together and made plenty of room with a Borla muffler.
    What can go wrong using a traction bar?
  16. Jun 9, 2020 at 10:39 AM
    nd4spdbh
    SoCal
    If you are using the stock center carrier cross member without significant reinforcement you need to start planning to get some in there asap.
  17. Jun 9, 2020 at 10:41 AM
    su.b.rat
  18. Jun 9, 2020 at 10:55 AM
    nd4spdbh
    SoCal
  19. Jun 9, 2020 at 11:37 AM
    Shortman5
    Supercharged TRD
    I mean. I didn’t get that BudBuilt junk. No way am I going to bolt it on to the diff.
    Mine is going to sit on the other side of the muffler but it’s also going to be welded all the way around each bracket.
    So as long as I have it away from the diff bolts and it has plenty on weld what other issues?
