Rear shocks after 2 inch block lift
Discussion in 'New Members' started by Scuba60, Dec 31, 2018.
  1. Dec 31, 2018 at 8:21 AM
    Scuba60
    Scuba60 [OP] Member
    2016 Tacoma sport Trd white
    3 inch lift , duel exhaust stainless
    Hello guys . 6th Toyota truck however first gen 3 2016 trd sport . My question is . With a two inch rear block kit (lift) do you suggest replacing rear shocks ?? . I am also dealing with the the alignment of front end . Any suggestion on settings . My alignment shop says can only set to factory specs and I’m sure that will burn through tires . Thanks for any input
    irayfz6 and TXpro4X4 like this.
  2. Dec 31, 2018 at 11:34 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW...have you considered taking your truck to another alignment shop?
    irayfz6 likes this.
  3. Dec 31, 2018 at 11:42 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Many people dont replace the rears but I can tell you it going to ride like crap if you use the stocks on blocks.
    Also take the truck to another shop if possible as stated above.
    tcjacado and irayfz6 like this.
  4. Dec 31, 2018 at 12:07 PM
    Scuba60
    Scuba60 [OP] Member
    Sounds like I need to . Thanks for the advice . Love the truck
  5. Dec 31, 2018 at 5:28 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    tcjacado and buckhuntin-tacoma like this.
  6. Dec 31, 2018 at 5:46 PM
    Scuba60
    Scuba60 [OP] Member
    Thank you ireyfz6
    irayfz6 likes this.
  7. Jan 3, 2019 at 1:38 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    irayfz6 likes this.
  8. Jan 3, 2019 at 2:01 PM
    Scuba60
    Scuba60 [OP] Member
    Thank you
    irayfz6 likes this.
  9. Jan 3, 2019 at 2:05 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW!
    The stock uca's will limit the alignment specs to only really allow factory specs.
    irayfz6 likes this.
  10. Jan 3, 2019 at 2:13 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Two inch lift on the rear end? Consider extended rear brake lines.
    Firestone told me they can only do an alignment on what’s “in the computer”. I put on PRO takeoff coil overs so I tell them to do a PRO alignment.
    irayfz6 likes this.
  11. Jan 3, 2019 at 5:10 PM
    Scuba60
    Scuba60 [OP] Member
    So I finally was able to get the alignment were it needs to go . I’ve ordered the rear shocks to compensate the rear two inch blocks . Now I have a drowning noise left front . 30-50 mph - felt in steering wheel ,and pedals . Not consistent with a rotational of tires however Sounds like a bad tire would with a (noise stop noise stop )pattern . Tires have 1200 miles on them with no chop .truck has 15k . I have 285/70 17 tires and Halo rims going on this weekend . But this noise bothers me . Any input note -started after lift was installed 3 inch front - two inch block back
    irayfz6 likes this.
  12. Jan 4, 2019 at 8:47 PM
    Montanahunter
    Montanahunter Well-Known Member
    Zhaun
    Helena Montana
    2009 DC TRD off-road
    OME lift Stealth custom wheels ARB bullbar Allpro Apex sliders Prismo design roof rack.
    Sounds like you may need a ECGS bushing for the left front side of your diff. This is a slight design flaw in the 8" clam differential. This seems to be a more of a problem after you lift because the cv shaft angle is steeper. The bushing cost $60 plus freight from ECGS. There is a whole thread about this issue. It's not entirely harmful so keep driving but if you put too many miles on you mat need to replace your CV axle shaft when you do the bushing.
    irayfz6 likes this.
  13. Jan 4, 2019 at 8:50 PM
    Montanahunter
    Zhaun
    Helena Montana
  14. Jan 4, 2019 at 8:57 PM
    Scuba60
    Scuba60 [OP] Member
    Montana hunter thank you so much for the link I’ll order that this weekend . Was concerned it was a major issue . NewHampshire Woods is waiting and I need the Taco to be healthy
    Montanahunter and irayfz6 like this.
