Rear O2 sensor bypass/CEL fix.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 40950, Apr 17, 2014.
  1. Dec 3, 2015 at 9:39 AM
    #81
    40950
    40950 [OP] Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I'm going to "lob the ball" here and post that it's going to take a bit of research on your part. Sorry, but I don't have those values and test procedures for your specific truck and sensors in front of me. A quick look around TW found some interesting reads. Some stuff on youtube about heating sensors and checking for top values and response time of the sensor, for a 4 wire, 3 wire, 2 wire, 1 wire.
    I needed a pic of your exhaust in front of me,,so this was found pretty easy and I think it is close.
    https://www.tacomaworld.com/threads/cat-converters-3-4-underbody-pictures-please.168614/
    Just spitballing here, but I think you need that second cat or your muffler in place again for this to work. Your muffler is gone and the second cat is gutted. From what I have seen so far, it needs the factory back pressure of at least the muffler.
  2. Dec 3, 2015 at 1:58 PM
    #82
    Holyghost23
    Holyghost23 New Member
    The only reason I joined the forum is because YOU GUYS GOT IT WRONG!!!. i don't know if you all are really dumb or just ignorant. but THAT IS NOT HOW YOU WIRE IT.
    i hope for fucks sake not one of you is a real mechanic. cause this is 3rd year shit simple wiring. and it works on most brands of cars and trucks in north America with a 4 or 5 wire set up
    this is the proper way to wire it. the other way is retarded and won't work at all, you just make a loop.. like plugging an extension cord into itself. i suggest you kids go back to school. yes i know this is an old post but i found it on google and got pissed off at the stupidity.. i should have guessed import owners are too dumb to figure out simple wiring
  3. Dec 3, 2015 at 4:47 PM
    #83
    40950
    CR, WA
    stock
    Like my original post,,from info put together years ago from someone else. It works. Works better for some,,not so much for others.
    Thanks for the optional wiring path, might try it to see.
  4. Dec 3, 2015 at 5:32 PM
    #84
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I undeleted this post just so I can ask you one question-
    Why so much butthurt from what you found from the interwebz? Did you really join just to come off as someone who wore their maxi pad tape side up?
    While we appreciate your input, I would suggest coming off less of an ass.
    Kthxbai
    notrouble likes this.
  5. Dec 5, 2015 at 4:27 PM
    #85
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    Well I put it in this morning and reset the light. I drove around 30 miles so far today and no light so it's looking good!
  6. Dec 5, 2015 at 5:30 PM
    #86
    40950
    CR, WA
    stock
    I'll be damned. Just proves the theory, that all trucks are not created on the same shift.
    If that pops back on again, Reset it overnight. leave the batt leads off till its needed if you can.
  7. Dec 7, 2015 at 10:05 AM
    #87
    Kotayota
    Sean
    Charleston, SC
    04 White DC
    I jinxed myself. Right as I pulled back into the driveway. Reset it and it came back on after about 30 miles the next day.( with my scanguage) I'm not giving up on this though I know I made it right I tripped checked it.
  8. Dec 7, 2015 at 10:07 AM
    #88
    Kotayota
    Sean
    Charleston, SC
    04 White DC
    I'm wondering if you do need a working 02 sensor for this to work. I feel like that's what's throwing the code on mine then if I get a replacement sensor and it works, I'll get a p0140 then this will work for me. Think that's my next step now
  9. Apr 28, 2016 at 6:06 PM
    #89
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    So I read through this and still am not sure on the best way to wire it in. I'm running 3" exhaust off the turbo, no muffler no cat, and have just been running with no rear o2 sensor for the last year but it's inspection time again and I'd really like to not have to go back to n/a just to pass. I wired my plug back in and zip tied it up to the frame and after about 30 min of driving today, I'm throwing no codes yet *fingers crossed*
  10. Apr 28, 2016 at 7:21 PM
    #90
    40950
    CR, WA
    stock
    Inspection crap.
    That reads as the sensor is out of the stream, ziptied to the frame, and wired back in with the resistors in place?. Glad the light is now off,,but how in the hell does that pass?. Payola?.
