Rear tire wobble!
Discussion in '1st Gen. Tacomas (1995-2004)' started by CRiz, Oct 29, 2013.
  1. Oct 29, 2013 at 6:38 PM
    CRiz
    CRiz [OP] Well-Known Member
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    So today I happened to glance at my passenger rear tire and I noticed that my rear tire had a very slight wobble. I checked it out and it happens at all seems and doesn't get any worse or better at different speeds. Last week I change my brakes so I'm thinking that maybe the tire was put on a little sides ways or something. I checked all the bolts today and they seemed to be tight but I only checked them with my hands. I also checked and the tire is not cupped. The only think i did with the truck is hit a curb in a parking lot but it wasn't anything crazy. Is there anything else I can check? Also I won't be able to take the tire off till Thursday so I'm wondering if it's okay to drive to school and work?
    Thanks guys:)
  2. Oct 29, 2013 at 6:47 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Get out the lug wrench and make sure they are tight. It's your life, don't be lazy. Use a star pattern.
  3. Oct 29, 2013 at 7:32 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    And a torque wrench
  4. Oct 29, 2013 at 7:34 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I assume him being a student he might not have one. Any kind of wrench is better than fingers, but torque wrench if you can. 83 ft-lbs.
  5. Oct 29, 2013 at 8:13 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Just check the lugs and they seemed to be tight, none of them seem to even be slightly loose.
  6. Oct 29, 2013 at 10:02 PM
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    I'm willing to bet either bent rim or out of balance.
  7. Oct 29, 2013 at 10:10 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Stock wheels or aftermarket? Hubcentric or lugcentric?
  8. Oct 29, 2013 at 11:49 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Could just be the radial run out of the tread as well.
  9. Oct 30, 2013 at 8:24 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    The tires are Goodyear wranglers. I'm not sure what the rim is but it's aftermarket too.
    ( sorry just boughtThe truck). And I believe they are hubcentric but I'm not 100% sure!
  10. Oct 30, 2013 at 8:26 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    One of the weights on the rim is chipped a little but not more than an inch. I wonder if this can throw it out of balance?
  11. Oct 30, 2013 at 11:49 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    I was towing my boat once and happened to look back to see one of the trailer wheels had a massive wobble to it. Stopped in at Les Schwab and they took a look at it...and then told me it was a good thing I brought it in because the tire had separated internally.
    I'd definitely get this figured out and taken care of ASAP before something catastophic happens.
  12. Oct 30, 2013 at 12:06 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Yeah I didn't drive my truck today. I'm gonna put it up on the lift tomorrow and check it out and see if I can get it figured out. If not I guess I'm gonna have to take it in
  13. Oct 30, 2013 at 2:04 PM
    BamaToy1997
    Bill
    Navarre, FL
    Swap front wheel with rear. If the wobble moves, it is most likely a bent rim, or really bad tire. If wobble remains then you may have a bent axle or axle housing flange.
  14. Oct 31, 2013 at 5:06 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    So I switched the tires around and the problem is still true to just the right side. So I'm guessing it's an axle problem, anyone have an idea of how much this will cost me?
  15. Oct 31, 2013 at 8:56 PM
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    do you got a locker? I am buying a complete rear end witch is easier to bolt in for $550. If i was buying a regular complete rear end i wouldnt pay more then $200
  16. Oct 31, 2013 at 9:51 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    No i don't
