Rear tires skipping when turning right and accelerating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yota-xsr, Mar 25, 2021.
  1. Mar 25, 2021 at 5:05 PM
    Yota-xsr
    Yota-xsr [OP] Member
    Billy
    00', V6, 4x4,
    Running trd 4runner wheels w/ 265/70/17 tires. Everything else in the rear is stock. When accelerating from stop and turning right my rear tires will abruptly skip and not catch unless i am gentle on the throttle. Its really only on really tight turns.
    Is my differential messed up?
    Wheel/tire too big?
    Anyone else experience this or what do you guys think?
  2. Mar 25, 2021 at 5:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Odd.
    Did you, or anyone install a lunchbox locker in the rear?
    BassAckwards and Taco critter like this.
  3. Mar 25, 2021 at 5:31 PM
    Glamisman
    Glamisman Well-Known Member
    check to see if you have the rear differential lock button pushed. if there is no RR Diff lock button lift the rear of the truck off the ground and see if you can spin a rear tire by hand. If you can and the other tire rotates backwards then you have a weird problem. If you cant then you have some sort of a locked differential.
    DK117 and Taco critter like this.
  4. Mar 25, 2021 at 5:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Unless someone did the grey wire mod, locker shouldn't be able to activate without being in 4L.
    But I do see where it's important to ask this question.
  5. Mar 25, 2021 at 5:46 PM
    Yota-xsr
    Billy
    00', V6, 4x4,
    Ok ill check. Only acquired the truck last year and as far as I know nothing was swapped on the rear end. It definately feels like its locking and both wheels trying to spin together.
  6. Mar 25, 2021 at 5:56 PM
    Yota-xsr
    Billy
    00', V6, 4x4,
    I jacked up the truck and one wheel spins forward and the opposite spins backwards. Now what lol
    The truck was in gear btw when i did it not sure if that matters.
  7. Mar 25, 2021 at 8:04 PM
    Yota-xsr
    Billy
    00', V6, 4x4,
    Ok. When i bought it the diff fluid was clear like it just been changed so i left it. Maybe previous owner put the wrong fluid in. Gonna change it with 75w90 and see if it clears it up
    Wulf likes this.
  8. Mar 25, 2021 at 8:30 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    That is the expected behavior for an open diff.
    How'd it smell? gear oil is stinky, even when new
  9. Mar 25, 2021 at 10:03 PM
    Yota-xsr
    Billy
    00', V6, 4x4,
    How'd it smell? gear oil is stinky, even when new[/QUOTE]
    Yeh it smelt like shit.
  10. Mar 25, 2021 at 11:02 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    How is the general condition of the suspension?
  11. Mar 26, 2021 at 8:05 AM
    Wulf
    rock raisin
    what tires? first truck? it's really easy to spin the tires on an unloaded pickup
    MalinoisDad, jbrandt and AmherstAndy like this.
  12. Mar 26, 2021 at 8:34 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I came here to say or ask, is the right tire just "spinning" when accelerating or is it "jumping" causing a bounce?
    if spinning, then quit gunning the dam pedal when turning sharp :notsure:
  13. Mar 26, 2021 at 8:42 AM
    Clearwater Bill
    Billy
    Largo Florida
    You have a Torsen diff out of a Miata. :D
    Or you have typical Tacoma weak springs, fair tire grip and resulting wheel hop when weight load is reduced over that tire. (Hard right loads left)
    Changing the diff lube will do nothing for your normal acting rear. Save your time/money.
    Yota-xsr[OP] and Wyoming09 like this.
  14. Mar 26, 2021 at 1:25 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    With my 2.7 I can spin rear tires from the dead stop while on the sharp turn every time. That's normal. With front wheels turned sideways you put big load on the rear wheels which try to push truck forward.
    Like @frizzman wrote
    onakat and frizzman[QUOTED] like this.
  15. Mar 26, 2021 at 1:59 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If by "Everything else in the rear is stock" you mean everything is original, then your 21 year old rear shocks are almost certainly completely shot.
    Worn out shocks don't hold the tires to the road very well
    https://www.youtube.com/watch?v=0sgOf3js2FY&t=8s
    But I'm willing to bet you're also just gassing it too much. Pickup trucks have effectively ZERO weight over the drive tires. Which means zero traction.
    Yota-xsr[OP], onakat and RysiuM like this.
  16. Mar 27, 2021 at 6:15 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    That's not going to tell you jack shit. A lot of non-selectable AKA lunchbox lockers will behave as an open differential when they're coasting and there's no power being applied. Do a couple hard launches in loose dirt and see if both tires are spinning out. Maybe have a friend watch. But it sure sounds like you have a lunchbox locker.
  17. Mar 27, 2021 at 8:02 AM
    Yota-xsr
    Billy
    00', V6, 4x4,
    I just put in new kyb monomax shocks.
  18. Mar 27, 2021 at 8:10 AM
    Yota-xsr
    Billy
    00', V6, 4x4,
    Michelin ltx defender 265/70/17.
  19. Mar 27, 2021 at 8:15 AM
    Yota-xsr
    Billy
    00', V6, 4x4,
    I think your right on the money!
  20. Mar 27, 2021 at 8:18 AM
    Yota-xsr
    Billy
    00', V6, 4x4,
    So after all considering all comments. I believe everything is fine. And it turns out im partially retarded.
