Rear slide window security
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jan 6, 2012.
  1. Jan 6, 2012 at 10:30 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    Any ideas out there on how to secure the rear sliding window? Can I put a metal stick or something in the channel that the window slides in?
    Thanks.
  2. Jan 6, 2012 at 10:31 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    that sounds good to me. i don’t see why you could not do that.
  3. Jan 6, 2012 at 10:32 PM
    drtydru
    drtydru Well-Known Member
    Dru
    Oakland
    08 4x4
    Bucket seats, Variable speed wiper switch, 09 led Tail Lights, Satoshied front grill, DDM HIDs, Fog light install, Mud flaps removed, 1.5'AAL, Billie 1552, Toyotec front coilovers w/Billies, B.A.M.F welded sliders w/kickout,
    Glock?
  4. Apr 30, 2012 at 7:33 AM
    AlerAero
    AlerAero Equipment MFG
    Northern Vermont
    09 Tacoma V6 SR5 4x4
    BakFlip Folding Tonneau, Locking bed storage compartments, Bug/rock guard, Anytime backup cam mod, Hitch + wiring
    SS rod in the channel is what I did! I looped one end so it was easy to take out!
  5. Apr 30, 2012 at 7:35 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    I accidently broke one of my cb antennas so i reused it by cutting it to length and putting it in the track
  6. Apr 30, 2012 at 8:04 AM
    mytundra77
    mytundra77 Member
    So Cal
    08 Double Cab Taco
  7. Apr 30, 2012 at 8:07 AM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    When it comes down to it, its just glass....they will break it if they cant slide it open.:confused:
  8. Apr 30, 2012 at 8:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Get a shell :D
    Personally, I can't fit through the rear slider if it is open. Also, if someone is going to break into your truck, do you honestly think they'll mess with the rear slider or just break the driver's side window? Something small and thin that sits in the track and is unable to be seen will prevent the window from being slid open but they will probably break the slider in the process.
  9. May 1, 2012 at 10:13 AM
    easyeatlanta
    Eric
    Memphis
    14 DC Trd Off Road
    I know several people who have been broken in through the rear window so that is a real concern
  10. May 1, 2012 at 11:46 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Maybe some kind of bar across the middle of the window that can be removed when you don't want to use it?
  11. May 1, 2012 at 12:01 PM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Here is the problem with making things too secure. If some low life wants to break in, he is going to. The more secure you make it, the more damage he causes in the process. Personally, I would just use the factory latch.