    Do they roll under the rig and look at anything during those inspections in NC?.
    Lucky to be living here. I really wonder how much longer that luck will remain in WA state.
  11. Apr 28, 2016 at 7:34 PM
    #91
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    No, i haven't done the resistors yet as I'm not sure which is the proper way to wire them. NC is very lax, unless you go to a big chain they don't look. Luckily I know a guy that can help me out with other things but a CEL isn't bypassable. I'm allowed 2 not ready's so I'm hoping e erything will work out and evap and catalyst can be my not ready's lol
  12. Apr 29, 2016 at 1:24 AM
    #92
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    I know a bit about wiring diagtams and noticed a couple of discrepancies in the diagrams at this link. First off, the two diagrams are not wired the same. The first diagram does not remove the O2 sensor from the circuit. The resistor is in series with the white wire and the cap is in parallel with the sensor on the white and blue wires. Both white and blue are still connected to the sensor. In the second diagram the resistor is in parallel with the cap and both are in parallel with the white and blue wires and the sensor is disconnected, eliminating it from the circuit. The link talks about eliminating the sensor, so I would assume the second diagram is correct. This is the way Mod has his wired.
    The diagram Holyghost23 posted is the same as the first diagram on the link, which does not eliminate the sensor.
  13. May 15, 2016 at 9:12 AM
    #93
    Bjack
    Bjack Member
    99 tacoma 4x4 DLX reg cab
  14. May 15, 2016 at 9:13 AM
    #94
    Bjack
    Bjack Member
    I went to RadioShack. The exact parts and put on my 99 and it did not work
  15. Jun 5, 2016 at 10:53 AM
    #95
    R103rider
    R103rider Well-Known Member
    Jimmie
    AZ
    2003 Tacoma
    None...yet
    Crap. Have this code. Not entirely sure what it is yet. Got abut 6 months to figure it out/sort it out.
  16. Jun 6, 2016 at 5:49 PM
    #96
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    more than one way to do it
    heres an 02 sensor confuser some guy made (I wouldnt do it because I obey all federal laws no matter how idiotic, and I worship Mother Gaia )
    thinwall brass tubing press fit into place, reduces rear 02 reading enough to not throw code and with a new 02 sensor in front it will supply adequate fuel trim to get you by until you get your student loan paid off or play enough gigs at honkey tonks to save up for a magic catalytic converter that will save the world from pollution
  17. Jun 6, 2016 at 10:42 PM
    #97
    40950
    CR, WA
    stock
    Cool. Thanks. Another one to add to the list. Had read across that little trick not to long ago. No cross holes drilled in the bottom,, just the tube pressed on with the one I seen. A different material I think.
    Would take some serious banjo work to get enough duckets to find that Magicat.
  18. Sep 9, 2016 at 10:03 PM
    #98
    Sweet Crude
    Sweet Crude Well-Known Member
    The fix works.
    Interrupt the blue wire (signal wire) with the resistor (resistors have no polarity).
    Bridge between the blue wire (signal wire) and the white wire (earth/ground wire) with the capacitor (capacitors are polarized), the negative leg of the capacitor goes to white/earth/ground.
    The diagram in post #83 is correct.
    The following Youtube video explains the workaround, it also details how and why it works.
    You'll notice that in the video the fixer uses a 4.7μF capacitor as opposed to a 1μF.
    (μF = microfarad)
    The microfarad rating influences the duration of the of the pulse (oscillating wave length) from the sensor.
    Some ECU's measure pulse duration and set a code if the duration is to long or short, typically this software is not found in most Toyotas ECU's.
    This fix is for REAR (Downstream) sensors only****
    The Capacitor:
    https://www.radioshack.com/products/...ant=5717323589
    The Resistor:
    https://www.radioshack.com/products/...ant=5717290629
    cruiserguy likes this.
  19. Sep 10, 2016 at 10:57 AM
    #99
    40950
    CR, WA
    stock
    Cool. Thanks for the info to this thread.
  20. Sep 10, 2016 at 12:50 PM
    #100
    Sweet Crude
