Rear Seat A/C Vents? Missing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spike Strip, Jun 17, 2023.
  1. Jun 17, 2023 at 6:04 PM
    Spike Strip
    Spike Strip [OP] Well-Known Member
    2023 TRD OR DCSB
    On my window sticker (circled in Red) it says, 'Dual Zone A/C w/ Rear Vents'
    Only vent in the rear I can find is the slots at the bottom of the back of the Center Console, yet no matter what A/C 'Mode' configuration I try on the dash, I can't feel anything out that vent, so it's not really an A/C vent I gather.
    The owner's manual (pic below) has a graphic of a couple of vents pointing to the rear seats, but I don't have those vents...
    What am I missing, here?
    '23 DCSB OR 4x4
  2. Jun 17, 2023 at 6:05 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    The rear vents are on the floor only and the system only gives air to them during heating, or if you manually select the floor position.
    the vent in the console is for cooling the inverter.
  3. Jun 17, 2023 at 6:09 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
  4. Jun 17, 2023 at 6:53 PM
    Spike Strip
    2023 TRD OR DCSB
    Ok, got it, tucked under the seats... Thanks for the replies.
    Couldn't really feel the push of air unless I put the fan on high and manually direct to floor, only. My Carhartt seat covers may be interfering or partially blocking the vents. Will investigate.
    TRDRed likes this.
