rear shock bolts.......dab of blue thread locker or dab of anti seize??
Discussion in '1st Gen. Tacomas (1995-2004)' started by yarb71, Jul 21, 2020.
  1. Jul 21, 2020 at 10:55 AM
    yarb71
    yarb71 [OP] Well-Known Member
    Looks to be about 53ft torque. Getting ready to horse these down. Some say Anti Seize ..some say Blue Locktite....
    nobody seems to agree.
    Thoughts? I have both..just wondering which i should use.....
    maybe it doesnt matter....
  2. Jul 21, 2020 at 11:45 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    I would only use Anti-seize and torque them, then re-torque them after 500 miles. In my opinion, blue loctite is overkill just for the rear shocks. I would only use loctite on more important areas like the front suspension.
  3. Jul 21, 2020 at 11:48 AM
    paetersen
    paetersen Well-Known Member
    SoCal=loctite
    everywhere else=antiseize and pray you can get it undone next time you replace shocks.
    Nessal, slander, Bivouac and 4 others like this.
  4. Jul 21, 2020 at 11:48 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    gotta give my pure mid west taco new rear shocks for the 1st time in like ever!
  5. Jul 21, 2020 at 12:52 PM
    yarb71
    im not sure its that hard to get blue loctite undone. Ive never had an issue. The red stuff is much much stronger but i would never use that anywhere.
  6. Jul 21, 2020 at 12:57 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    I use anti seize on just about everything that isn’t an internal part of a gear box or engine with a few exceptions here and there. I’d personally put anti seize on the shocks because they take a lot of abuse from mud, water and road grime, but to each their own.
    billybop90 and Wyoming09 like this.
  7. Jul 21, 2020 at 12:59 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Anti seize
    billybop90 likes this.
  8. Jul 21, 2020 at 1:16 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    My motorcycle is held together by blue loctite, but I hardly touch that tube with the truck. Anti-sneeze all the things.
    Shellshock likes this.
  9. Jul 21, 2020 at 1:34 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    anti seize and still cut them off
    GQ7227 likes this.
  10. Jul 21, 2020 at 2:05 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Amen, Brother!! If I have an exposed bolt end, beyond the nut, I will even paint that with anti-seize. It's just the way of life in the rust belt.
    ToyotaDriver[QUOTED] likes this.
  11. Jul 21, 2020 at 2:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Interesting.
    Nothing on mine and I refuse to.
    TnShooter and GQ7227 like this.
  12. Jul 21, 2020 at 2:17 PM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    I should own stock in anti-seize, use the stuff on everything. Your bits and pieces down below will love you for it.
  13. Jul 21, 2020 at 2:54 PM
    yarb71
    yeah a little goes a LONG way. I got a tube 20 years ago.....and i still use it on everything and have plenty left. Probably last the rest of my life.
    billybop90 and Kevins60 like this.
  14. Jul 21, 2020 at 2:56 PM
    0xDEADBEEF
  15. Jul 21, 2020 at 2:59 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Geez I cant imagine putting Loctite on anything. Rust gives me a hard enough time.
  16. Aug 23, 2022 at 11:32 PM
    MadeFromMetal
    MadeFromMetal New Member
    '02 Jeep GCL (WJ) 4.7L V8 4x4, daily
    Loc-tite Threadlocker Blue 242 isn't permanent, it's very easy to wrench off. Blue only requires 100 Ft-Lbs of torque to break. It's Red Threadlocker that's permanent and requires torching the bolt to lower required torque from 450 Ft-Lbs to 130 Ft-Lbs.
    Purple threadlocker is only 50 Ft-Lbs but is for smaller fasteners.
    Threadlocker acts as Anti-Seize on bolts, protecting them from corrosion.
    It's honestly beneficial if you have a good impact wrench to breakaway bolts with Blue threadlocker.
    But I don't use threadlocker on my suspension because it messes up torque readings making you have far too much or far to little torque on important suspension parts like U/LCA's, Sway Bars and Links, Shocks, Tie Rods/Track.
    I do use it on Steering parts like the knuckle and shit I don't want to ever come loose or rust inside the threads.
  17. Aug 24, 2022 at 8:51 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Older thread I buy never seize by the case!
    I have never used any thread locker
    MadeFromMetal[QUOTED] likes this.
  18. Aug 26, 2022 at 2:56 PM
    MadeFromMetal
    Out of curiosity, what kind of Anti-Seize do you use? Frankenstein, Copper, Graphite or Pure Nickel base?
    I'm picking up Nickel Anti-Seize for my rear shocks and Sway Bar links. I normally used Orange hybrid high strength gel threadlocker by Permatex or Blue Loctite 242 for front vital steering bolts and some problem child suspension areas like the Sway Bar Link on my 02 Jeep Grand Cherokee Laredo.
    The reason I mentioned is that an engineer told me Copper Anti-Seize actually breaks down steel bolts and can cause galling. He advised me to only ever use Nickel either Loctite, Nickel-Graph or Permatex brand
  19. Aug 27, 2022 at 6:32 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Each time I reread these posts I get more and more confused.
    Anti-seize and thread-lock are two different compounds and used for completely different purposes.
    Bivouac likes this.
  20. Aug 27, 2022 at 9:59 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Anti seize you got to use right one on the right metal....basic/copper/nickle....
    Cant use reg anti seize on aluminum....
    Anti seize is a must .......for bicycles......your $400 titanium pedals come with special copper A.S.
    Blue locker you can use on anything, with exception of high temps......stops galvonic....seals the joint/seam.....and over torquing isnt as easy.....
    Alot of times I just use the anti-seize to paint exposed threads on under carriage....
    its the only thing that'll stick to a recently 'fluid flimed' surface.....
    And no arguing here, all of you will do way way better than most of the previous owners....
