Rear Speakers low/no bass
Discussion in 'Audio & Video' started by bismarck, Apr 12, 2023.
  1. Apr 12, 2023 at 12:14 PM
    bismarck
    bismarck [OP] Well-Known Member
    2023 TRD Off Road
    So I upgraded my speakers. No, I was stupid and didn't do a sound check on each speaker. I'm dumb.
    I bought these for fronts https://www.crutchfield.com/p_20647KSS69/Kicker-47KSS6904.html
    and these for rear https://www.crutchfield.com/p_575R1675X2/Rockford-Fosgate-R1675X2.html
    I had to do some modifications of the wiring, to run the harness from the tweeter input to the crossover.
    I got this harness included with the setup
    I was sent this pic to alter the harness so it would work with the other (front) speakers.
    I conncected everything and if I put the sound full rear, I get the highs, but low/no bass out of the speakers. I would assume they'd have the ability to pump out sound, but they sound like garbage.
    Here is the crossover that's included
    Also got harness to go from factory wiring to speaker.
    I went and took apart the rear doors again, and swapped the inputs but to no avail.
    Still sounds like garbage.
    Any thoughts?
    If I had a speaker wiring diagram I could troubleshoot it, but I have no idea if there's one out there in the wild.
  2. Apr 12, 2023 at 12:19 PM
    bismarck
    2023 TRD Off Road
    I did cut the harness provided and capped off the unused end of the loop, then connected them to the cross over woofer outputs.
  3. Apr 12, 2023 at 5:11 PM
    bismarck
    2023 TRD Off Road
    After doing some looking, it appears the rear comes directly from the HU. So stuck with crappy sound unless I want to amp it.
  4. Apr 12, 2023 at 5:30 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Rear speakers get about 3 watts of power from the radio. Your new speakers probably sound even worse
    Dkurtz42 likes this.
  5. Apr 12, 2023 at 5:43 PM
    bismarck
    2023 TRD Off Road
    They really do. lol
    is there an easy way to connect the factory HU and speaker wiring to an aftermarket amp?
    easy = plug and play.
    I can do the total rewire, but would like to get something premade and ready to go.
  6. Apr 12, 2023 at 5:48 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Call crutchfield. They have solutions to this problem. Dude actually laughed and knew I had a Tacoma when I told him the issue.
    bismarck[OP] likes this.
  7. Apr 12, 2023 at 7:23 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    honestly the rear speakers even with moderate power never sound great.
    imo, the rear speakers are a waste of money/effort.
  8. Apr 13, 2023 at 2:55 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Signal for rear:
    soundman98 and bismarck[OP] like this.
