Rear Seat Storage and Dog Bed Platform
Discussion in '1st Gen. Tacomas (1995-2004)' started by loudboy, Apr 7, 2021.
  1. Apr 7, 2021 at 4:07 PM
    loudboy
    loudboy [OP] Well-Known Member
    Portland, OR
    '04 4x4 TRD Off-Road Limited
    All-Pro lift, Addicted tube bumper, Revenge sliders, stuff and crap
    Whipped up a better place for my pup to lay in the backseat of my Doublecab, with bonus storage underneath. My dog likes this much better as it's flat and wide, there's no edge to fall off, and she can see out the windows easily (she's a short chunky girl)
    Just a basic screwed and glued plywood frame where the rear seats used to be
    It's bolted to the same holes the seats bolted to, using bent brackets
    The platform itself rests on top of the frame underneath. The platform is bolted to a piano hinge which itself is bolted to the rear bulkhead using Riv-nuts. The carpet is glued to the plywood platform to keep it from slipping around. The memory foam in the back is just zipties to convenient points on the rear bulkhead using the wooden batten to hold it all in place.
    Pipe insulation foam is pinched onto a wooden forward lip on the platform to give a defined edge for the bed to stop against
    A rubberized sheet (Ruffwear Dirtbag Seat Cover) is laid out over the top of the platform. This created a sling or hammock of sorts so that the dog+bed don't do falling off the forward edge. The sheet has clips on is that fit wonderfully around the headrests. Small pleats were sewn into the sheet to tighten up the slack to help everything fit snug. A loop of elastic cord also helps hold everything in place.
    And a dogbed of memory foam remnants sit on top of it all, with plenty of storage on either side and behind.
    nagorb and BuddyS like this.
  2. Apr 7, 2021 at 4:14 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    looks great! I hope to do this one day myself.
  3. Apr 7, 2021 at 7:31 PM
    RandyO
    RandyO Well-Known Member
    Randy
    SF Bay Area (Calif)
    Silver '03 AC PreRunner
    Bed Liner and Bed Tool Box - nothing much...
    Looks great! Almost perfect. I'm thinking some type of seat belt to attach to a quality Dog Harness would be a good addition to this setup. That platform puts the dog at the perfect level to go flying through the windshield if an accident occurred.
