Rear Shock Bushing Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by pray4surf, Nov 7, 2018.
  1. Nov 7, 2018 at 10:31 AM
    pray4surf
    pray4surf [OP] Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    I'm running a pair of Bilstein 5125's on the rear of my 98 taco - I've got no complaints - but the rubber(?) bushings are shot and I need to replace them (top and bottom / both shocks).
    Does anyone have part number / vendors for these items?
    Specifically, the stickers on the shocks read (drivers side) F4-BE5-6525-H5
    I'm hoping to source the bushings prior to removing the shocks.
  2. Nov 7, 2018 at 10:58 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Wheeler's off road has them and will take care of you
  3. Nov 7, 2018 at 11:33 AM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2013 acces cab TRD offroad M/T 4wd
    If you get the poly bushings make sure they have the 3/4" holes. The last set of Bilstein 5125 shocks I bought came with 5/8" bushings and didn't fit the rear of my Tacoma so I had to replace the bushings.
  4. Nov 7, 2018 at 12:00 PM
    pray4surf
    Rick
    Oceanside, CA
    Already been in touch with Wheeler's and no dice if you have a part number I'd appreciate it.
    I'm aware of the 3/4" ID - Does that apply to both ends (top/bottom)?...
    I'm looking at 2 diff Energy Suspension items which might fit the bill
    98108 or 98109
    I'm pulling the shocks Saturday... I'm hoping 4wheelparts near me will have what i need
  5. Nov 7, 2018 at 2:05 PM
    NCJeyota
    Raleigh,NC
    part number I bought was 98108 and they come 2 to a pack. top and bottom are the same
  6. Nov 7, 2018 at 2:54 PM
    pray4surf
    Rick
    Oceanside, CA
    jammer likes this.
  7. Jul 25, 2020 at 7:56 AM
    Toadfishjax
    Toadfishjax Member
    Chad
    Jax, Fl.
    15 Tacoma TRD 4x4
    31 Maxxis Buckshot 2s, Yaesu ham radio, K&N CAI
    I know this is an old thread but i had this problem today and i contacted bilstein. Heres the email i got back
    Hi Chad,
    The 5125 shocks are universal and are not a direct bold on shock. In many cases some modifications may need to be made to the shock itself or the mounts on the truck.
    Have you tried to spread the shock tabs on the axle a bit to get the shock into the mount? Also you can grind the side of the bushing sleeve down a bit if needed as well.
    Thanks.
    Mit freundlichen Grüßen / Best regards
    John Trexler
    So if you are like me and got pissed because they didnt go on easy, take a breath and get out the grinder. So i used the bolt for the shock mount to press in the silver sleeve then trimmed the bushing back to the sleeve with my utility knife (classic 199 ) . Then i got the grinder out and took about an 1/8 an inch off each side. Fit like a glove!
    Im hope this info helps somebody out one day
  8. Jul 25, 2020 at 9:34 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Do you know if these will fit the Bilstein 5100’s?
  9. Jul 25, 2020 at 9:36 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Same
    jammer[QUOTED] likes this.
  10. Jul 25, 2020 at 9:37 AM
    jammer
    Ben
    Bentonville, AR
    Awesome. Thank you for the fast reply!
    GQ7227 likes this.
  11. Jul 25, 2020 at 12:56 PM
    jammer
    Ben
    Bentonville, AR
  12. Jul 25, 2020 at 4:16 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i need front shock bushings not rears. havent found an exact replacement for the front. they are vulcanized in and arent meant to be replaced
  13. Jul 25, 2020 at 5:08 PM
    jammer
    Ben
    Bentonville, AR
    Well I’m glad you said that because I thought maybe they would fit the front. I’d like to have a set if I need to replace the ones on my 5100s located on the front.
    If you find some please let me know.
  14. Jul 25, 2020 at 5:12 PM
    devinzz1
    devin
    2023 aclb trd or mt
    probably just gona ditch the 5100s. they suck anyways
