Rear main seal replacement cost!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hamzeh-7, Dec 20, 2022.
  1. Dec 20, 2022 at 7:48 AM
    Hamzeh-7
    Hamzeh-7 [OP] Member
    Nick
    2016 Tacoma SR5
    Tacoma specs: 2016 SR5, 4WD with 128k miles
    Noticed a leak from the undercarriage. Took the taco to the Toyota dealer and was told the leak is coming from the rear main seal. Quoted $3200 for replacing the rear main seal. I’m aware it is 90%+ in labor I’d be paying for, however, quote a little seems steep. Is $3,200 a high quote? Any suggestions?
  2. Dec 20, 2022 at 7:50 AM
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    How many hours did they quote?
  3. Dec 20, 2022 at 7:52 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    this
    and ask for a copy of the quote,,, location will matter, but you can look at all the other fees and charges. Also see if they are quoting by the book or hourly.
  4. Dec 20, 2022 at 7:52 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    The average labor rate per hour is between $75 and $130. You can expect the dealership rate to be higher than at an independent repair shop. So yeah, that quote isn't that far off. They probably estimate 30hours of total labor.
  5. Dec 20, 2022 at 8:29 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    You have a 4WD and it's a given it will be more than a 2WD. That being said, it shouldn't take more than 12hr for a good tech to do.
    I would get other estimated from other dealers or reputable shops in your area, try transmission shops too, they may be lower and may have more expertise in this area.
    Good luck
  6. Dec 20, 2022 at 9:52 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    I looked up the labor time to replace an automatic transmission earlier today. The labor was 9 hours. So add .5 for the seal for 9.5 total. Our labor rate is $150/hr for a total of $1425 for just labor. Add parts, shop supplies and taxes. And you would be in the $1650 range.
    CaptainBart45 and Chew like this.
  7. Dec 20, 2022 at 9:53 AM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    This. I was gonna say a rear main can be done in 12-16 hours max, if there's any more time allotted I think you're getting taken for a ride or it's an incompetent and/or unethical shop. I'd for sure get at least one or two more quotes. I'd honestly expect a quote for that to be half of what yours was, but you did get your quote from the stealership so...
  8. Dec 20, 2022 at 10:27 AM
    MGMoverland
    Brad
    Golden, CO
    Some rear main seals require removing the oil pan to access the seal or seal housing depending on what is involved in the install. IE sealant required at the interface between the rear main housing and the oil pan. This can add substantial time to the quote. Not sure on the 3.5 3rd gen specifically.
  9. Dec 20, 2022 at 10:42 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Did this leak happen quick or slow? Have you cleaned or replaced your PCV valve at any point?
  10. Dec 20, 2022 at 10:53 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    One piece seal, have to pull trans.
  11. Dec 20, 2022 at 10:57 AM
    rolled93slc
    Jerry
    Lynchburg VA
    Toyota Warranty time for this is only 5.9hrs. So It is not that involved. It has a seal plate that is bolted to the block and to the oil pan. Pan removal is not needed. The seal is also a separate part from the Seal plate. So that does not need to be removed either.
  12. Dec 20, 2022 at 11:32 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I have changed some rear main seals that took 3 shifts with 2 guys to change... they can be labour's intensive. $3200 is a dealership tax. I bet a good quality mom and pop shop could do the job just as well and for much cheaper. And you help the little guy... if it isn't warranty, I would never darken the doorway of a Dealership service centre.
    MGMoverland likes this.
  13. Dec 20, 2022 at 11:35 AM
    MGMoverland
    Brad
    Golden, CO
    I was referring to some engines so it is good that it is not required. Some housings do not give much space to slide the seal and housing together onto the block. It is always a good thing to remove the oil pan if you want to ensure proper seal. Just replacing the seal in the housing and not replacing the housing gasket can be risky as well.
  14. Dec 20, 2022 at 11:38 AM
    eurowner
    eurowner Duke Sky
    Scoty
  15. Dec 20, 2022 at 11:39 AM
    MGMoverland
    Brad
    Golden, CO
    I would def recommend checking out a independent as well. Usually have good techs who are better paid at brand specific independents (I was one) who are more interested in repairing it correctly.
  16. Dec 20, 2022 at 3:16 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I paid $1100ish a few weeks ago. 120K miles on the engine. Local shop that specializes on Toyotas. I made a thread on it.
  17. Dec 20, 2022 at 3:29 PM
    gregmitchell90
    gregmitchell90 Member
    16' TRD Sportyspice, 6', 2WD. Blazn Blew.
    Changed tires a couple times.
    Actually having mine done as we speak. $800 for a one day job in a shop in Mesa, AZ. 2WD TRD Sport 2016. 115k mi. Kinda bummed, but thankfully only major repair thus far.
    rtzx9r and shotgunbilly420 like this.
  18. Dec 20, 2022 at 3:33 PM
    Hamzeh-7
    Nick
    2016 Tacoma SR5
    Curious what major could go wrong? Asking so I can be aware of possible problems if I take the taco to an independent shop
  19. Dec 20, 2022 at 3:44 PM
    The hammer
    I would say the same usual suspects that do wrong at stealerships and independent shops alike. Mainly, over torqued, under torqued or missing fasteners and improper installation of the seal.
    The main thing is to replace the seal with a TOYOTA oem seal, after checking to see if the said seal is the currently or superseded seal recommended.
  20. Dec 20, 2022 at 3:49 PM
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    Just my 2cents. I also have a 2016 SR service truck and my rear oil seal went out at 183,000 miles. It cost me approximately over a $1,000.00 with tax.
    gregmitchell90 likes this.
